12-26-2013, 09:46 AM | #1 | |
Rep 2,201
Drives: .
Garage List 2018 Audi RSQ3 (8U) [10.00]
2022 BMW X3 xDrive3 ... [10.00] 2015 BMW M235i (F22) [10.00] 2017 Mini Cooper S ... [10.00] |
Ferrari Shows New 2014 F1 Engine
12-26-2013, 10:45 AM | #3 |
Rep 97
Wait a sec, there is a generator hooked directly to the shaft of the turbocharger? That is insane to imagine. What sort of RPM is that turning at? How did they design a turbo that can spool with all that resistance? Can't wait to see how this technology pans out.
12-27-2013, 03:31 AM | #6 |
Rep 220
12-27-2013, 06:43 AM | #7 |
S0THPAW
8954
Rep 7,860
12-27-2013, 11:54 AM | #8 | |||
Rep 2,201
Drives: .
Cool! What are you going to be doing in there? |
12-27-2013, 11:58 AM | #9 |
Rep 220
12-29-2013, 09:57 AM | #11 |
Rep 2,201
Drives: .
12-29-2013, 02:21 PM | #12 |
Rep 1,922
Drives: 2011 e91
How many years until we see our turbocharged cars with that generator system? This season should be exciting to watch.
2011 E91
2016 M2 - Sold 2014 X1 - Sold 2002 Land Rover Discovery II - 3" lift & 33s |
01-01-2014, 08:50 AM | #14 |
these are the times that try mens soul's
37
Rep 280
A 1.6L v6 that revs to 15,000 rpm is insane. IIRC the generator runs off of wasted heat (hot side turbo) I am pretty sure it isn't directly connected to it.
01-07-2014, 01:57 PM | #15 | |
Rep 379
Running the 1.6 to 15k isn't nearly as insane as running the 3.0 V10's up to 20k. The only reason they 'only' rev to 15k is because the rev limit is capped. Its been capped for the past several years.
There will be two forms of generators in the car; one will be hooked up the turbine shaft and one will be hooked to the gearbox/rear-wheels like the KERS of previous years. The turbine generator will either have a clutch on it to disconnect it from the turbine or it will stay at constant speed and always keep the turbo spooled up. I think it will be more the latter. There is debate if the engines will have wastegates or not, they almost certainly will not have blow-off valves. This year will be all about recovering as much energy as possible. Oh yeah, in case you did not know, F1 engines don't have valve springs. They use pneumatics to hold the valve closed; springs go into hysteresis at some point about 15k. Quote:
Living the 1-life since 2013.
01-07-2014, 02:23 PM | #16 | |
You got my money?
3629
Rep 4,861
Drives: Ice Cream Truck
"the dodo"
2022 G80 M3 Competition X /// 2025 X5 40i X
01-07-2014, 08:40 PM | #17 |
Rep 698
Drives: Mini Cooper S Paceman
This is the kind of stuff that makes F1 so special. Can't wait for this season to start!
