06-20-2012, 11:43 PM | #1 |
Rep 3,099
So i'm looking at getting the er cf widebody especially since my front bumper is now damaged..
To this effect, some wheels to fill it out are needed.. Then some extra width in the rear.. Basically i'm after: Front: 18*10+20-25 (22/23 precisely) Rear: 18*10 +30-35 (34 from memory) If 10" is too rare/hard or whatever, i'm happy with a 9.5.. And appropriately lowered offsets If you know of a 19 or a 17 (though they wont fit the brakes i want.. And 19's are unneccessarily huge too..) feel free to add that in I'd rather not go custom due to being 1k/wheel too Thanks heaps! |
06-21-2012, 12:16 AM | #2 | |
Old fart
Rep 107
What do you think of this. Front: 18" Rear: 19" I have been thinking that should i order 19" for rear, it can look better.
F48 X1 xdrive25 2020
E53 X5 4.4i V8 2001 |
06-21-2012, 12:29 AM | #3 | ||
Rep 3,099
Body kit is +2.5 inches per corner I'd rather 18" front (to clear 355mm brakes) and rear 17" to put down more power and clear 330mm brakes. That would be PERFECT for me, i like the staggered small rear look too, but the 18's look hot currently too, i'm pretty easy The thing with 19's.. I like minimal clearane between brakes and wheel, 19's would add a full inch :/ |
06-21-2012, 03:18 PM | #4 | |
Rep 25,989
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
06-21-2012, 05:37 PM | #5 | |
Rep 3,099
The reason rear has higher offset.. Well basically i whipped out the tape measure, 1" on the rear (9.5+45>10"+34) is perfectly square track with the front given the current measurements and difference... From talking with the makers, it's pretty precisely measured apparently.. And according to them you can fit a 10.5 up front with some squeezing Another post here has 18*9.5 +30, which i'd be willing to run if a 10" can't be found.. Though thats on a 135 (different track as far asi'm aware), and is a little sunk with no camber at all It's the ER widebody What's the point of doing 18" front and 19" rear? Bigger brakes in the front, smaller in the rear.. Each kg of weight in the wheel is less power to the ground.. It may look okay, but it is STUPID... Actually it looks crap, too much clearance between rear caliper and wheel. Yeah i'll get the kit first and just test with spacers, but i've been searching for wheels for a while now with no luk hence the post |
06-21-2012, 07:42 PM | #6 |
Rep 1,664
Drives: E82 N55 DCT
Just go with a similar setup that ER did with the widebody kit on their car... see below...
Wheels: Forgeline Competition ZX3R with titanium fasteners Front: 18x10 +24 Spacer: none Rear: 18x10 +62 Spacer: none Tires: Front Yokohama Neova AD07 285/30/18 Rear Yokohama Neova AD07 285/30/18 Suspension/Fender Mods/Camber: KW Clubsport - Lowered quite a bit (sorry don't have exact number) KW Upper Camber Plate (included with KW Clubsport) - Camber, secret :wink: Evolution Racewerks Wide Body Front Fender Notes: Front: Will not fit with stock fender Rears: Did not roll the rear quarter panel. Slight rub on inner plastic liner. No rub on fender. If you roll the fender, it might tuck the plastic liner higher and might not rub at all anymore.
06-21-2012, 09:28 PM | #7 |
Rep 3,099
That would be under-square by over an inch on the rear, which would be less balanced.. Stock, 135i hubs have wider track on the rear
I have 9.5 + 45 atm and for the outer edge of the tyre to be square it has to be an inch widened and 10" +20-25 Also, $1000 a wheel is what i'm trying avoid, seeming impossible For that price would be a set of volks or ssr's new or bbs lm's etc. |
