12-16-2013, 07:09 PM | #1 |
Rep 1,049
First track day
I got to experience my first track day this past weekend at Willow Springs. Good times! What an incredible car. Decided to download my thoughts here…
Thoughts on the M3: I’ve been itching to take my car to the track knowing that street driving doesn’t come close to experiencing the potential of this car. I expected to be impressed with the V8, but I was surprised to be most impressed with the chassis and suspension. Yes, the V8 pulled (probably would pull harder without a full time passenger). Yes, the V8 rev range gave you lots of room to be in the power band and made engine braking really quite useful. And yes, the throttle response was immediate. But the chassis and suspension really wowed me. At speed, it just did things I didn’t think a 3700 lb car should be able to do and didn’t drive like a 3700 lb car. You could brake deep and hard without significant nose dive. The lateral grip was incredible. Accelerating hard out of a tight turn, the LSD was working its magic. Even the traction control compensated for my mistakes and helped me to recognize what I was doing wrong. Never felt like it was slowing me down as much as being my tutor. Between sessions the M3 made no complaints. Didn’t even break a sweat. After the track day was over I turned everything to comfort mode, clicked on the heated seats, found a nice Pandora station, cracked open the sunroof and had a very comfortable ride home. I can’t think of a better all in one package. Thoughts on driving technique: I had the benefit of a private instructor for every session. Very helpful to learn etiquette, learn the line and approach the limits safely. Highly recommended for newbies! This was the first time I was able to experience throttle steering both to push the car wide and pull into a corner. (Again, no way you would do this on the street.) I started to get it a lot more towards the end of the day. Lots of fun! I needed to relearn the M3s limits on the track. During street driving I know what it can do in a straight line and low speed turns, but under hard braking and higher speed corners it was a whole different story. I was very uncomfortable taking high speed turns, but gradually learned that when balanced, this car can hold a lot of speed in long sweepers. I also broke way too early because I wasn’t used to it. This car can brake later and harder than you would think. I also didn’t use 100% of the track because I’m not used to trying to ride the edge of a road. This prevented me from hitting the optimal driving line in certain places. I need to find the edge of my tires. Next time I am going to focus on braking later and harder, being in the right gear at the end of each braking zone, using off throttle to enter turns vs. braking when appropriate, turning in later & more sharply on some corners, and using the edge of the road. Oh and keep practicing throttle steer. Thoughts on other cars: Some people have a lot of disposable income. It was a lot of fun to see what people were hiding in their covered trailers. Saw some open top racecars and stock cars that were fun to see around the track. I always heard miatas were little track beasts. You never know what these guys are packing in these 10+ yr old cars. Most had modified suspension with R comp tires. Many did not have the stock motor. Who knows, LS1, turbos, you name it. It’s funny, but they are intimidating if you don’t know what kind of heat they are packing. Everyone knows GTRs are beastly. But man, down the straights they.are.beastly. Again, who knows how much HP they had, but the two I saw screaming down the straights made other cars look like they were standing still. Final thoughts: Very happy I got to experience the M3 on the track. On the streets it’s all about the engine. From a 0-60 perspective the M3 is pretty good. On the track it’s about the complete package, chassis/suspension/brakes/engine/transmission. On that front I found the M3 to be quite spectacular. |
12-17-2013, 01:23 PM | #3 |
Rep 1,239
Tracking
Reading your post takes me back 2.5 years ago when someone first introduce me to the world of tracking "huge smile in my face" Since then I've never look at my M3 the same way. Oh, and modding for the track. Lol that's for another thread entirely. Believe me from here on forward you will find creative ways to make more $$$ to support this disgustingly expensive habit.
2016 Hellrot F80 M3|JRZ RS Pro with Swift Springs 550/750 spring rates l AP Radical 5000R 9668/9449 lSpiegler SS LinesI DS1.11I Eisenmann DP|MPE Catback|18" Forgeline GS1R 18x10 et 22 and 18x11 et 44 NT01 275/35/18 and 305/35/18| Forgeline GTD1 18x10et43 SquarelM Performance Lip/Splitter|IND aesthetic mods|Dinan Toe Link|Fall Line mono ball conversion kit and upper link kit| Aim Solo 2DL Smarty Cam|Simpson Hybrid|Stilo Offshore helmet.
12-17-2013, 06:03 PM | #5 |
Keelhauler
Rep 83
Drives: 128i 6-spd
Nice post. After tracking a E36 M3 for a few years, I will be taking my E90 M3 to the track for the first time early February (Thunder Hill) and look forward to seeing how they differ.
