04-11-2014, 07:51 PM | #1 |
Rep 253
Drives: '08 135i M-Sport Coupé
Coding BRAKE light off
My BRAKE light is lit on my dash. I waited too long to replace my brake sensors and I can't manually clear the code myself. Went to the stealership and they told me I needed a new brake sensor and I needed to replace my battery before the light would go away.
I know that when my adaptive headlights started throwing errors I just had someone turn them off in the coding and I just don't have that feature anymore. Is there a way to code out the brake sensor light so that it's not illuminated on my dash anymore? |
04-11-2014, 08:00 PM | #2 |
Rep 1,968
If the brake sensor tripped, you either need a new sensor, or you can "code" it off yourself by pulling out the sensor, stripping the two wires, twisting them together and wrapping them with some tape and tying it to the strut.
The brake light on the dash illuminates when there is an open circuit in either sensor (one per axle, LF and RR I think). Once you do that, reset it following these directions: http://www.1addicts.com/forums/showthread.php?t=415111 |
04-11-2014, 08:21 PM | #3 |
Rep 4,660
Instead of coding it out, why don't you just replace the sensor? It's such an inexpensive fix ($20 tops?). Replace the sensor and the light goes out on it's own, you don't have to do anything. And unless you battery really does need to be replaced, the SA is lying to you.
04-11-2014, 08:27 PM | #4 |
Rep 253
04-11-2014, 08:29 PM | #5 | |
Rep 253
04-11-2014, 11:45 PM | #6 |
Rep 1,491
Yeah that just want to make money out of you, don't be a sucker. Do what you got to do with the brake sensor, strip, replace whatever, and put your battery on a battery charger if it's really "flat" like they say it is then after to try the brake sensor parts
Black Wrapped Roof, BFG Rivals, Dinan Camber plates, M3 Steering wheel, Matte Black kidney Grills, H&R Sport springs,
Sparco assetto gara,Pagid sport Brakepads,STOPTECH Slotted Rotors, DISA STG3,EURO BOX |
