BMW M3 Forum (E90 E92)
Mporium BMW
      07-04-2013, 03:24 PM   #1
jbraslins
Latvian Gangstah
jbraslins's Avatar
84
Drives: 2009 E92 M3 Melbourne Red 6MT
Alignment numbers, now that I got camber plates
Getting camber plates installed on my E90 M3 before my next VIR outing in August.
Now that I'll be able to dial in more camber, what numbers for camber/caster/toe do you all suggest for VIR (or any track for that matter).
Thanks.
P.S. Running Pilot Super Sports with Ohlins R&T / BBS CH-R 19"
[SOLD] 2015 YMB BMW M3 M-DCT
[SOLD] 2010 Alpine White E90 M3 M-DCT
[SOLD] 2002 TiAg E46 M3 manual
      07-04-2013, 03:50 PM   #2
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Are you on stock suspension? I ran -2.5 front and -1.9 rear and needed more with street tire and stock suspension. Couldn't keep the tire from rolling over. I would suggest between 2.5 and 3.0 fron and close to 2 rear. Depends how street unfriendly you want to be.
      07-04-2013, 05:38 PM   #3
surlynkid
surlynkid's Avatar
115
Drives: 2013 E92 M3
I run -1.6 on the street and -2.4 on the track. I have to adjust toe back and forth at the same time. There are 6 flat spots on the tie rod for using an open end wrench for adjustment. I turn them in 2.5 flats when i increase camber and then turn them back out when I am done on the track. I think I can get closer to -3.0 but my wear is pretty even at this point.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
      07-04-2013, 06:29 PM   #4
Longboarder
Longboarder's Avatar
3431
Drives: 2016 BMW i8
Good times.
There's a thread for this:
http://www.m3post.com/forums/showthread.php?t=367003
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S
1979 Porsche 911 Turbo (930)
a couple others
IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w
      07-05-2013, 01:11 PM   #5
LiM3y
LiM3y's Avatar
Drives: 2008 E90 M3
I have -2.5 on the front, max castor at that camber, zero toe (I might add a little next alignment) and factory max -2.0 at the back with 1/32 each side toe in. I got these off the board as a good compromise. So far, running an H&R front sway bar with Eibach springs and Hankook R-S3's 275/35/18 I have had very even wear across with tread for 6 track days (3 @ VIR) (swapping front and rear wheels between days)
      07-05-2013, 02:32 PM   #6
jbraslins
Latvian Gangstah
jbraslins's Avatar
84
Add you going to add a little toe out or toe in upfront?
      07-05-2013, 03:43 PM   #7
LiM3y
LiM3y's Avatar
Drives: 2008 E90 M3
Sorry, toe in to settle the car in day-to-day highway cruising a bit more.
m3post
