      06-04-2012, 07:28 PM   #1
1speedbike
1speedbike's Avatar
734
Drives: 2022 X4 M40i, 2008 135i
Looking for CF Roundels
Dear Forum Vendors,
As far as I know, there isn't really a good solution in terms of carbon fiber roundels for the 1 series. The hood isn't much of a problem, but last I heard, there are no options for trunk fitment. This may have changed (the last time I was looking for roundels was over a year ago).
So... any vendors have front and back roundels for the E82 in carbon fiber? Either black and white or black and red. Doesn't matter to me.
Please let me know, because I am tired of all the stickers!
Thanks!
Also - sorry if this isn't in the right place. I figured a lot of vendors would see it here and I have seen other members post here with no problems or anything.
2022 X4 M40i - 2008 135i - 2015 F700GS
On Order - 2024 i4 M50
Scruffy's gonna die the way he lived... Mmhm.
      06-04-2012, 07:39 PM   #2
Adam135
Drives: 2014 435i
Also interested in this. I might go monochrome but I'm having trouble finding a full set of those too.
What about these on eBay? http://www.ebay.com/itm/CARBON-FIBER...ht_3643wt_1159
      06-05-2012, 03:54 PM   #3
ken1137
ken1137's Avatar
Drives: BMW S1000XR
2009 e90 335i  [6.40]
I now you are looking for Vendors but I just bought these on Ebay...
http://www.ebay.com/itm/270964889392...84.m1497.l2649
...received today. i can post a pic later if you wish, or maybe you are looking for a better quality Mfg. They dont look bad and should be better than those darn stickers. The hood emblem kept shrinking due to the heat.
BMWCCA member
      06-05-2012, 08:49 PM   #4
Adam135
Drives: 2014 435i
Yes please.
      06-05-2012, 10:04 PM   #5
ken1137
ken1137's Avatar
Drives: BMW S1000XR
Sorry 1speedbike...dont mean to jack the thread
Here is a pic. front and back of the plate and roundel. The roundel has adhesive, but I may add superglue to be safe. Larger one is for the hood and smaller for the trunk.
BMWCCA member
      06-05-2012, 10:11 PM   #6
Adam135
Drives: 2014 435i
Don't use superglue, it eats through paint. Maybe automotive double sided tape would work, if it's not too thick.
Thanks for the pic, they look good. I ended up going with the monochrome roundels from SVC. Still had to order the trunk roundel on eBay since they said its permanently out of stock.
      06-06-2012, 10:44 AM   #7
1speedbike
1speedbike's Avatar
734
Attachment 702736
Not a thread jack at all! I have gotten wheel roundels from ebay before and the quality definitely wasn't OEM... but then again it wasn't bad at all, either. A little dull, but nobody could notice the difference and the CF weave was pretty spot on, like yours.
Can't find a similar listing with both roundels though. I'm getting single trunk and single hood roundels for about $15-20 each, but I guess that's better than nothing. If no vendors chime in that they have this product, I'll go the eBay route.
And... dear vendors... if you have roundels that fit:
      06-06-2012, 12:01 PM   #8
New21er
Drives: 2011 135i
You can use the E90 trunk roundel. You will have to cut the pins off and then use 3M double back tape to hold it on. Worked for me.
      06-06-2012, 08:27 PM   #9
Adam135
Drives: 2014 435i
Is this the right emblem for the trunk? http://www.ebay.com/itm/160674385776...ht_3316wt_1159
      06-06-2012, 08:45 PM   #10
New21er
Drives: 2011 135i
Hard to tell, without a side shot. But what the hell for $10.00 try it.
      06-06-2012, 08:59 PM   #11
1speedbike
1speedbike's Avatar
734
Yeah it's hard to tell. 73mm certainly seems right, but from what I remember our trunks have a weird concavity to them where the roundel goes so it's weird. I could also be wrong, I just know the trunk roundel is a PITA.
      06-07-2012, 11:19 AM   #12
New21er
Drives: 2011 135i
The E90 roundel has the same "concavity" as ours have, just the pins are different.
      06-28-2012, 10:49 PM   #13
Greenkirby21
Vrooom :)
Greenkirby21's Avatar
Drives: C7 Stringray
Anyone find a rear CF roundel?
I found this
http://www.ebay.com/itm/2PCS-REAL-Ca...ht_3236wt_1073
I don't want to use stickers x[
2014 C7 Corvette Stringray - Laguna Blue - NPP Exhaust - Competition Seats
      06-28-2012, 11:11 PM   #14
ken1137
ken1137's Avatar
Drives: BMW S1000XR
The trunk roundel fits but does not have the same shape (concavity as Speedbike said). I used thick 3M dbl sided tape and black caulk to fill the gap. Doesnt look bad but there was no other option.
BMWCCA member
      06-29-2012, 08:48 AM   #15
1speedbike
1speedbike's Avatar
734
I found this
Yep, I ended up buying something similar, except my kit had a stick on steering wheel roundel too. The steering wheel roundel is actually part of the air bag cover, so you can't take it out. I just stuck it on.
The prongs on the trunk roundel in the kit that I got were in a slightly different location than they should have been. I ended up cutting them off and using layers of 3M tape to fix the concavity issue. Still have a bit of gap in some areas, but not noticeable until you look close. And as for the hood, I have a CF hood so no holes for prongs, so I ended up cutting the prongs off the hood emblem too and just taping it on. Hood looks fine.
I just wish there was a better way...
Tags
carbon, e82, fiber, roundels
1addicts
