BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      01-08-2014, 05:43 PM   #1
LarThaL
LarThaL's Avatar
339
Drives: 2011 M3
Max performance tires compared in photos
Check out the pics below. These are all top rated max performance tires. Very revealing:
#1
What you see here, is that the 275 Michelin (left) is about 3mm narrower than the 265 Continental (right)
#2
The 265 Continental (left) is 10mm narrower than the 255 Yokohama (right)
#3
Finally, the 275 Michelin (left) is a full 13mm narrower than the 255 Yokohama (right)
I knew there are variations in sizes but for a 275 of one brand to be 13mm NARROWER than a 255 of another brand is quite surprising to me. This can be quite an issue with tight/aggressive fitments, rubbing, etc. Guess you really can't compare between tire brands. And then when you consider aspect ratio, this may affect overall diameter also.
Audi S6 * Audi S3 * Porsche Cayman GTS
--Former BMW M3 owner
      01-08-2014, 05:45 PM   #2
W///
W///'s Avatar
7532
Drives: F82GTS, E36/E92M3, Z4M
Wow cool, thanks so much for sharing. I guess I have no choice but to stay with Michelins (vs trying out AD08R's) because I'm close to rubbing already.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT
08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT
07 E85 Z4M Roadster, Alpine White/Red, 6MT
99 E36 M3, Techno Violet/Dove Grey, 6MT
      01-08-2014, 07:11 PM   #3
pbonsalb
Drives: 18 F90 M5, 99 E36 M3 Turbo
Tire Rack has the details in its specificatons. The tested wheel size is shown. If running the tire on a wider or narrower wheel, the tire will be very slightly wider or narrower.
      01-08-2014, 07:20 PM   #4
Brian0473
Brian0473's Avatar
31
Drives: 2010 SSII DCT Coupe
Wow...very helpful. This could be a great sticky if everyone would contribute who either owns multiple sets of tires or takes pics when they buy new ones.
Also, do you know the actual tire type and sizes used? (i.e. was the Michelin a 275/35 or 275/30...?). It will be interesting what the specs out on say Tirerack.com say.
No toys right now...
My old M3:
      01-08-2014, 08:55 PM   #5
LarThaL
LarThaL's Avatar
339
Drives: 2011 M3
The Michelin is a 275/40/20 Latitude Sport which is an SUV load rated version of the PS2 from my old Porsche Cayenne
The Continental is a 265/35/19 Contisport which is OEM stock from my 2011 M3 ZCP
The Yokohama is a 255/35/20 Advan Sport which in the OEM tire on my 2014 Audi S6.
I recently purchased a new Audi S6. I had the stock tires removed and replaced with OEM sized winter tires prior to delivery. When I looked at the width of the Yokohamas, I had to do a double take on the size because they seemed so wide. Indeed, my comparative measurements of all these unmounted tires lying on a flat surface confirmed my initial impression.
      01-09-2014, 03:06 AM   #6
r53s65e90
8300
r53s65e90's Avatar
Drives: r53 s65e90
IMHO measurements are meaningless if tires are not mounted. Also 265, 275 and so on, refers to the maximum width of a tire cross section when mounted on a recommended rim and not the tread width, which is not standardized.
scrammer422.50
      01-09-2014, 06:10 AM   #7
Brian0473
Brian0473's Avatar
31
But the photos are really showing the difference in cross section widths. If you go out to tirerack you can see these listed for every tire they sell. A quick look showed the opposite of the photos so this is interesting. I agree on the mounted vs. not mounted point.
My old M3:
      01-09-2014, 09:12 AM   #8
CSBM5
CSBM5's Avatar
2756
Drives: 2019 M2 Comp, 2011 M3, etc
Somewhat misleading since wheel widths are not shown, and those make a big difference in section width measurements. I can promise you that a 275/35-19 Michelin PSS is definitely wider than a 265/35-19 Continental DW when both are mounted on the same 9.5" wheel (recently evaluated this when buying PSS').
Here's one of my examples (I have many of these I've evaluated) -- this is a 245/40-18 BFG Rival, both tires shown are identical. Guess the difference.
Current Stable:
2024 G20 M340i Melbourne Red/Cognac
2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg
2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8
      01-09-2014, 09:28 AM   #9
325rider
Drives: '11 e90 M3 6mt
Here's one of my examples (I have many of these I've evaluated) -- this is a 245/40-18 BFG Rival, both tires shown are identical. Guess the difference. :)
They were mounted on wheels with different widths? How bout telling us
      01-09-2014, 09:51 AM   #10
CSBM5
CSBM5's Avatar
2756
Yep, of course. The one on the left is on a 8.5" wheel and the one on the right is on a 9.5" wheel.
