12-20-2013, 06:36 AM | #1 |
Rep 1,470
Brake pad swap = mushy brakes
This happened to me in October to a lesser degree (but a mid event bleed fixed it) but not in November but now again for this weekend's event. I swapped to my Pagids and now the brakes are mushy. I have bled each caliper twice now, and I am still getting way too much pedal travel. I basically have to double pump it. I never open the bleeders to swap pads. Anybody have a similar problem? If so, what fixed it? I have Stoptechs at all 4 corners. This is getting annoying. Unless someone has an idea, I am just going to suck out the reservoir and start from scratch with a liter of SRF.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
12-20-2013, 07:40 AM | #2 |
Rep 8,076
Drives: 11 E90 M3 Individual
I'd bleed in fresh fluid. I know E46s would have the brake booster go out which would cause a mushy pedal...might want to check that. It was a slight hissing sound...not sure if it's the same on an E9x.
2018 F30 320iX Melbourne Red
12-20-2013, 09:09 AM | #4 |
Grown Azz Man
430
Rep 3,021
Scott, get some new fluid...........Phil
2016 GT4.....Sapphire Blue Metallic, Platinum stitch Leather/Alcantara interior, Carbon Fiber Trim, PCM w/Nav, Guards Red Belts, 2 Zone Climate, Sport Chrono, LWB, Smokers Pack, Big Gas Tank, Light Design Pack, Bi-Xenon w/PDL, Auto Dim Mirror, Clear Side Markers, GTS Clear Taillights
12-20-2013, 09:44 AM | #5 |
Rep 7,298
Thats strange. Do you check your reservoir while you swap pads? I usually dont but after i swap one side, i pump the brake pedal until it stiffens up before moving to the next.
12-20-2013, 09:44 AM | #6 |
Rep 5,396
sounds scary
I had the same thing happen to me on my old Porsche when I swapped in new pads and retracted the pistons to get the pads in, and the problem that time was that the brake master cylinder had broken. it was my fault for not pumping the brakes before swapping the other side out. apparently this is very common on 997s, but haven't heard this about the m3. hope you can get it sorted out.
12-20-2013, 10:12 AM | #7 |
Rep 1,470
The fluid was new and completely flushed Oct 27. Worked perfect until pad swap.
12-20-2013, 10:13 AM | #8 |
Rep 1,470
Can I mess anything up pushing pistons back into calipers without lid off reservoir?
Never a problem before. It is odd.
12-20-2013, 10:14 AM | #9 |
Rep 3,675
my pedal felt the same so over the last 2 days i flushed all my fluid changed pads and put on a fresh set of rotors up front....only thing is i didnt flush the clutch so i guess we will have to see what happens at laguna tommorow...
12-20-2013, 11:34 AM | #10 |
Rep 1,470
Bled it again. Could master cylinder be goobered up? First push goes soft and almost to floor. A quick second push is tight. Same thing repeats every time I use brakes.
12-20-2013, 12:27 PM | #12 |
Rep 5,506
I always open the bleeder to swap pads then flush fluid after the change. Pushing dirty fluid back up through the ABS system and master cylinder can damage it.
Auto Detailing Enthusiast!
12-20-2013, 02:56 PM | #13 | |
Rep 381
Strange since all you did was replace the pads. Now that you're bleeding the brakes are you remembering to bleed both sides this time? I can't figure out how it would occur but it sounds like you either have air in the master cyclinder circuit or it's faulty.
12-20-2013, 03:08 PM | #14 |
Rep 1,470
Gave up for this weekend. Taking Porsche.
12-20-2013, 06:49 PM | #15 | ||
Rep 1,470
Reservoir never went empty, so no air should be in master. I think master is messed up but am just going to take it to momentum Monday.
12-20-2013, 07:17 PM | #16 |
Rep 8,076
The caliper is a pretty simple device. There's passage that carries brake fluid and pushes out the pistons. As long as you get a steady stream of fluid out of the bleed screw AND there are no fluid leaks...the caliper is good to go.
Did you ever run the reservoir dry? That means you need to cycle the ABS pump since you may have introduced air into the system especially if you used a pressure bleeder. Are you losing brake fluid? If not then its probably a brake booster, master cylinder, or a vacuum leak on the booster line.
12-20-2013, 11:10 PM | #17 |
Rep 1,470
Yes. Caliper is simple.
Reservoir never dry. No leaks. Not losing fluid.
12-20-2013, 11:48 PM | #18 |
11817
Rep 23,187
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
12-21-2013, 09:05 AM | #19 | |
Rep 8,076
BTW...have fun at the track. Be aware that T15 CCW tends to eat up P-cars
12-21-2013, 10:27 AM | #20 |
Rep 20,741
Drives: 2021 911 turbo
Were your Pagids new or already used?
If they were already used, is it possible they had some un-even wear? And when you re-installed them, they were not seating flat on the discs. The pads deforming/moving when pressure is applied will cause a mushy pedal. Hapenned to me in the past. |
12-21-2013, 11:14 AM | #21 | |
11817
Rep 23,187
12-21-2013, 11:52 AM | #22 |
Rep 8,076
Btw...what's a purple derple?
