04-27-2013, 09:59 PM | #1 |
Rep 157
2008 128i 5 year history
For all of the "normal" 1 Series owners who don't lower/chip/big brake their car here's a short update on a DD 128i: Car is 6MT, only option is a sunroof. Bought the car with 35K miles in 11/2011; car now has 88K miles on 4/2013.
Maintenance performed: Oil changed every 7500 miles- Valvoline Syntech 5W-30 Tires rotated every 7500 miles. CAF changed every 15K miles Air filter changed at 35K and 60K OEM Coolant and OEM brake fluid changed 11/2011 Rear diff fluid changed at 35K and 60 K - Redline 75W-90 MT fluid changed at 40K and 70K - Redline MTl Serpentine belt and spark plugs changed at 60K Front pads /rotors replaced at 87K for the first time. Meyer rotors/Textar pads. All work DIY except serpentine belt/plugs Tires have not be replaced since I bought the car, and probably still have 15-20K tread left. No mechanical issues with the car. Have not performed any suspension alignments or replacements. Total cost for all maintenance - $989. The point of this is the reliability of the car IF you maintain it AND you generally assume BMW engineers know more than yourself you let the car be. My track car is a SpecE30 so I leave all aftermarket parts selections for that purpose. |
04-27-2013, 10:06 PM | #2 |
Rep 57
That's great news, and thanks for posting. My 2009 128i coupe has also been very reliable, although I have been following the recommended maintenance schedule until now.
Good luck, and I expect you will have many more trouble free miles with the maintenance schedule you have been following. |
04-27-2013, 10:09 PM | #4 |
Vrooom :)
315
Rep 2,602
wow your tires last you a longggggg time.
I went through my RFT in 15k
2014 C7 Corvette Stringray - Laguna Blue - NPP Exhaust - Competition Seats
04-28-2013, 12:46 AM | #5 |
AristoCat
41
Rep 676
Is rotating tires a must do maintenance routine? My dealer never did that to my car nor asked me or advised me to do it! Car has almost 100,000 km now, changed tires 30,000 km ago to the new Bridgistone RFTs but no rotation on the new ones either. Should I do that or it's too late?
AristoCat
04-28-2013, 01:19 AM | #6 |
Rep 493
Drives: 2010 135i vert
Great! But...did you enjoy it?
Posted from 1addicts.com App for Android |
04-28-2013, 05:18 AM | #7 |
Rep 129
Nice to know because BMW parts are costly. BUT I have never had a car I didn't mod. I am going to follow Greenkirby21 lead and do the things he did.Well some of them anyway! My BMW is WAY to quiet my taste, to high, and I do not like chrome! RFT are a pain in the ass to say the least. With all that said, it is your ride and thanks for the report.
04-28-2013, 06:16 AM | #8 |
privateer
Rep 73
Curious as to the scheme you used to rotate tires.
Seems to me there are several arguments as to method based on front drive vs. rear drive. |
04-28-2013, 06:31 AM | #9 |
Rep 157
To answer a few of the questions:
1) I suggest rotating the tires. BMW doesn't recommend it. But my tires were on the car when I bought it, I now have 55K on them with tread left. Proof is in the pudding. 2) forgot to mention I always run my tires 2 PSI high. Why? A slightly stiffer sidewall, and I have a margin for normal air loss. 3). Yes, I have enjoyed the car, probably something a 135er doesn't understand . Why? There's a saying on the track: "Straights are for fast cars, turns are for fast drivers." Sure, I can always purchase a car with more horsepower. But there isn't a lot of skill in putting your right foot down. But this car is a well balanced vehicle in stock form, a comfortable cruiser (I drive 150 miles a day), and yet can turn relatively well. Not as well as my SpecE30 but two cars built for two differntly purposes. I know there are many cars that can outperform this vehicle on the test track. But how often (in Atlanta) are you testing the vehicle's limits? Unless you are t-braking before every exit ramp ang hearing the tires sing (or flashing the DTC light) as you go around the cloverleaf, this bottom of the line BMW is all you need, IMHO. |
04-28-2013, 06:37 AM | #11 |
Rep 157
Also forgot to mention the RFTs were not on the car when I purchased it. If they were i would have swapped them for normal tires.
I do not have a spare or a pump. Since I drive the Northeast Corridor and have AAA I think I can survive a flat. Of course all of you know by writing this post my car will either not start tomorrow morning or I will have a flat by Friday. |
04-28-2013, 09:25 AM | #12 |
Rep 63
This is pretty consistent with my experience. I've had 3 E46s and this 128i (Step, Premium & Sport) for the past 2 years. All have been utterly reliable with little or no repairs. This 128i is the best by far - zero repairs. Just routine maintenance and new tires at 19K. Ill probably switch to non-RFT next.
04-28-2013, 10:18 AM | #13 |
Resident Tamed Racing Driver
298
Rep 4,697
My RFT's lasted 5k miles.
I think we have different driving styles.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
04-28-2013, 11:02 AM | #14 |
Слава Украине!
2331
Rep 2,443
04-28-2013, 11:17 AM | #15 |
298
Rep 4,697
Lucky.
I was busy with work and didn't have time to look into who made good wheels for the 128i for quite a bit.
04-28-2013, 01:26 PM | #17 | |
Rep 1,048
04-28-2013, 01:53 PM | #18 | |
Rep 975
Although I am a NA nut I sometimes do not understand the hate between 135i and 1xxi owners. |
04-28-2013, 02:13 PM | #19 | |
298
Rep 4,697
That said, yes the 128i does turn better. Weight the is the enemy of everything in terms of performance, and given equal specs otherwise, the car that weighs 250lbs less will perform better through the turns.
04-28-2013, 02:13 PM | #20 |
Rep 3,323
Your maintenance costs are good because of DIY, but still low. I'd like to see a 5 year 135i maintenance history. My costs have all been paid by warranty, minus tires and extra oil services.
Sparkling Graphite Metallic / 6MT / Terracotta Boston Leather / Sport Package / Comfort Access system / Gray Poplar wood trim / Heated front seats / iPod and USB adapter / HD radio / Premium hi-fi system / OE Tuning / VRSF Intercooler & charge pipe / BMW Performance short shift kit / BMW M Performance Handbrake Handle / BMW Stainless steel pedals / V1 hardwired / rear sun shades Pennsylvania 20 electoral votes
04-28-2013, 05:03 PM | #21 |
Opus Angelus
426
Rep 1,267
04-28-2013, 07:27 PM | #22 | |
Rep 3,070
A question: What about fuel filter, you think it is just OK to keep it as long as everything seems working fine? This is a relatively grey area, so would like to hear what you think about that. I myself think that DI turbo engines should change it more often as well as people who live and drive in places with questionable gas quality.
"The mark of a great car is one whose overall competence exceeds what you should expect from its individual components and the 1M does just that", Chris Harris.
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake. Last edited by ozinaldo; 04-28-2013 at 07:36 PM.. |
