01-05-2012, 05:35 PM | #1 |
Supreme Allied Commander
3843
Rep 54,364
Drives: F80 M3
>>HP Autosport<< AR Design 1M Catless Downpipes
We are extremely excited to present AR's 1M 3" Hi-Flo catless downpipes! The only TRUE 3" downpipes currently on the market! In addition to an intoxicating and exotic sound, these downpipes add significant power and virtually eliminate turbo lag, making the fabled N54 engine even more responsive!
Our Hi-Flo 3" Catless Downpipes Feature: * The only TRUE 3" catless downpipes currently on the market! 3" tubing until cat-back flange - all systems currently on the market reduce to 2.5" much closer to the turbocharger. * 100% Hand Crafted in the USA - not China - from premium 304 stainless steel - flanges and O2 bungs included! * Water-jet cut 304 Stainless cat-back flanges, and CNC'd 304 Stainless V-Band flanges. * 100% TIG welded, argon back-purged. * Set of our exclusive bomb-proof exhaust gaskets included. * Grade 10.9 Metric Hardware(145,000PSI tensile strength, C32-C39 Rockwell, Zinc Plated), and Nord-Lock positive locking re-usable washers included. * Factory location O2 bungs * Available with a 2000�° F ceramic coating. Coatings come with a 3 year warranty against corrosion and rust to original owner. * Lifetime warranty against any manufacturing defects given to original owner. * We do NOT grind/polish our welds as some other manufacturers do. Grinding welds compromises the strength of the weld, and can lead to weld failure - especially critical in applications exposed to temperatures in excess of 1200°F. Such temperatures will also rapidly deteriorate the polished finish. $836.07 +$159 for ceramic coating Order here: http://www.hpashop.com/AR-Design-3-1...-N54-DP-1M.htm ***Ceramic coated DP's are in stock, there is no lead time*** Last edited by HP Autosport; 01-03-2017 at 03:57 PM.. |
05-31-2012, 11:02 PM | #5 |
Rep 3,070
Guys, there are a lot of people like me who are hesitant about the catless downpipes despite the fact that they should be giving best power gains, sound and especially response compared to other sections. This is not only because they will give you codes that need to erased, related warranty issue etc. but also they may give us other headaches (gas smell maybe?). But the biggest hesitance comes from the mid pipe option; I think lots of 1M owners think about an upgrade to a better exhaust but then ask themselves if a full system with aftermarket dps would be too much (too much install work, code trouble, smell, loudness etc.). So the question I am asking is does it really worth the trouble or a good rear muffler plus catless mids would be close enough in terms of response, feel, sound and power. Especially in comparison to dp + muffler set up like Evolve offers? In short, what is the way to go with optimum result and minimum trouble and why? Catless dp + oem mids + new muffler or oem dps + catless mids + new muffler. Or yet another option: catless dps + catless mids but oem muffler? Can people with first hand experience share their thoughts about this?
06-05-2012, 09:36 PM | #6 |
Rep 562
Drives: 2011 1M VO
I am interested in this problem too, and have thought that most of the restriction is in the DP and then MP, not so much aft of the mid pipe. So figured most effective for power and some reasonable noise would be to keep stock "muffler" and get rid of both cats, tho assumes a tune to take care of CEL and to access the increased potential power. Anyone tried this approach?
06-05-2012, 10:43 PM | #7 | |
3843
Rep 54,364
Drives: F80 M3
If the ultimate power is not your goal, stock DP's with intake, FMIC, cat back exhaust and stage 1 tune may be good enough for you. |
06-06-2012, 09:08 AM | #8 | |
Rep 3,070
I really think that this AR dps + Maddad pipes with stock muffler could sound like hell plus give optimum gains in hp/torque/response. Anything else that needed to be taken into account about dps? Gas smell maybe? |
06-06-2012, 09:15 AM | #9 | |
Rep 3,070
Let's see. |
06-06-2012, 09:18 AM | #10 |
aiming for 450.....
303
Rep 2,910
I don't own a 1M, but am running catless Dp's, N55 mids and a Berk tech. Street Exhaust. Power gains were noticable and did not have the "gas smell" whatsoever. One thing I did do was install the BMS o2 Sims to avoid the codes related to the catless downpipes.
My maintenance is done by an "independent" shop here in Germany so I really don't worry on code issues. I also have a BT tool so I can scan and see if I have any issues.
Quote from Ezeedee regarding car mods:
"you're only done when you sell the car " |
06-06-2012, 09:22 AM | #11 | |
Rep 3,070
