10-24-2013, 06:01 AM | #1 |
*_*
808
Rep 3,160
Wheel Lug Strength During Tracking Duties
Unlike most, I didn't go stud kit since I didn't want my dealer to blatantly know I'm tracking the M.
Suggestion/heads-up for newbies: after about 9 track events this season, one of the lug nuts snapped (Macht Schnell Spacers Kit). Makes sense since these aren't supposed to be removed and torqued that often over shorter periods of time. If you're tracking often, remember to switch out the lug nuts after a certain period of time so you're experiencing a snapped lug. Better yet, get a stud kit if it works for your situation. |
10-24-2013, 08:55 AM | #2 |
Rep 954
It should also be noted that you shouldn't torque your wheels (or really even check the torque) when you've just come in from a session. You want the check everything when it's cool. Torquing a hot lug is a good way to over-toque it and break it.
10-24-2013, 09:16 AM | #3 |
Rep 1,711
Its a good idea to change lug bolts every 10 or so track days.
Also, if you notice that one lug bolt is damaged, dont just replace that one. You must replace all 5 on that side. Last edited by Groundpilot; 10-25-2013 at 03:28 PM.. |
10-24-2013, 12:57 PM | #4 | |
Rep 4,488
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
10-24-2013, 02:50 PM | #5 | |
*_*
808
Rep 3,160
10-24-2013, 07:47 PM | #6 | ||
Rep 1,470
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
10-24-2013, 08:40 PM | #7 |
Rep 1,711
10-25-2013, 07:19 AM | #9 |
Rep 3,456
Drives: Harrop E90 M3
You should also avoid spacers as much has possible, especially under high stress circumstances like the track. They're just another added variable that can cause issues.
10-25-2013, 09:53 AM | #10 |
Rep 4,488
Hmm, I immediately loosen and retorque them to spec after it's been in a shop just to make that exactly right, but I certainly don't mind them mounting them initially.
10-25-2013, 10:06 AM | #11 |
Rep 3,337
The problem lies in a shop that over-torques lug bolts past their yield-point, even if they "fix" the problem right away...it's too late for that bolt. Then it is only a matter of time until that fastener fails in service (which is probably what happened in the case mentioned).
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 |
10-25-2013, 10:12 AM | #12 | |
Rep 954
10-25-2013, 10:39 AM | #13 |
Rep 4,488
^ Interesting, the indy shop I go to (and have since developed a great relationship with the owner) always uses an 80 ft-lb torque limiting stick when they're attaching the lugs to my car, and they mentioned without my even asking that they periodically check the accuracy of those sticks by using torque wrenches on the fasteners afterward and consistently find the sticks to torque within 1-2 lb-ft of their spec.
I also generally go into the shop with a typed page describing the services I want. I figure between the aftermarket parts I have and the fact that I have time to geek out over the details of my one car whereas they have to know all kinds of things for lots of different cars, if I can provide more information for them, it will ensure the job gets done right or at least save time and effort for them if it would have gotten done right anyway but with more work on their end. So on that page I have a note that the torque spec on the lugs is 88 lb-ft. I have a master Word document I keep with all kinds of other notes, including torque specs for various fasteners that are part of the StopTech BBK, notes about the Vorshlag camber plates, and even some stock stuff like a reminder of the existence of the secondary oil sump and the request to intentionally underfill during an oil change because an overfill is easy with these stupid dipsticks and can only be solved by draining from the bottom rather than running a fluid extractor down the non-existent dipstick shaft. Whenever the car needs service I just pull the relevant details from that master Word doc into a new one for the specific things I need done at that visit, and all is well.
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 10-25-2013 at 10:46 AM.. |
10-25-2013, 12:56 PM | #14 | |
Rep 1,711
10-25-2013, 01:08 PM | #15 | |
Rep 5,506
Auto Detailing Enthusiast!
10-26-2013, 06:52 PM | #16 |
*_*
808
Rep 3,160
I should've mentioned I don't use spacers on the track, I pop them off. Spacers on the street are a must hate that wheel gap - so fugly.
10-26-2013, 08:27 PM | #17 |
Rep 8,076
Drives: 11 E90 M3 Individual
You can over torque a fastener with a torque stick. Stud kit or OEM bolts are both subject to failure. IMO, a stud kit is more prone to failure because there's more room for installation error.
Over-torqueing once will not cause your wheels to fall off. Not properly seating the wheel against the hub or not having hub centric wheels AND over torqueing WILL result in failure of the fasteners pretty quickly. So that's why it is very important to keep your hubs and wheel bores clean. Although if there's a car at the track that is stuck on the side with 3 wheels...its usually a BMW.
2018 F30 320iX Melbourne Red
10-27-2013, 09:09 AM | #18 |
Rep 20,741
Drives: 2021 911 turbo
IMO, over-torqued bolts/studs used at the track is the most probable cause for studs or bolts to fail (unless the wheel is coming loose). When torquing a nut or bolt, it is not the torque per se that is sought after, but rather it is the amount of stretch of the bolt or stud that is needed. The bolts/studs act like a spring that squeeze the two surfaces to me mated together. It is the friction between the two surfaces that actually carries most of the load. If the nuts or lugs are over-torqued, this means the lugs or studs are also overstretched. Combined with the heat expansion of extreme track conditions, the lugs/studs can be stretched beyond their tensile strength limit causing them to fail. Every time you brake, the bolts/lugs are stretched, which could also cause fatigue failure.
Implying regular torquing and un-torquing of the lugs/studs as the reason for failure implies a very low cycle fatigue failure, which I think is unlikely if they are properly torqued to begin with. Last edited by CanAutM3; 10-27-2013 at 10:43 AM.. |
10-27-2013, 10:09 AM | #19 |
11817
Rep 23,187
i do the same as well. just haul them in the x5. otherwise would be driving all over on the nt01s also. i see those guys almost monthly for mount or flip.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
10-27-2013, 11:44 AM | #20 | |
Rep 8,076
Those lug bolts might have been old. But I'm curious if the lug bolts offer any reliability disadvantage vs the studs and lug nuts that every other non-EU car maker uses. I'm sure there are plenty of older Japanese and US cars with owners that aren't regularly changing their studs and are regularly over-torqueing them.
10-27-2013, 06:18 PM | #21 |
Rep 7,298
I always use hand tools for lugs. If a shop starts using air tools i will stop them immediately. Just a breaker bar for taking off and your hand with socket and then torque wrench for putting on.
Do these lugs break that often after 10 track days because there are plenty of ppl on here that are ok. Maybe due to having spacers on some of the time?? |
10-27-2013, 07:14 PM | #22 | |
Rep 8,076