Did you run with MDM and/or Power On? Were you on stock pads? If so, any fade? That is my only concern for my first track. Since I still have a warranty, I figure if I eat the pads/rotors, BMW can replace them. |
12-17-2013, 07:21 PM | #6 | |
Rep 7,298
12-17-2013, 07:29 PM | #7 |
Rep 1,049
12-17-2013, 07:41 PM | #8 | |
Rep 1,049
I ran power on as a preference. Not enough seat time to determine which I like better. 100% stock including pads. No fade, but again I need to learn to trust the brakes and brake later and harder. That said, Willow Springs did not seem like it was that hard on the brakes. Only a few really hard braking zones. Actually, part of my strategy is to track this car a few times before my factory warranty expires. Not just for free pads, but to get any kinks out of the system early. |
12-17-2013, 09:00 PM | #9 | |
Rep 7,298
Sorry jacobe!! |
12-18-2013, 12:47 AM | #10 | |
America
11
Rep 62
-Mid-Ohio-
12-19-2013, 08:13 AM | #11 |
Rep 20,741
Drives: 2021 911 turbo
Nice write up. Glad you enjoyed it .
You'll get hooked . |
12-19-2013, 12:12 PM | #12 | ||
Rep 1,239
First track day
12-19-2013, 02:36 PM | #13 |
Rep 6,149
Nice write up.
If you will be purchasing ANY AT&T services online or in store could you mention that you were referred by me? My Employee Referral ID is eo4489. This would be a great help and it costs you nothing, thank you!
12-19-2013, 04:44 PM | #14 |
Rep 18
Quick question...did you track on stock 19" wheels? I wanna track my car but don't wanna go through the hassle of getting 18's for my first track day
12-19-2013, 05:22 PM | #15 |
Rep 3,246
wheels are wheels and size makes little to no difference for a first time out. I've been rocking 19's for almost 4 years now and to OP congrats and welcome to the event horizon
mods: track ready stuff
12-19-2013, 06:47 PM | #16 | |||
Rep 7,298
12-19-2013, 10:33 PM | #17 |
Rep 1,049
Stock ZCP 19s and oem tires. No problem for the first time out. Didn't even use up a significant amount of tire. I think if you build up speed and are not entering corners too hot, you won't burn up too much tire on your first few outings.
12-19-2013, 10:40 PM | #18 |
Rep 1,049
Forgot to mention our most favorite topic; DCT vs. 6SPD!
DCT was fantastic, but I did miss knowing my gears by feel. This is the big drawback of DCT for me. Maybe when I get more used to the track, but I didn't have a lot of time to look down and figure out what gear I was in! Sometimes I was in too high a gear coming out of a turn or I downshifted into a near redline situation. I would never do that driving a 6SPD because I would just know what gear I was in, know the car speed and the general RPM range instantly. Now I have to look to remember what gear I'm in. Will have to practice glancing! HUD would be really useful in this regard. |
12-20-2013, 12:38 AM | #19 | ||
America
11
Rep 62
Stock 19s with the conti sports will be fine as you start out. They actually last quite a while if you don't fly into turns with too much speed and make them push. As far as shifting, I will stay away from the 6MT/DCT debate. But, I think everyone can agree that a proper exhaust system will help. On the track the stock system is impossible to hear which doesn't help at all when you are thinking about shift points, redline etc. The difference for me was night and day. Always keeps you aware! You also get to hear that great V8...
-Mid-Ohio-
12-20-2013, 08:20 AM | #20 | |
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
Like you, I run the stock ZCP suspension with ZCP wheels/19" tires. The only issue with running street tires is that they will melt on you on a warm day there (and bad stuff will ensue). You should be ok in the winter. Also, as you get a little faster, you will significantly wear the outside edge of the front tires (and sometimes the rears as well) and you run the risk of going through new tires in one or two sessions (like I did). More negative camber is the only fix. The stock ZCP suspension does not allow enough neg camber, so front camber plates/track alignment are essential. Hope to see you out there!
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
12-20-2013, 09:51 AM | #21 |
Rep 7,298
You should downshift a little later in the braking zone so that your rpms will be lower and you wont be over revving. I used to heel toe at the beginning of the braking zone and got the revs pretty high. Now i do it towards the middle or near the end of the braking zone and that will get you to a nice rpm for tracking out. Should be easier with dct.
12-20-2013, 10:50 AM | #22 | |
Rep 1,049
