BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      07-07-2013, 11:10 AM   #1
HansW
HansW's Avatar
Drives: looking for an E46 M3
2012 BMW E92 M3  [0.00]
Tire pressures for PS2 at the track
Wondering if anyone has run their stick PS2 tires at the track. I am doing a local small track tomorrow in my new car and wondered what kind of experiences some of you have had with the tires at different pressures. Anything would be helpful.
      07-07-2013, 11:54 AM   #2
leo95se
Drives: '09 e92 M3, '15 F15 X5d
i start them around 33-35 and try to keep them under 42 hot. above ~45 they get greasy
      07-07-2013, 02:50 PM   #3
HansW
HansW's Avatar
Thanks. Just what I needed
      07-07-2013, 03:52 PM   #4
SumoJax
SumoJax's Avatar
Drives: 2010 M3 e93
+1
but don't go too hard, my fronts started to "chunk" on me had to replace front driver side under warranty. I use PS2 for street or wet only and run track set of r-compounds now. Have fun, be safe.
2010 M3 E93 AW / 6MT / ESS VT2 600 / Dinan Free Flow Exhaust / Dinan High Flow Middle Racing Exhaust / Dinan Racing Coil-Over Suspension / HRE P40SC / Michelin PSS 255/35/19 295/30/19
      07-07-2013, 04:35 PM   #5
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
What they said. Cold setting Depends on temp for your day but hot 40-42 and you will probably have hard time not rolling over onto the sidewall but adding pressure will make them greasy as stated.
      07-08-2013, 08:55 AM   #6
PrimeBMW
PrimeBMW's Avatar
Drives: E46 M3+S62, E92 M3
check pressures immediately upon returning to the pits. 38-40 hot is better for grip and it keeps you away from the high pressures that make the car harder to control.
      07-08-2013, 09:11 AM   #7
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Prime I suggested a little higher because on street tires it was a real struggle not to roll the tire over and wear the sidewall. I went up to 42 with out them getting greasy byt saved some sidewall. Still wore past tread wear arrows.
      07-08-2013, 02:22 PM   #8
PrimeBMW
PrimeBMW's Avatar
Nitrogen. I was thinking if I had to do it all over again starting with the PS2 that Nitrogen would have/should have saved some tire. That way you could start with higher pressures and not have an enormous delta between cold and hot pressures. (one of the downsides of the PS2 or PSS)
BTW I will start using Nitrogen on the Yokohama race slicks soon for the same reasons.
      07-08-2013, 02:32 PM   #9
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
I'm thinking I may need some also. Rolling the nt01s slightly. Not bad yet.
      07-08-2013, 08:30 PM   #10
SumoJax
SumoJax's Avatar
Drives: 2010 M3 e93
Go with the higher pressures, mine rolled alot and "chucked" as a result. See photos in previous post below:
http://www.m3post.com/forums/showthread.php?t=852545
m3post
