07-07-2013, 10:06 PM | #1 |
Rep 954
Do these rotors have two more weekends in them?
How many days do these rotors have left? I am running pfc01 pads and am also now moving to nt01 tires which I know will stress my brakes more than my PSS tires did.
Speed wise I've started to move up to the intermediate run group. So I'm far from fast but I'm running faster than I was my first few days. I would love for these to last 4 more days at NJMP Lightning. Any chance? Thanks. |
07-08-2013, 12:39 PM | #6 |
Track? What Track? I was just riding along . . .
46
Rep 694
I attended a talk last weekend at VIR from a speed shop owner. He said rotor cracks are not a problem until they get to the outside edge. The thing is, he also said M3 rotors get cracks in the "sandwich" of the two plates which you can't see. I'm not sure where that leaves us on rotor cracking. It leaves me "nervous."
07-08-2013, 12:42 PM | #7 |
Rep 954
07-08-2013, 04:39 PM | #8 |
collecting toys
41
Rep 810
Turner is a good place to get replacement stock rotors....
2011 e92 M3 Monte Carlo Blue ESS 535 - gone but not forgotten
2015 cayman GTS - new toy 2006 SLK 55 AMG sold |
07-12-2013, 02:52 PM | #9 |
Rep 3,246
Looks to me like you could run a whole season on those. Cracks are almost inevitable, especially on drilled rotors, but if they're not close to the edges, so should be OK. just watch and make sure the cracks aren't going out to the edges and you should be fine. These are brakes, so as always, better safe than sorry.
mods: track ready stuff
07-12-2013, 06:18 PM | #10 |
Rep 8,076
Drives: 11 E90 M3 Individual
No cracks that extend to the edges or connect two holes. If you think your close, don't forget to check the backside of the rotors.
2018 F30 320iX Melbourne Red
07-13-2013, 06:44 AM | #12 | |
Rep 20,741
Drives: 2021 911 turbo
IMO, Those rotors are fine. I have run rotors with way more cracking without issue. I have never had a rotor failure. As others have said, just watch for cracks that connect holes together and especially cracks that reach to the outside edge of the disc (which I have personnaly never seen on my car). You should be good for more than 2 days with these rotors. |
07-21-2013, 10:21 PM | #14 |
Retired Curmudgeon
2985
Rep 4,047
The rule of thumb is that if you can catch your fingernail in a crack, then the rotors are done.
Get PFC direct drive rotors and be done with it.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
07-23-2013, 11:44 PM | #16 |
Rep 1,144
Be prepared to change rotors once a day then.
That is nothing. Last edited by jml; 07-23-2013 at 11:49 PM.. |
08-09-2013, 12:59 AM | #17 | |
Retired Curmudgeon
2985
Rep 4,047
I raced a stock class E36M3 for years. It weighed in at 3175 lbs dry without anyone in the car (that was the minimum weight spec). Add in 180 lbs of a suited up driver, then add fuel and in an enduro it could tip the scales at 3500 lbs. My rotors were simple blanks and when the cracks got bad enough you could catch a fingernail, they went into the scrap pile. Hardly ever got to that point, though when they did, there was still plenty of material left (e.g., above min thickness spec). I have no idea what you are doing to your brakes to get that much cracking. Do you have any cooling duct work? Those are some serious cracks. Silly big, in my opinion. Knock yourself out if you want to run those. Just don't crash into me or take any of my track time while they scrape you off the barrier. 'k?
08-09-2013, 02:14 AM | #18 |
Rep 2,806
Drives: '09 E90 M3 - IB
I have AP Racing rotors. They crack quite a bit with race pads. Stillen is the official distributor of AP Racing. When I sent them pictures like the one below of my rotors, they said it was no problem and to keep running them.
They said keep running them until either the cracks show up at the edge of the rotor, or the rotor width goes below minimum spec width. I kept running them, and they were fine. The rotor width went below minimum spec before any cracks went to the rotor edge. |
08-09-2013, 04:18 PM | #19 | |
Rep 1,144
But in general the OP's rotors are totally fine. |
08-10-2013, 08:12 AM | #20 |
Rep 3,456
Drives: Harrop E90 M3
How is it that people are saying get new stock rotors here? It certainly appears the OP has a bbk. You should be fine for a couple days, just keep an eye on them. Next time you get rotors or rings, switching to slotted will eliminate the possible cracks between holes. I'm not saying slotted don't crack, but in my experience they are more resistant to crack that their drilled counterpart.
08-10-2013, 10:45 AM | #21 | |
Rep 954
If I had known at the time that PFC was coming out with an E46 M3 ZCP upgrade kit I'd have waited, but what's done is done and I do like my stoptechs. |
