12-16-2013, 09:43 AM | #1 |
Rep 116
Hankook TD Tire Pressure Recommendations
Trying on 285/30/18 square set-up on my E92M. What cold/hot tire pressures are you fellas finding best for fronts and rears?
And pressure differential between left and right at BRP-CW and BW-CW? Last edited by CalSE; 12-20-2013 at 10:21 PM.. |
12-18-2013, 09:13 AM | #6 |
Rep 1,388
Ahh, someone with 285 square!! Are you on stock suspension? Camber plates? What wheel width and offset?
I'm buying a set of 285 AD08s (I'm on 265 square AD08s now) off a friend and wanted to confirm with someone that 285s fit up front without the inside of the tire hitting the suspension. I've searched my ass off and haven't found a definitive answer. I have 18x10 et25 ARC-8s on my E90 (stock suspension with EDC) and am running -2.5 camber up front (with GC plates). Sorry for the thread jack but this is highly critical info!
E90 M3 Space/Fox/6MT
E92 335i BSM/Saddle/6MT - Sold |
12-18-2013, 09:49 AM | #7 |
Rep 116
First I have to give credit and thanks to EAS for assisting me in my set up.
Here is what I can remember: -Apex EC-7 x 10.5 to clear the Brembo. Can't remember the offset but I requested for the "flush" stance. -KW Clubsports at -3.5 front and -2.0 rear cambers. Front helper springs removed. Front springs replaced with shorter length but with same spring rate. I also think different collars were used. -MS 5 mm spacers at front. -Hankook 285/30/18 with no rubbing whatsoever. -Hankook 285/35/18 with slight rubbing in the front plastic wheel well cover at about 180 degree steering wheel turn. I hope this helps. If you want more details, I would suggest you call Kevin at EAS. I believe they have setup other M3s with 295 square! |
12-19-2013, 08:14 AM | #8 | |
Rep 1,388
12-19-2013, 02:11 PM | #9 | |
Rep 1,239
2016 Hellrot F80 M3|JRZ RS Pro with Swift Springs 550/750 spring rates l AP Radical 5000R 9668/9449 lSpiegler SS LinesI DS1.11I Eisenmann DP|MPE Catback|18" Forgeline GS1R 18x10 et 22 and 18x11 et 44 NT01 275/35/18 and 305/35/18| Forgeline GTD1 18x10et43 SquarelM Performance Lip/Splitter|IND aesthetic mods|Dinan Toe Link|Fall Line mono ball conversion kit and upper link kit| Aim Solo 2DL Smarty Cam|Simpson Hybrid|Stilo Offshore helmet.
