08-26-2013, 02:29 PM | #1 |
Apex Everything!
976
Rep 4,378
Drives: 2007 Honda S2000, 2017 GT350
Track Prep Mistakes...
I was just thinking about some of the mistakes I've learned from in the past related to tracking my car. Figured you guys might have a ton as well and a lot of us could learn from them. Here are 2 of mine:
Not Enough Camber with R Comps Besides the fact that I shouldn't have been running r-comps at my then skill level anyways, I was running PS Cups with -1.8 degrees of camber in the front. The tires corded on the outside fronts only after a couple track days. Expensive mistake. Overflowing Brake Fluid when Changing Pads A few months ago I put on brand new pads which meant the calipers had to be opened up quite a bit to fit back on the rotors. I didn't bother checking the level of my brake fluid in the reservoir and it ended up overflowing. I wiped it clean and thought everything was fine, but about a month later, my car started going into limp mode because the brake fluid fried a sensor.
2011 E92 M3(Sold). 2007 Honda S2000 (Track Car). 2016 Cayman GT4 (Sold). 2017 Shelby GT350 (AKA Crowd Killer).
My pet project: https://stickershift.com |
08-26-2013, 03:05 PM | #2 |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
Great idea, thanks for posting!
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
08-26-2013, 03:10 PM | #3 |
Rep 633
Always double check on lugs. Torque and re:torque. I have made this novice mistake every once in a while. Carry a to do sheet with a list.
Only add oil when the warning sign comes on dash. I added a tad much and got a warning for too much oil even when the oil dip on dash showed half. Had to drain some, PITA |
08-26-2013, 03:33 PM | #4 |
Rep 1,470
[QUOTE=radiantm3;14563103]
Overflowing Brake Fluid when Changing Pads A few months ago I put on brand new pads which meant the calipers had to be opened up quite a bit to fit back on the rotors. I didn't bother checking the level of my brake fluid in the reservoir and it ended up overflowing. I wiped it clean and thought everything was fine, but about a month later, my car started going into limp mode because the brake fluid fried a sensor. QUOTE] common mistake home mechanics make all the time. you top off the brake fluid as it drops when the pads wear and then put new pads in and overflow it. it is an issue on pretty much all cars. i typically use a turkey baster to remove some before and as i do each caliper to avoid that. the only exception i have seen was a 2007 acura TL type-s with front brembos. the FSM said I had to open the bleeder to let the fluid out when i pushed the pistons back, because pushing fluid backward was not good for their ABS system. odd, but I followed the manual.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
08-26-2013, 03:34 PM | #5 |
78
Rep 684
My advice is to do track prep at least one week in advance. That way we can still have reasonable time to order/deliver/install parts without paying a ton for overnight shipping
08-26-2013, 03:46 PM | #6 |
Rep 1,239
Aluminum tape
First time trackers should tape wheel weights w/ high temperature aluminum tape to prevent it from flying off and having to get it balance later.$$$
2016 Hellrot F80 M3|JRZ RS Pro with Swift Springs 550/750 spring rates l AP Radical 5000R 9668/9449 lSpiegler SS LinesI DS1.11I Eisenmann DP|MPE Catback|18" Forgeline GS1R 18x10 et 22 and 18x11 et 44 NT01 275/35/18 and 305/35/18| Forgeline GTD1 18x10et43 SquarelM Performance Lip/Splitter|IND aesthetic mods|Dinan Toe Link|Fall Line mono ball conversion kit and upper link kit| Aim Solo 2DL Smarty Cam|Simpson Hybrid|Stilo Offshore helmet.
08-26-2013, 03:52 PM | #7 |
Rep 1,711
08-26-2013, 03:53 PM | #8 |
Rep 1,250
Running stock pads hard. I crumbled all four pads in one day at VIR when I had stock brakes, necessitating new pads all round. If you are advanced/brake hard, buy PFC or bbk.
08-26-2013, 04:00 PM | #9 |
Rep 938
Don't save money by waiting to change (stock) pads etc just bc you think there is more life on them. Once you hit 25% left, just toss em out at home and take the time to do them in comfort. It's a hassle at the track, and always winds up being 100+ degrees.
Spend the time to pack, and be organized. It's always the small things that get missed, and make you run around like an idiot. |
08-26-2013, 04:11 PM | #10 | |
Rep 5,506
Auto Detailing Enthusiast!
08-26-2013, 04:14 PM | #11 | |
BimmerPost Supporting Vendor
8211
Rep 18,823
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
08-26-2013, 04:20 PM | #12 |
Apex Everything!
976
Rep 4,378
Would love to know the right way to do it on our cars. Widening the calipers while the caliper is off the car AND with the bleed screw open seems like an increased chance of something going wrong. With my luck the bleeder bottle hose will pop off and I'll have fluid everywhere.
08-26-2013, 04:22 PM | #13 |
Apex Everything!
976
Rep 4,378
My tires rotate around my wheel every time after a track day so it probably doesn't make much difference anyways.
08-26-2013, 04:25 PM | #14 |
Apex Everything!
976
Rep 4,378
So true. I change pads/fluids a week before a track day in case I screw something up. It's also nice to be able to drive on them for a week to be sure nothing will fall off from user error.
08-26-2013, 04:33 PM | #15 |
Rep 7,298
when I change pads, I get to the damn reservoir (why so complicated lol) just to check that it is not overflowing - so far it has been ok on swapping to track pads and back to stock pads.
Waiting on Derple's response to this thread. |
08-26-2013, 04:34 PM | #16 | |
Rep 5,506
Also, the brake fluid needs to be bled afterwards when retracting pistons with the bleeder open to make sure you get out any air that may come in while open. As for spraying fluid.. can't help you with that one!
08-26-2013, 04:39 PM | #17 | ||
Apex Everything!
976
Rep 4,378
08-26-2013, 04:40 PM | #18 |
Apex Everything!
976
Rep 4,378
Yea that's what I do too. I open the cap just to make sure the fluid can rise a bit without building too much pressure. I have no idea if that's necessary or not.
08-26-2013, 05:10 PM | #19 |
Rep 381
Check your tire pressures after every session. Even after they have stabilized it's a good idea just to make sure you don't have a tire going down.
Could save your underwear.
08-26-2013, 05:21 PM | #20 |
Rep 7,298
Figuring that I retracted the piston all the way back the last time and nothing happened, one would think that it should be fine going forward. Didn't check when I went back to stock pads because I was too lazy. When I swap them again this time, I will check again.
08-26-2013, 05:30 PM | #21 | ||
Rep 7,298
Search youtube for 5 minute m3 brake pad swap. |
08-26-2013, 05:31 PM | #22 | |
Rep 7,298
