04-25-2014, 04:09 PM | #1 |
Rep 81
Turning radio off when exiting car
OK, a tiny pet peeve of mine is that a single push of the start/stop button to turn off the engine does not turn off the radio. This seems to require a 'double tap' to turn everything off. I tried holding down the button for an extended period as described before but this does not seem to turn off the radio and electronics like a quick double tap does.
Is there any way to override this or code this differently? Thanks. |
04-25-2014, 04:18 PM | #2 | |
Rep 18,727
The way the start/stop button work is similar to the old school physical key. There are 3 position. 1. Off 2. ACC 3. Start So, with start/stop button, if you only press once from off position, it will go to ACC position, unless if you press the brake pedal then it will start the car immediately. Same as if you press the button when the engine is running, it only kill the engine, but not the whole electrical system that run the accessories, such as radio, power window, etc. Hope this help.
04-25-2014, 04:20 PM | #3 |
Rep 18,727
Oh, to answer your question.
There is no power off on the radio. I am not sure if there is another way to shut it off by holding some other button for a few seconds. I never worry about it since the new car are smart enough to not get damaged or damaging other component by just shutting off the car.
04-25-2014, 04:25 PM | #4 |
Rep 81
Yeah, I understand the starting up the car thing. And I understand that there is no 'turning off' of the radio. I just want to be able to go from running engine while parked to everything off without pressing the button twice. Is that possible? Right now, I'm having to press the button twice to cut off engine and turn everything off. Is there a way to do it with just one press?
04-25-2014, 08:49 PM | #5 | |
Rep 3,307
04-25-2014, 08:54 PM | #6 |
Rep 18,727
Ahh, my mistake, now I understand exactly your question.
Chrisny is correct, you can jump out and locked it and everything will be turned off.
04-25-2014, 09:21 PM | #8 |
Rep 3,990
So, to add to this discussion in regards to double tapping to turn off the car completely. Why do the ambient lights stay on until you lock the vehicle? If I leave it unlocked, the ambient interior lighting stays on for a while - I stood there for at least 3 minutes before locking because they still stayed on. Do they eventually turn off or do you have to always lock the car for them to turn off?
04-25-2014, 09:39 PM | #9 |
Rep 423
I'm glad you asked that question, I just came in from a night drive and everything turned off except for the lighting trim (night light) and instrument panel. It went off in about 3 minutes or so, but is this normal?
04-25-2014, 10:01 PM | #10 |
Rep 18,727
Unfortunately I never pay attention to that, because I always leave the car unlock in the garage and just left. I have faith in the safety design where it will shut off everything if no activity for 30 minutes.
04-25-2014, 10:07 PM | #11 |
Rep 3,990
Yeah, I always used to before I noticed the lighting kept staying on, so I wasn't sure. I didn't want to risk it. I guess it eventually shuts off; good to know.
04-26-2014, 03:53 AM | #12 | |
Rep 2,713
04-26-2014, 04:52 AM | #13 | |
Rep 3,990
04-26-2014, 08:54 AM | #14 | ||
Rep 18,727
My youngest son loves to stay in the car and pressing buttons also even when the power is out. So my wife sometimes leave him alone while she is unloading grocery from the trunk. But then, you won't believe what he did. He put coins inside the CD slot. Fortunately, he did it to my wife's F10, which I rarely drive. But then, it annoys you, now we can even use the CD drive.
