06-10-2014, 03:10 PM | #1 |
Rep 146
2011 X5 Maintenance Schedule
May be this a re-post but i am looking for a maintenance schedule for my 2011 X5 , i ve got 57k mile on it and don't want to go with extended warranty or maintenance package being offered by BMW.
Being a DIY savvy i believe i should be able to handle most of the regular maintenance items such as filters , plugs, oil , brakes etc. Secondly, are there any known problems that can happen at higher miles for e.g.: bad water pump at xxxxx miles? or a belt change may be? Please Help! FYI - its a used X5 and didn't come with owners manual that i can refer too for help. |
06-10-2014, 03:25 PM | #2 |
Rep 994
You can go to BMW's site, register there and your car VIN to download manuals for your car.
2012 X5 xDrive35i Sport Activity - Alpine White - M Sport Package
06-10-2014, 03:53 PM | #3 |
Rep 146
06-10-2014, 04:53 PM | #5 | |
Rep 11,136
He finally just ditched it and bought a Tahoe this year. |
06-10-2014, 05:08 PM | #6 |
Rep 994
Other than what the onboard computer tells you through the menus, this guide mentions somethings:
http://www.bmwsections.com/docs/x5/ You can google harder than I did, all I used was "e70 maintenance."
06-10-2014, 09:00 PM | #7 | |
Rep 146
Interesting… Thanks …. now i gotta decide even harder
06-10-2014, 09:01 PM | #8 | |
Rep 146
06-10-2014, 09:03 PM | #9 |
Rep 146
06-10-2014, 09:10 PM | #10 |
Rep 994
But it has a section on maintenance right, which refers you to mainly the onboard computer and service info... There is your answer.
06-12-2014, 11:00 PM | #11 |
Rep 1,067
Drives: 2017 M3 ZCP / 2017 RRS SC
That is no such thing as a maintenance schedule on a modern BMW. When the computer alerts you to maintenance, you do it. Not that I agree with that but that is the reality. There are some items which are not in the computer like spark plugs on the TT motor I think are 45k miles. The best bet is go go by the old school schedules of the past. I would start by cutting that 15k oil service down to 7500ish.
17 M3 ZCP -- 2017 Range Rover Sport SC --RIP-- 12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500 |
08-12-2019, 09:38 PM | #12 |
Rep 109
What about the ZF8 transmission? Is it lifetime fluid, or does it need drain/refill at certain mileage/time? My 2011 had 70, xxx miles on it currently.
09-07-2019, 09:51 PM | #13 | |
Rep 18
I did mine at 60k even if it was working flawlessly. After the fluid change, there has been a small improvement in smoothness between gear shifts and better MPG. |
greg3288.00 |
09-08-2019, 02:49 PM | #14 |
Rep 828
Drives: 2011 X5 3.5i w/ SA Package
No fluid is lifetime, no matter what they say. I did the fluid and pan/filter at 58k miles on my ‘11 ZF8. I bought the kit delivered from FCPEuro for $254. It was a bit of a pain to follow the process and procedure, but saved me hundreds, and was very satisfying to know it was done right.
greg3288.00 |
09-08-2019, 06:04 PM | #15 |
Rep 109
Is this the kit you bought? It's less $$ than you mentioned..
https://www.fcpeuro.com/products/bmw...-24118612901kt Greg |
09-08-2019, 09:23 PM | #16 |
Rep 828
Nope. I bought the kit with OEM ZF fluid. Probably not a significant difference. I just thought since this would be the only time I change it, I’d go OEM all the way.
