BMW M3 Forum (E90 E92)
      09-17-2013, 07:16 AM   #1
E92inSG
E92inSG's Avatar
553
Drives: F80 M3
Ok I'm about to bite the bullet and splash for a set of semi slicks.
My rim setup is TE37SL 18x9.5 front and 18x10.5 rear.
Currently on hankook R-S3 265/35 and 285/35
Will most likely be going for Pilot Sport Cups for my next competitive event.
I can either go 265/35 and 295/30 or I was also thinking of running a square 285/30/18 to provide a bit more grip upfront (slight understeer currently) and also maybe extend tire life by rotation (not a huge concern)
What would you hardcore track guys recommend?
1) stay with 265/35 and 295/30
2) go 285/30 square on staggered wheels
3) go 285/30 front and 295/30 rear
      09-17-2013, 07:33 AM   #2
E92inSG
E92inSG's Avatar
553
Drives: F80 M3
Edited 1st post
      09-17-2013, 09:40 AM   #3
Porschefile
Porschefile's Avatar
59
Drives: E92 M3
Definitely option 2 or 3. Wider tires up front= more overall grip for sure, and likely better balance. 275 square on 10's works well.
      09-17-2013, 09:52 AM   #4
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
option 4- square set of tires and wheels. if you have staggered wheels and square tires means you cant change front to rear at the track to even wear out which is the advantage of having a square set in the first place.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs|
      09-17-2013, 10:04 AM   #5
E92inSG
E92inSG's Avatar
553
Drives: F80 M3
Like I said for me the advantage of square setup is more of the additional rubber in front vs the possibility of front to rear rotation.
I definitely won't be getting another set of wheels so option 4 is out
So
With that outta the way,
You guys are saying I shouldn't run square tires on non square setup?
      09-17-2013, 10:22 AM   #6
mkPOTO
Mr. Nice Says Hello
mkPOTO's Avatar
636
Drives: BMW M3 | X5 xdrive 35i MSport
yes squared, I ran staggered and you can tell the car twitches a bit, so I went with 18x10 apex with 285 tires and the car feels planted!
      09-17-2013, 10:28 AM   #7
E92inSG
E92inSG's Avatar
553
Drives: F80 M3
So there shouldn't be any issue running square tires on non square wheels yah?
      09-17-2013, 11:08 AM   #8
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
no you can do it but might want to think about 275-35 square as you are putting a pretty wide tire already on the front 9.5 rim.
      09-17-2013, 11:11 AM   #9
E92inSG
E92inSG's Avatar
553
Drives: F80 M3
MPSC doesn't come in 275/35
anyway i found some good info from michelin themselves so looks like i'm gonna stick with 265/35 in front and 295/30 rear
FYI
      09-17-2013, 11:17 AM   #10
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
265 shows fits 9-10.5? i ran advan ad08s in 265-30-19 as my track tire for a time and still think the benefit of square front to back outweighs slight decrease in tire width in the rear. your entry and mid corner speed will be better and handle more neutrally and exit will only suffer slightly.
      09-17-2013, 11:35 AM   #11
E92inSG
E92inSG's Avatar
553
Drives: F80 M3
Hmm so your saying I should decrease rear width? I always thought the way to go square was to increase front width instead.
Will do a bit more research
      09-17-2013, 11:58 AM   #12
swartzentruber
Drives: 2011 E90 M3
Why PSC? I think there are far better R-comps for cheaper. I had them once, never bought them again.
2011 Jerez Black/Fox Red E90 M3 DCT, ZCP, ZCV, ZCW, ZP2, BMW Apps
2015 Golf R
      09-17-2013, 12:06 PM   #13
Groundpilot
Groundpilot's Avatar
Drives: 135I DCT , e92 M3 DCT, Audi A6
+1. PSC are not nearly as good as BFG R1
      09-17-2013, 12:06 PM   #14
E92inSG
E92inSG's Avatar
553
Drives: F80 M3
What would you recommend?
      09-17-2013, 12:11 PM   #15
E92inSG
E92inSG's Avatar
553
Drives: F80 M3
Originally Posted by Groundpilot
+1. MPC are not nearly as good as BFG R1
I'm not allowed to use straight grooved semis in my class.
      09-17-2013, 12:14 PM   #16
radiantm3
Apex Everything!
radiantm3's Avatar
Drives: 2007 Honda S2000, 2017 GT350
2011 E92 M3  [9.35]
2014 BMW i3  [10.00]
Get Hankook TD's. They are worlds better than PS Cups (or R888's). I just ran them last week and I'm in love with these tires. They come in 265/295 as well (that's what I run). Feels like and endless amount of grip.
2011 E92 M3(Sold). 2007 Honda S2000 (Track Car). 2016 Cayman GT4 (Sold). 2017 Shelby GT350 (AKA Crowd Killer).
My pet project: https://stickershift.com
      09-17-2013, 12:30 PM   #17
E92inSG
E92inSG's Avatar
553
Drives: F80 M3
That's the only other alternative I was considering.
Z221.
So u ran both and the TD's were noticeably faster?
      09-17-2013, 03:55 PM   #18
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
try nt01. comes with thread.
      09-17-2013, 05:00 PM   #19
OC3
Havin' a blast!
OC3's Avatar
Drives: 2013 M3 E92 Jerez Blk DCT ZCP
I run 285/30/18 TD's (squared) on TE37SL 18x10.5 squared. Fits perfectly, no rubbing, no need for spacers, etc.
And, 275/35/18 NT01's (squared) on TE37 18x10.5 squared. Works great too.
BRP 1:56 | CVR 2:01 | ACS 1:53 | WSIR 1:34
      09-17-2013, 05:56 PM   #20
E92inSG
E92inSG's Avatar
553
Drives: F80 M3
What do a set of TDs run for in those sizes in USA?
      09-17-2013, 05:57 PM   #21
radiantm3
Apex Everything!
radiantm3's Avatar
2011 E92 M3  [9.35]
2014 BMW i3  [10.00]
Z221.
The cups were horrible. And once you pass the fairly low limits of grip they just give out from under you with little warning.
      09-17-2013, 06:29 PM   #22
OC3
Havin' a blast!
OC3's Avatar
$1,300 or so.
m3post
