08-01-2012, 11:28 AM | #1 |
Joint Chiefs of Staff
4918
Rep 115,980
New! H8/h11 Canbus Hid Fog Light Upgrade Kit For Bmw
Now Available for Only - 129.00 http://www.n54tuning.com/index.php?_...&productId=113 Increase visibility with this direct plug & play Canbus HID fog light upgrade kit for BMW. Everything you need to brighten up your fog lights with an error canceling canbus device built in. This kit is specifically designed to be a easy plug and play HID upgrade to your OEM BMW fog lights. No cutting, error codes, bulb out warnings. Just bright HID Light! One kit lights both fog lights. Features: • Bright White Xenon Light vs. Dim Stock Halogen • 4x Brighter Than stock halogen bulbs • Canbus error code canceler built in • Consumes 50% less wattage to run • Plug & Play for Easy Installation / Removal • Designed to work with BMWs sensitive electronics • 100% Water proof and Dust proof • No Error Codes Applications: • BMW Vehicles Equipped with H8/H11 Fog lights Our HID fog light upgrade kit should be used when intense light and/or energy efficiency are desired. HID (High Intensity Discharge) bulbs produce light by means of an electric arc between tungsten electrodes housed inside a transparent fused quartz arc tube. This tube is filled with both xenon gas and metal salts. The gas facilitates the arc's initial strike. Once the arc is started, it heats and evaporates the metal salts forming a plasma, which greatly increases the intensity of light produced by the arc and reduces its power consumption. High-intensity discharge lamps are a type of arc lamp. High-intensity discharge (HID) lamps make more visible light per unit of electric power consumed than fluorescent and incandescent lamps since a greater proportion of their radiation is visible light in contrast to heat. Mike |
08-01-2012, 02:57 PM | #2 |
Rep 439
Drives: 2009 BMW 135i
Any installed pics Mike?
2009 BSM 135i 6MT
08-02-2012, 08:03 AM | #3 |
4918
Rep 115,980
08-20-2012, 10:51 AM | #9 |
4918
Rep 115,980
Here is one with the 8000K version. Will get more soon.
Mike |
07-01-2013, 01:44 AM | #12 | |
Rep 1
08-20-2013, 02:35 PM | #13 |
4918
Rep 115,980
