View Poll Results: Best tires size for 128i M sport 18" wheels | |||
FR: 225/40R18 RR: 225/40R18 | 22 | 44.00% | |
FR: 225/40R18 RR: 245/35R18 | 12 | 24.00% | |
FR: 225/40R18 RR: 255/35R18 | 16 | 32.00% | |
Voters: 50. You may not vote on this poll |
01-31-2014, 06:20 AM | #1 |
Rep 45
BMW 128i tires size poll
Hi,
I will buy very soon my new tires for this summer. Which of these sizes is the best for a 128i with M sport package and 18" wheels. Make your choice!!! :thump: Kafou |
01-31-2014, 08:25 AM | #3 |
bimmerphile, technogeek
998
Rep 3,785
Drives: 2012 E82 6MT Sport
Go square.
01-31-2014, 08:37 AM | #4 |
Resident Tamed Racing Driver
298
Rep 4,697
Also this.
Stock power? 215 or 225 square. Modded? 235 Square.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
01-31-2014, 11:56 AM | #6 |
Rep 45
01-31-2014, 01:02 PM | #7 |
Rep 750
Drives: '98 Z3M (gone), '09 135i
I'd go 245
01-31-2014, 01:15 PM | #8 |
298
Rep 4,697
None of the 128i power mods compromise that DD status. I should know, I have them all in my daily driver.
Square setup dials out a good bit of the factory understeer. I really doubt you will need a 245 setup as I'm significantly up over stock power and running 235 square. You also start to run into front wheel fitment issues at that point.
01-31-2014, 02:05 PM | #9 | |
Rep 45
01-31-2014, 02:47 PM | #10 |
298
Rep 4,697
I guess I always considered the 1 Series a lost cause in looks, so I focused on function.
01-31-2014, 08:58 PM | #12 |
Rep 506
Drives: 2010 128i 6MT Sport Pkg. 18"
Looking at the same situation this spring. I'm going to use the staggered stock 263 wheels and go w/225's squared. Don't see the need for more rubber than that on a stock car and those fatter tires just going to cost you more at the pumps.
01-31-2014, 09:04 PM | #13 |
Rep 2,239
225 squared. there's no reason to have anymore tire even with all the power mods for 128. Running a staggered setup is a a waste of tire, money and weight and causes understeer.
For the record i run 215/245 on my summer setup and it's unnecessary and has a lot of understeer compared to my winter setup which is 225-45-17 squared.
08 e93 335i MT
02-01-2014, 05:21 PM | #15 |
701
Rep 3,268
Drives: 2010 128i
No matter what, just go square. 225, 235, or 245, depending on wheel size and other mods. I'm running 17" 245's all around with no fitment issues.
____________________________ |
02-01-2014, 07:30 PM | #16 |
298
Rep 4,697
As someone who runs 235 square in the summer with all the power mods, you really don't need 245.
02-02-2014, 05:10 AM | #17 |
Rep 2,643
You may not need 245's for traction but it will give the rear rims better protection.
The cars tendency to understeer can be fixed with some front negative camber. 225F / 245R tire sizes can give nicely neutral street handling once you add front camber. |
02-02-2014, 01:17 PM | #18 |
Rep 45
Well, it's pretty close between square 225 or staggered with 245 rear. Have read a lots of comment from members who prefer square but not that much from the members who voted for 245. I'm curious to hear your comments. My wheels are the 261, so not the same size front and rear, I don't think that if I go square that will be a problem but if so, tell me...
Thanks Kafou |
02-02-2014, 01:40 PM | #19 | |
European Editor
10596
Rep 22,992
One reason why I decided to go with 225/255's... was that the 255 rear tires were a lot cheaper than 245's versions Just something to consider. What ever tire you go for make sure the tire sidewall is reinforced(higher load rating) for better turn in than normal tires would provide. My new Michelin PS3’s 225’s & 255’s… http://www.1addicts.com/forums/showt...chelin+PS3%27s
02-02-2014, 04:16 PM | #20 | |
701
Rep 3,268
Drives: 2010 128i
True, but why not add negative camber and square the tires?
02-02-2014, 05:05 PM | #21 |
Rep 2,643
I think it depends on the type of handling you expect and what you will use the car for. The car can still have plenty of turn in with staggered tires. If still using stock rear sub frame bushings I think its best to be cautious about adding front camber combined with non-staggered tire sizes.
The stock rear subframe bushings can cause unpredictable handling, which can be a very unwelcome source of instability. I wouldn't automatically recommend non-staggered tires in that case. |
