08-22-2012, 10:16 PM | #1 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
HPA | Burger Motorsport Oil Catch Can 135i N54
Keep Oil Out of your BMW 135i Air Intake System
It's no secret that the BMW N54 motor suffers from serious oil control problems causing oil to blow through and coat the intercooler and charge piping, gunking up intake valves and the VANOS system, lowering the effective octane, and generally degrading engine performance. The higher your boost levels the more apparent these problems become. The solution to this problem has finally arrived. The BMS oil catch can. While there are other catch cans on the market they all fall short in various areas. Some are mounted on the hot/turbo side of the motor preventing proper vapor condensation. Others utilize hoses that are too small and runs that are too long to allow proper PCV ventilation causing internal motor / ring sealing issues. Some have insufficient or no internal baffle system while others have internal baffles systems that are too restrictive for the N54 motor. Most are simply repackaged oil catch cans from smaller / lower power motors shoe horned in to place in the N54 engine bay. To solve these problems BMS designed their oil catch can kit from the ground up specifically for the N54 application. It features 100% CNC machining with zero welding for a precision fit and long life. The hoses exceed the OEM PCV piping in diameter and that flow rate is maintained throughout the entire oil catch can ensuring no excessive crankcase pressure buildup. The mounting location is out of the way under the cowl allowing for shorter lines, more efficient operation, and a very stealthy look. Install takes around 20 minutes, includes all required hardware, and is 100% reversible. Simply unscrew the base of the can to empty it's contents every 3-6 months. BMS Oil Catch Can Features • Increases Air Intake Efficiency • Promotes Engine Longevity • Non-Clogging Air/Oil Separation Double Baffle • Free Flow Solid Design • Large Intake / Exhaust No Tapering Down • Stealth Mounting on Cool Side of the Motor • Anodized Black Lightweight Aluminum • Mounts Out of Sight Under the Cowl • Made in USA Applications • 2008+ E82 Coupe 135i / 1M • 2006+ E90 Sedan 335i / 335xi • 2006+ E91 Touring 335i / 335xi • 2006+ E92 Coupe 335i / 335xi / 335is • 2007+ E93 Convertible 335i / 335xi • 2008-2010 E60 Sedan 535i / 535 xi Replacement BMS Oil Catch Can Bracket Screws Available at most hardware stores: #10-32 x 1/2" Stainless Steel Intro Price: $179 Order here: http://www.hpashop.com/Burger-Motors...tchcan-N54.htm ****not legale for sale in California*** Last edited by HP Autosport; 07-02-2016 at 09:32 PM.. |
08-22-2012, 10:22 PM | #2 |
Rep 293
Will this void the BMW warranty? Any idea?
Cold Weather Pkg / Sport Pkg / Active Steering / Comfort Access / Prem Hi-Fi / Bluetooth / Rear PDC / BMW Perf 313s wrapped with Michelin PSSs / Dunlop Winter Sport 3D (winter) on 17'' Motegis / Blacked Out 135i badge / BMW Performance Grills / BMW Performance Power Kit Stage 1 / BMW Performance Exhaust
08-22-2012, 10:27 PM | #3 |
3847
Rep 54,376
Drives: F80 M3
03-03-2013, 06:40 PM | #5 |
Macaroni
Rep 111
What am I missing on your site? How is there no shipping charge or even feature to check and see how much it should be? I made it to the "place order" button and saw no shipping info...
--Josh--
2011 CTS-V Manual, 542rwhp 2015 Lexus GX460 1965 Mustang Fastback |
03-12-2013, 06:20 PM | #6 | |
3847
Rep 54,376
Drives: F80 M3
Try again... |
07-16-2013, 01:02 PM | #8 | |
3847
Rep 54,376
Drives: F80 M3
You can see the full installation instructions here to get a better idea how and where it is connected: http://burgertuning.com/instructions/occ_install.pdf |
