BMW M3 Forum (E90 E92)
      10-13-2013, 09:08 PM   #1
Sebringjetta
Sebringjetta's Avatar
Drives: E46m3
totaled e46 buying e90.. need tire and wheel recommendations
Ok so a few months ago I put my e46 m3 into a wall and sad to say she is done. I have gone through several threads about tire size but most of the memmbers already own a specific set of wheels and want tires for that set of wheels. With that said I will be starting from scratch so I need recommendations for wheel offset size along with tire size. I perfer to run nt01 as thats what I ran on my e46. I will be running bbk so that most likely puts me in te37sl and apex. But I was running te37sl on my e46 and to date I believe they are some of the best wheels out there for track use.
So school me on wheel size and tire size for my new sled. Thank you for your time
      10-13-2013, 10:13 PM   #2
M3 Esq
Automobilist
M3 Esq's Avatar
Drives: E70 X5, 911 GT3
Apex arc 8 is a good choice. I run 18x10 ET 25 square set, with 275/35/18. This is a very common setup.
I have also run staggered TE37SL 18x9.5 ET 22 and 18x10.5 ET 20 with 265/35 and 285/35. I like the apex setup better.
      10-13-2013, 10:19 PM   #3
Sebringjetta
Drives: E46m3
Do think 285/30 square or 285 front and 295 rear would rub or be an issue? Some members have mentioned this setup but wonder if its a little much...
      10-13-2013, 10:40 PM   #4
M3 Esq
Automobilist
M3 Esq's Avatar
I have not tried either of those setups so I can't say for sure. I know some have run 285/30 and I'm sure they'll chime in.
      10-13-2013, 10:58 PM   #5
Sebringjetta
Drives: E46m3
Well I really appreciate all your help sir
      10-14-2013, 02:28 PM   #6
OC3
Havin' a blast!
OC3's Avatar
Drives: 2013 M3 E92 Jerez Blk DCT ZCP
One of the sets I run is 285/30 squared TD's (on squared TE37SL 18x10.5 ET20) and the front tires just barely touch the fender liner. Wouldn't call it rubbing.
BRP 1:56 | CVR 2:01 | ACS 1:53 | WSIR 1:34
      10-14-2013, 02:53 PM   #7
Sebringjetta
Drives: E46m3
no rubbing!!!!! thats what i was hoping to hear w/ a 285-30
      10-14-2013, 04:45 PM   #8
OC3
Havin' a blast!
OC3's Avatar
I should note that the front camber is -3.5.
      10-14-2013, 04:52 PM   #9
Transfer
Transfer's Avatar
5254
Drives: Bronco Wildtrak, Tesla MYP
Probably the most common and works very well.
      10-14-2013, 04:54 PM   #10
OC3
Havin' a blast!
OC3's Avatar
Yep.
Although, many run that staggered setup as well.
It's a trade-off between larger front tires of squared setup reducing understeer at turn-in, and larger (than front) rear tires of staggered setup giving you more grip at corner exits. Tried to get best of both by running 275/35 R-S3 at front and 285/35 R-S3 at rear at one time last year. But, ultimately, ability to rotate tires w/ squared setup won over for me.
      10-14-2013, 08:38 PM   #11
jml
jml's Avatar
128
Drives: X5M, GT3RS, GT4
as above, 275 NT01 are pretty hard to beat in a square setup.
Make sure that if you get 18"s you get something that will clear a future BBK.
      10-14-2013, 09:18 PM   #12
klammer
Drives: 11 spc gry m3 e90, 19 X5
That's some serious camber! I'm not even at -2 Is that a track only setting or do you rock that on the street and if so hows the wear?
mods: track ready stuff
      10-14-2013, 10:15 PM   #13
OC3
Havin' a blast!
OC3's Avatar
I daily it like once a week, so it gets used mostly at the tracks. For street, I ride on old, heat-cycled-out R-S3's (of which I have 3 sets).
      10-14-2013, 10:20 PM   #14
Sebringjetta
Drives: E46m3
Lmao was doin the same thing on my e46 m3
m3post