Current Stable:
      01-09-2014, 01:07 PM   #11
dereksM3
dereksM3's Avatar
Drives: 2016 MG 340i M-Sport
Have any pictures of this as I'm very curious since I will be getting 275/35 PSS...even compared to OEM PS2 sizes as well.
      01-09-2014, 01:46 PM   #12
CSBM5
CSBM5's Avatar
2756
No, sorry, didn't take pics at the tire shop. I do have a pic of the 265/35-19 DW vs this 245/40-18 Rival both on 9.5" wheels though. The 265 DW was only 8mm wider than the 245 Rival when both are on a 9.5" wheel.
Current Stable:
      01-09-2014, 05:05 PM   #13
LarThaL
LarThaL's Avatar
339
Drives: 2011 M3
There are no wheel widths. These are all UNMOUNTED TIRES. There is usually a recommended range of wheel widths for a given tire.
      01-09-2014, 05:55 PM   #14
CSBM5
CSBM5's Avatar
2756
Ah, that makes sense now. You really can't compare unmounted tires since due to substantial differences in sidewall design, trying to measure section width, unmounted and uninflated, is pointless. You will find wide variation in unmounted section widths depending on the specific tire type...many years ago I was comparing unmounted Hoosier A6 versus BFG R1, for example, and made conclusions based on that, but they were completely invalid once I compared them mounted on the same wheel width and inflated.
Regards,
Chuck
Current Stable:
      01-09-2014, 07:22 PM   #15
Handy Man
Drives: Pending
Regards,
Chuck
What he said.
      01-09-2014, 07:44 PM   #16
LarThaL
LarThaL's Avatar
339
Drives: 2011 M3
Regards,
Chuck
But still....you wouldn't expect a 275 to be that much narrower than a 255. This is, in essense a 33mm "error".
FWIW, if I measure the unmounted treads, the 275 Michelin has a 267mm tread. The 265 Continental has a 270mm tread (although the tread is slightly more worn) and the 255 Yokohama (new) has a 274mm tread
      03-19-2014, 09:25 AM   #17
Colorado Rob
Drives: 2011 Comp 7speed Alpine Carbon
2011 BMW M3  [0.00]
Need tires - help 2011 M3 Comp 9" & 10" - which tires ?
My original sizes: 245/30/19 265/30/19
I think my spacers are F-12mm to 15mm
R -18mm
I have always gone PS2s.
What pilot sport or other tires do you all love ?
What sizes ?
Thx
      03-19-2014, 09:43 AM   #18
tdott
Drives: M3
I don't think those are accurate measurements, you are measuring the side wall bulge which has little impact on what actually touches the ground.
What you need to measure is the contact patch, the width of the tire that actually touches the ground. By measuring the contact patch you eliminate things like rim protectors that make the side walls budge out further. Also stating just the brand of tire is useless as different models will have different variances. You should state the full tire size and model of tire.
      03-19-2014, 08:08 PM   #19
LarThaL
LarThaL's Avatar
339
Drives: 2011 M3
These were tread measurements done in a consistent manner between tires. Nothing to do with sidewall bulge, etc.
Again, I am not surprised that there is variation. It is the degree of variation that surprises me.
      03-20-2014, 09:54 AM   #20
tdott
Drives: M3
Excuse the bad paint drawing, arrows are not exact just to give an idea of what I mean.
The amount of wide wall bulge or distance from the actual contact area differs between tires.
      03-20-2014, 12:17 PM   #21
Amirsm3
Amirsm3's Avatar
514
Drives: 2011 Space Grey e90 M3
I love tire rack's thoroughness with the tire specs.
2011 e90 M3 Space Grey DCT ZCP- eAs, BMW Performance, Agency Power, Macht Schnell, iND, Milltek, Volk, Challenge, Stoptech, Ohlins
BMWCCA:518970
      03-20-2014, 12:20 PM   #22
Amirsm3
Amirsm3's Avatar
514
But then there's still a variance. The one on the left is supposed to be a 275 width michelin and the one on the right is a 255 yoko. Subtract the sidewalls, still the same story.
BMWCCA:518970
m3post
