      11-29-2011, 11:10 PM   #1
ZCP M3
Drives: 2011 VO 1M Coupe #759
Anyone tried replica CSL 18's on the 1M?
So I'm still trying to find a suitable (and more importantly cheap) dedicated winter wheel for my new 1M. I came across these CSL replicas at **********s and according to my wheel offset calculator, here's what I've come up with...
Fronts: 18x8 ET35, gain 9mm inside clearance, lose 17mm on outside stance
Rears: 18x9 ET20, gain 18mm inside clearance, lose 8mm on outside stance
Seeing as these are $165/wheel, I can get a full set with new TPMS installed for $1010, about half the cost of the OEM 18x8 ET20 wheels without TPMS.
Anyone tried these on a E92 M3 or 1M? Do they clear the massive front calipers?
      11-29-2011, 11:18 PM   #2
mrow
Drives: AW 1M
Do they have to be ordered staggered? Since they are only for winter use I would order a square setup and maybe some small spacers if you're worried about the stance. This way you can rotate them so they'll last you longer since you only need them for winter.
1addicts
