01-06-2012, 02:04 PM | #1 |
Supreme Allied Commander
3885
Rep 54,494
Drives: F80 M3
>>HP Autosport<< Light weight Braille racing battery custom mounting kit
Enjoy up to 40lb weight reduction over the BMW OEM battery by using the HP Autowerks lightweight aluminum battery tray and Braille lightweight racing battery. Yes, you don't need to spend $6K on an Akrapovic exhaust for the same weight savings! Plus the battery mounts above and away from the center of gravity of the vehicle making it even more important to take weight away at those locations. The tray accomodates three different Braille battery sizes. Please choose which battery you would like inlcuded with your HPA battery tray from the options below.
Mounting tray is $269.95 when purchased with a Braille lightweight racing battery. Specs 15 lb Casing: Polymer plastic Weight: 15 lbs. Length: 6.8" Width: 3.4" Height: 6.1" Pulse Cranking Amps: 1,067 Cranking Amps: 574 Cold Cranking Amps: 425 Amp Hour Rating: 21 Warranty: 1-year free replacement Price: $209.99 Specs 21 lb Casing: Polymer plastic Weight: 21 lbs. Length: 6.6" Width: 5.2" Height: 6.8" Pulse Cranking Amps: 1,380 Cranking Amps: 742 Cold Cranking Amps: 550 Amp Hour Rating: 31 Warranty: 1-year free replacement Price: $241.49 Fiberglass reinforced plastic (FRP) All Braille batteries feature an industry leading energy-to-weight ratio accomplished via Enhanced Mat Technology (for more surface area on the lead plates) combined with calcium full frame power path grids (for increased cranking power). Durability is also built into every Braille battery. Using high-density oxide, Braille batteries offer true deep-cycling ability over the life of the battery. Heavy-duty vibration resistant power posts resist cracking and deterioration common to many lightweight batteries used in harsh automotive environments. The battery is a sealed unit that can be mounted in any position safely using its adjustable automotive terminal posts. Braille batteries include a one-year free replacement limited warranty that is not pro-rated. This same battery is installed in the Berk Technology's Redline Time Attack Race Car, our Red Line Time Attack 335i and our project 135i and 1M. http://www.1addicts.com/forums/showthread.php?t=259353 http://www.1addicts.com/forums/showt...t=project+135i Order here: https://www.hpashop.com/HPA-Battery-...?categoryId=-1 Note: We recommend a minimum of 21 lb battery for E8x 1-series. Some vehicles may require "Battery Replacement Registration" for the charging system to properly charge the battery. ***ONLY 21 lb hold-down's and trays are available at this time*** Last edited by HP Autosport; 05-23-2022 at 05:05 PM.. |
03-20-2012, 05:33 PM | #4 |
3885
Rep 54,494
Drives: F80 M3
02-21-2013, 10:15 AM | #6 |
Rep 277
Do these light weight batteries last as long as OEM (regular) batteries?
In short, is there any catch to switching my 135 (or even 325) to this lightweight battery? Any negatives? |
02-21-2013, 10:26 AM | #7 |
Resident Tamed Racing Driver
298
Rep 4,697
Generally reduced capacity and CCA. If you have any parasitic loss it can strand you very quickly.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
02-21-2013, 12:13 PM | #8 | |
3885
Rep 54,494
Drives: F80 M3
I have done a personal test on a 2011 135i by letting the radio run for a couple of hours, no issues there. Park the car for over 2 weeks, it started right up. |
06-19-2014, 07:16 PM | #10 |
California-bound
385
Rep 1,480
Would the vehicle not need to be recoded for the 21lb battery, is that why you recommend that one in particular?
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 |
06-19-2014, 07:50 PM | #11 |
Rep 1,054
I've been wondering this also. Would one not have to code the battery for a lower CCA(1380)/CA(550) over the standard battery?
06-19-2014, 08:25 PM | #12 | |
Rep 4,531
Now the question is...does the E82 had a map to CORRECTLY charge and float this battery without basically destroying it? |
06-20-2014, 12:58 PM | #13 | |
3885
Rep 54,494
Drives: F80 M3
We have both the 15 and 21 lb. batteries in stock. |
06-20-2014, 07:45 PM | #14 | |
Rep 4,531
Ideally, I would like to try and run a 15 lb battery during the summer and swap out to OEM during fall/winter and non-autox seasons |
06-23-2014, 04:04 PM | #15 |
3885
Rep 54,494
Drives: F80 M3
You may under or over charge the Braille so we still recommend you performing a new battery registration.
07-12-2014, 06:58 PM | #16 |
Rep 1,436
Is there anything available for F30 ?! If so does it need to be registered too and can it be done through coding ?!
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
07-15-2014, 02:20 PM | #17 | |
3885
Rep 54,494
Drives: F80 M3
Yes, registration is highly recommended. |
07-15-2014, 05:12 PM | #18 |
Rep 1,436
How is the registration be done ? and how long safe can I drive without registration ?
07-15-2014, 05:24 PM | #19 |
3885
Rep 54,494
Drives: F80 M3
