09-20-2013, 04:31 PM | #1 |
Rep 449
Thinking about upgrading to bucket type seats...
For my e92. My concern is since the seats cannot fold forward could i still fit my baby recaro seat in the back and easily get access for dd? My wife thinks it won't work because seat doesn't fold. Does anyone with infant/toddler baby seat have any issues getting in/out? Thanks
Cayenne "wifey"
M3 "mine" Previous toys: 997.1 GT3, C63, e92M3, 350Z, ISF, IS350, B5 S4, R1/Ninja 636 |
09-20-2013, 04:56 PM | #2 |
Rep 3,422
How about --
http://www.europeanautosource.com/pr...rtster-cs-seat Bucket shouldn't influence your ability to get a baby seat in the back, but it's going to get old sliding it back and forth, imo.
M4 GTS, GT3, C63 S | E90 M3s, E39 M5
09-20-2013, 07:40 PM | #6 |
Rep 898
09-20-2013, 07:55 PM | #7 | |
Rep 954
Safety systems are deigned to work as just that, systems. Part measures aren't safe. Since you want to use the back seats a cage is out. If you want to be more planted a folding bucket like the Recaro Sportster is a great option. But please skip the harness bar. If you want harnesses do it right. But harnesses are for the track not the street. Harnesses on the street are for show. And if you're driving hard and fast enough on the street to need harnesses than shame on you. |
09-20-2013, 10:07 PM | #9 | |
Rep 3,422
Sparco, G-Force, Simpson, etc. All of their 4 pt harnesses are unsafe? For example http://www.sparcousa.com/product/4pt-belt (FIA approved). Believe NASA is allowing 4 point. I'd like to think sportster cs + bar + 4 pt harnesses would be a viable solution for sliding around on stock seats, but not able to do a cage. (Assuming the structural integrity, sufficient strength of the harness bar.) What am I missing
09-20-2013, 10:26 PM | #10 |
Rep 7,298
I think 4 point is allowed for autox. But if you get in a crash at a track uhoh. I think the person at chuckwalla was in a 4 point and his gf submarined and passed away. If you are basically going to be glued in your seat you need the car to not crush you hence cage. Thats what im thinking at least using common sense.
09-21-2013, 07:18 AM | #11 | |
Rep 954
The issue isn't the 4 point belts. There are FIA approved 4 points that have anti-submarine features that should prevent you from sliding under the belts. The concerns I would have are two: 1. If you are in a roll over crash the harnesses keep your body from rolling away from the deforming roof as you would in a 3 point setup. Hopefully the seat would crumple enough to prevent your spine from compressing, but hopefully and spine compression aren't really great words to have in a sentence together. 2. If you have a rear impact and the seat back of a folding bucket were to give out you run the risk of hitting your head on the harness bar. This is part of the reason that a cage and reclining seats are a bad choice as well. Of the above two concerns, #1 would scare me a lot more. But #2 is dangerous as well. Something being FIA approved is great, but you need to dig further into how the FIA testing as done. Was it done with a folding seat or fixed back? Was there a cage or a bar? Was there a net, a halo seat, etc? All of these safety devices are meant to work as a system and putting just one piece on the car and assuming since it's FIA certified you're ready to rock is a bad one to make. We all assume some risk in taking our car onto the track, but if you feel like you're fast enough to need actual harnesses and race seats then I think you're at the point of being ready for a cage. Now, having said all of that, I will say this really (to me) applies to track driving. Auto-X I'd feel pretty comfortable with fixed seats and a bar and (probably) quality reclining seats and a bar. I say this because I think the likelihood of a roll over is very low and there are no other cars or walls to hit. As I said above, if you're buying this kind of gear for the street because you think you need it you are driving too fast on the street (and probably aren't even nearly as good as you think you are) and should be ashamed of yourself. If you're looking for another option, consider the Schroth Quick-Fit harnesses. I think they are out or just about to come out for the E92. I had them in my E46 and they did a great job of keeping you planted in your seat. They are a great option for a weekend car that needs to haul the family around during the week. However, check with the group(s) you run with and the local laws. I was told by NJ BMW CCA and DelVal BMW CCA (my local groups) that they aren't thrilled by them and are not allowed in New Jersey. So rather than risk the displeasure of a great group of folks that run great events and/or getting hassled by the state troopers that like to prowl around NJMP I got rid of mine. But they were great. So it's worth considering. Sorry this turned into a local soap-box speech about this stuff. It's just something I've done a lot of soul-searching on and have formed strong opinions on. Stay safe. -Doug |
09-21-2013, 07:42 AM | #12 | |
Rep 3,422
09-21-2013, 08:05 AM | #13 | |
Rep 8,076
Drives: 11 E90 M3 Individual
But BMW owners are lucky since we have a DOT tested 4pt harness option that you can remove. Fixed back seat? Baby? No way in hell you can get a baby seat back there. If you could it would be such a massive PIA.
2018 F30 320iX Melbourne Red
09-21-2013, 09:40 AM | #14 |
Rep 3,422
09-21-2013, 09:53 AM | #15 |
Rep 8,076
Yes ...lets keep this on topic. Many past schroth 4pt harness threads have gone in the toilet pretty quick
09-21-2013, 09:57 AM | #16 |
Rep 206
I've also wanted Recaro Pole Position for quite a long time, but my problem is that I want to be able to use the back seat. If this is the case, than just forget it. There is just no wise solution for the problem. You might be able to put the child in the seat, but in case of bad crash, where your B-Pillar get crushed, I wouldn't want my child to be seating in the back. In situations like that sometimes it is only matter of seconds before the worst happens.
My solution is Schroth Quick Fit (Pro). As bigjae1976 said, you only have to adjust the lap belt correctly. The Recaro Sportster CS are a waste of money for me, because they are not lighter, they don't offer much more support than stock seats and you still sit too high. My conclusion is, that if you want bucket seats, you have to forget about the back seat. Last edited by dex37; 09-21-2013 at 12:47 PM.. |
09-21-2013, 10:01 AM | #17 |
Rep 3,422
09-21-2013, 10:08 AM | #18 |
Rep 449
Thanks for all that replied. Definitely something to think about. Perhaps now isn't the right time to buy fixed seats :T
Cayenne "wifey"
09-21-2013, 11:04 AM | #19 |
Rep 8,076
More of a humor thing vs an argument.
09-21-2013, 11:43 AM | #20 | |
Rep 7,298
09-21-2013, 12:45 PM | #21 | |
Rep 206
09-21-2013, 01:51 PM | #22 | |
Rep 954
