      09-28-2011, 11:09 PM   #1
blueshark
Drives: "transportation" for now
1M supercharger?
Could a supercharger be paired with the existing turbocharging units?
      09-29-2011, 01:29 AM   #2
Daniel135i
Italy
52
Drives: 2011 135i 6M, AW, CR, MSPORT
2011 135i  [10.00]
2005 SRT-4  [7.00]
Anything is possible with the right money thrown at it.
      09-29-2011, 01:46 AM   #3
DooBs
DooBs's Avatar
Drives: 1 Series M Coupe 697/740
do it
      09-29-2011, 01:55 AM   #4
M3 Adjuster
Albania
7906
Drives: 1M, X1 M Sport, E46 325ic
Why? Sorry...I'm not incredibly versed on turbo cars.. but wouldn't it be easier to...
1- swap to larger turbos
2- larger front mounted intercooler (FMIC)
3- dial up the boost
4- tune
I don't understand why one would put a supercharger on a car with turbos... sorry..
      09-29-2011, 02:28 AM   #5
Fundahl
Drives: VO 1M, 300zx TT
4- tune
There have been twin-charged cars, mainly race vehicles. The benefit is the ability to run a large turbo with a high flow rate but without the lag.
You can do it properly with a positive displacement blower that has a clutch to disengage the pulley when the appropriate turbo rpm is reached.
      09-29-2011, 04:23 AM   #6
carchrism5
carchrism5's Avatar
Drives: M2, X3 M40i, 911
Buy a different car. Not worth the trouble.
      09-29-2011, 04:26 AM   #7
Pete_vB
Pete_vB's Avatar
Drives: '69 GT3, GT4, 1M, 912
True. But it's non-trivial (understatement) to do well.
As you say, it's generally used to reduce lag, such as:
http://www.greencarcongress.com/2005..._vws_new_.html
But the 1M already has small turbos and not much lag, so it's be a lot of complexity and weight for little gain (which is probably why BMW didn't do it).
Now if you swapped the turbos for larger ones then it might be worthwhile to reduce the lag, but the OP suggested leaving the turbos stock...
Could it be done? Probably yes. Should it be done? Probably no...
1M, GT4, 1969 Porsche 911 w/ 997 GT3 Cup Motor (435hp & 2,100 lbs)
      09-29-2011, 08:31 AM   #8
Dan Parker
Drives: 2012 Golf R
Jay Leno or Richard Branson would do it....
Dan Parker
      09-29-2011, 08:46 AM   #9
robertm
Drives: 2020 M2 Comp
Bill F-ing Murray would do it too!
      09-29-2011, 08:47 AM   #10
wabbit
wabbit!
wabbit's Avatar
Mexico
41
Drives: ///1M
i agree not worth the trouble!! buy something else...
      09-29-2011, 08:53 AM   #11
pearlwhites
pearlwhites's Avatar
Drives: 1M, 06 CTT, 07 A8L
That's because he is awesome
      09-29-2011, 09:16 AM   #12
ZCP M3
Drives: 2011 VO 1M Coupe #759
Don't make it more complex than it already is.
      09-29-2011, 12:03 PM   #13
biggles
Drives: M3/1M (ordered)
The current 1.4TSI engine in Vw golf/scirocco is turbo
      09-29-2011, 12:03 PM   #14
biggles
[QUOTE=biggles;10515758]The current 1.4TSI engine in Vw golf/scirocco is turbo and supercharged!
      09-29-2011, 12:46 PM   #15
v1k0d3n
v1k0d3n's Avatar
Drives: M2C /// (and x3 for the wife)
hahaha!!!
Just throw one of these bitches in there and call it a day.
      09-29-2011, 01:06 PM   #16
James T. Kirk
Captain of the Enterprise
James T. Kirk's Avatar
Drives: 2011 1 Series M Coupe
I'd switch out the turbos for a pair of warp nacelles.
2011 1 Series M Coupe VO M3 vs 1M Comparo Review
2011 M3 E90 DCT ZCP (sold) * 2010 335i Sedan (sold)
2005 M3 Convertible (sold) * 2003 325i Sedan (sold)
      09-29-2011, 01:23 PM   #17
Dee Pee
Dee Pee's Avatar
176
Drives: '11 AW 1M, ‘24 718 GTS
You just made my day buddy. I'm a huge Star Trek fan. I was comparing the 1M to the USS Defiant from DS9 with one of my fellow nerdlings. He got the joke.
      09-29-2011, 01:31 PM   #18
strati1
supercharger vs twin turbos and supercharger
just watch it it explains why twin charging needs to be done to the 1m
//Mods: Golf Tee, red out tails, smoked fogs, B&G S2 Springs, Adjustable Koni Yellows, Vorshlag Camberplates, PSS 225 square, Macht Schnell 90mm studs, H&R spacers 15mm front 20mm rear (no rubbing), RPI scoops, K&N
      09-29-2011, 01:34 PM   #19
MusclezMarinara
Drives: VALNCYA
S 63 Ftmfw !
      09-29-2011, 01:35 PM   #20
ZCP M3
No it demonstrates what happens when you don't right-size your turbochargers and can't run a sequential setup.
The other thing it demonstrates is that both cars are limited by traction and comparing four-figure HP cars to 1Ms and VWs is irrelevant.
EDIT: Let's also overlook the fact the Ford GT has an extra FIVE HUNDRED horsepower. Yeah, lets chalk all the advantages up to twincharging.
      09-29-2011, 01:44 PM   #21
strati1
It demonstrates the basic assertion that twin charging has potential
      09-29-2011, 01:46 PM   #22
Fundahl
Lol
I never said it would be practical or worthwile in my opinion, just letting it be known it can be done and has benefits.
If you have to ask you are probably better off paying someone else to design your twin-charged N54.
1addicts
