      09-24-2013, 02:30 AM   #1
hyphy1
hyphy1's Avatar
Drives: 2010 135i
Pre-LCI to LCI (eyebrow) Headlight Swap?
I have the 2010 headlights without the lit eyebrows. Will I be able to swap the old headlights to the LCI headlights with eyebrows?
Anyone here do any swaps/conversions out there? Coding issues?
      09-24-2013, 06:34 AM   #2
JimD
JimD's Avatar
369
Drives: 128i convertible
I don't think there are coding issues as long as the bulb of the headlight stays the same. I like my no brow headlights, however. Maybe you need to find somebody with a later 1 to swap with.
      09-24-2013, 06:58 AM   #3
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
Should be plug and play but is it worth it? Better to do custom LED AEs
      09-24-2013, 02:39 PM   #4
hyphy1
hyphy1's Avatar
Drives: 2010 135i
To the owner with price as no option, to each their own opinion.
Can anyone confirm perfect fitment of the headlight conversion (xenon to xenon)?
      10-02-2013, 05:19 PM   #5
kore
kore's Avatar
Spain
Drives: E81 118D N47
Perfect fitment is guaranteed with no issues.
LCI headlights are exactly equal to pre-LCI except the eyebrow.
The only problem here is that you have not the wire in the harness which provides signal to the eyebrow.
The solution is easy: on both harness connectors (one for each headlight) you have to put a little piece of wire to make a bridge between the pin of angel eyes signal and the one of eyebrow led signal. It is necesary to buy a pair of pins on your dealer (they are cheap).
I can't remeber the part numbers of the pins because I did it long time ago. But I remeber it was absolutely a simple operation.
That works perfect. Everyone I know they have upgraded to eyebrow headlights have done it this way.
Anyway, if you do this wire modifications to feed the eyebrows or if you don't, you will never have compatibility issues neither dashboard errors. So do it!
I hope this will help you.
      10-02-2013, 10:51 PM   #6
hyphy1
hyphy1's Avatar
Drives: 2010 135i
That really helped a lot! thanks!
Now to do a little research and search for the part number...
      05-05-2022, 02:32 AM   #7
sims_drk
Morocco
Drives: Bmw 135i
Hello hope ur doing well . I have pre lci lci bi xenon headlights ( without eyebrow ) and want to update to lci bi xenon headlights ( with eyebrow ) . I found the headlight on ebay but the part numbers aren't the same . Is that a problem ? Big thanks in advance
1addicts
