02-18-2013, 11:10 PM | #1 |
Rep 1,177
What a night!!! My car took the worst time to die
10:30pm leaving the gym, 45f degree out there. Got to my car, put the key, press start and boom Christmas time, the whole dash starts to flash, wipers starts to move, ticking sound from glove box and inside light starts to flash and fade away.
Add to that my trunk did not open and i could not get the toe hook out to toe the car, thank God one of the gym trainers showed up and offered to help so i asked if i can borrow the hook from his 1. This is seriously a flow in the design to remove key for the trunk, just in case if you got electrical issues. Does this sound like a battery issue? My car is exactly 3 years and 1 month with 40k miles, if it was battery, which i think will not be covered with the warranty, what will be the $$$ damage? Do you think i can push them to at least pick up the labor cost and whatever that battery programming cost?
Alpine White, Coral RED , Glacier Silver Aluminum trim, M sport, 6MT, NAV, HiFi, USB-iPod, Bluetooth
Performance: JB4|BMW PE|DP Cosmetics: BMW Sport Pedals|Black Kidney Grill Last edited by Ash83; 02-19-2013 at 12:27 PM.. |
02-18-2013, 11:20 PM | #2 |
Rep 654
My trunk has a key, it's really tucked up under there above the license plate...did they do away with that?
Probably is a battery and not likely you'll get them to comp you one. If you get the same battery, it just needs to be registered. If you get a different one it'll need to be coded. Unless you have that ability or can find somebody near you that does, you're kind of at the mercy of the dealer. Good luck
2008 E88--Fuel-It! Stage 4 LPFP & PI--PS2 turbos--JB4/MHD--FBO--662whp/604wtq
2011 E90--Fuel-It! S2BL LPFP and PI--PS2 Turbo--JB4/MHD--FBO--546whp/589wtq 2013 Mini JCW--Tune--DP--FMIC--a couple Fuel-It! goodies--265whp/320wtq 2013 F10--JB4/BM3 2015 F82--Fuel-It! Stage 3 LPFP & PI--PS2 Turbos-- JB4/BM3-FBO |
02-19-2013, 02:29 AM | #4 |
European Editor
10594
Rep 22,992
Sounds like it could be the battery cable recall. I would push the dealer on that.
SUMMARY: BMW is recalling certain model year 2008-2012 1-Series coupes and convertibles manufactured December 2007 through July 2011; Btw... only early 1er's had a mechanical key tucked up under the lic plate light area. After 2009 bmw deleted that lock and went all electronic.
02-19-2013, 03:31 AM | #5 | |
Rep 959
Which is the dumbest idea since the battery is in there and if the car battery dies then it will be a headache to replace it.
02-19-2013, 04:43 AM | #6 |
Rep 1,198
Or if you're doin some modding work and disconnected the battery for safety and then your neighbor comes by and closes your trunk being a Good Samaritan thinking you forgot to shut it. That was te first week I had my car. I had to tind up taking out the rear left speaker cutting away a small bit of the foam to find the trunk emergency release cable. Then I took a razor and shaved away the plastic coating on it just enough to be ble to pull on it to release the trunk. So if my battery ever dies an I need to get in there that's what I'll do. But it's very dumb they did away with the mechanical lock
02-19-2013, 04:54 AM | #7 | |
Rep 959
02-19-2013, 04:57 AM | #8 |
Rep 654
Yeah, I didn't know there was a key on mine until a week ago. I disconnect my battery all the time and was always paranoid so I was jamming a towel in to the lock assembly.
As for the battery cable, I thought those were more of a catostrophic failure with no current flow...sounds like she had some and the lights then watched the lights "fade away". I guess worse case, the cable, it's taken care of by the recall or the fact it's under warranty...battery....not as likely. Let us know how it goes.
02-19-2013, 06:18 AM | #9 | |
Rep 2,438
02-19-2013, 08:33 AM | #10 |
bimmerphile, technogeek
998
Rep 3,784
Drives: 2012 E82 6MT Sport
US cars have a emergency manual trunk release... But it's in the trunk.
02-19-2013, 09:16 AM | #13 |
998
Rep 3,784
02-19-2013, 04:57 PM | #14 | |
Rep 204
I thought about keeping a smaller 12v battery with leads handy just to pop the trunk if the battery dies or somehow this happens again but with all this talk about coding batteries I figure I will just deal with this poor design. |
02-19-2013, 09:05 PM | #15 |
Rep 1,198
02-20-2013, 02:00 PM | #16 |
Loves his G20
265
Rep 2,507
No kidding, how can a company that produces such amazing machines commit such a huge flaw?
2020 330ix-Msport Past- 2013 135i 2011 135i |
02-20-2013, 03:51 PM | #17 |
Rep 1,177
I got my car back and they said it was a dead battery, it was covered under warranty.
How could a battery die in 3 years? I hope my original battery was just bad and it is not a bad alternator that will cause more issues when the warranty runs out. -------------------------------------------------------- Job #1 PROBLEM A TOWED IN, VEHICLE WON'T CRANK 6120505 CHECK BATTERY WITH BATT TESTER (N/C) 6120502 PERFORMED BATTERY ENERGY DIAGNOSIS (N/C) 6120503 CHECKING BATTERY IN CLOSED-CIRCUIT (N/C) 6121517 REPLACING BATTERY (N/C) 1 61-21-7-586-961 BATTERY FROM EXIDE (W (N/C) CORE CHARGE 1 BF EXCISETAX (N/C) 40480 BATTERY DEAD PERFORMED ENERGY DIAG USING ISID FOUND EXHAUSTIVE BATTERY DISCHARGE,30G SHUT DOWN,BATTERY FAULTY,PRO DATE OF WEEK 2009.DIAGCODE D6121 00ENDIAG 902.NUMBER OF TRIPS 5/20KM 76,OK.PERFORMED LOAD TEST USING MIDTRONICS SAID REPLACE BATTERY WC 80C08-NUTEG.R/R BATTERY RESET CLOCK.REGESTERED BATTERY REPLACEMENT IN POWER MODULE -----------------------------------------------------------
Performance: JB4|BMW PE|DP Cosmetics: BMW Sport Pedals|Black Kidney Grill Last edited by Ash83; 02-20-2013 at 04:11 PM.. |
02-21-2013, 01:28 PM | #18 | |
Rep 42
02-21-2013, 07:43 PM | #20 |
Rep 32
of course your tool kit is in the trunk that you cannot open to get to that allen wrench that you need one more reason I love my 6MT
02-21-2013, 07:54 PM | #21 |
Rep 2,926
Dunno about everyone, but my dealer isn't currently doing the recall till they get the OK from BMW NA...
I'll have to take it in when they start in March...
02-21-2013, 08:17 PM | #22 |
Rep 307
They dont even have the official BMW bulletin yet. My car is in the dealer and I asked them to perform the recall but they dont have the reworked parts yet. As you say it will begin in March.
2009 N54 335i Sport
