      08-30-2011, 09:18 PM   #1
zayzay
Drives: bmw 1M
AFE Air intake system
Does anyone own an AFE air intake system for their 1M and if so, which one do you recommend to purchase from AFE power? Also, if you do own one, do you feel any substantial gains in horsepower and torque?
      08-30-2011, 09:21 PM   #2
mikewills
Drives: Ducati Hypermotard
2008 Duc 848  [0.00]
I belive Dan Parker has it...the one with the two conical filters.
      08-30-2011, 09:26 PM   #3
zayzay
Drives: bmw 1M
do you have a part number?
      08-30-2011, 09:37 PM   #4
mikewills
2008 Duc 848  [0.00]
I believe it's this one, but please don't quote me. They also sell the intake scoops. Just run up your post count to 5, then PM Dan Parker.
http://www.**********s.com/AFE-Dual-...-335i-535i.htm
      08-30-2011, 09:42 PM   #5
Fundahl
Drives: VO 1M, 300zx TT
Do a Dual Cone Intake or copy "Mr. 5 Intake".
No need for this.
      08-30-2011, 10:59 PM   #6
Dan Parker
Drives: 2012 Golf R
http://store.bimmerworld.com/135-c80.aspx
The dual afe filter is about 3/4 down this page. I did the scoops as well. They have to ram a lot of fresh air into the filters. You can hear the turbos quite a bit more and the quality is top notch. I haven't dyno'd the car with them on so I'm not sure if it makes power but looking at the design I suspect it is an improvement.
Dan Parker
      08-31-2011, 01:54 PM   #7
zayzay
Drives: bmw 1M
I just purchase the afe cold air intake system. do you actually feel a horsepower gain when driving the car compared to stock?
      08-31-2011, 03:13 PM   #8
HP Autosport
Supreme Allied Commander
Drives: F80 M3
You do notice it a little bit power wise but it really makes a difference with a tune and other power modifications as the N54 bottle necks at the intake. It also has more induction noise. We sell aFe products as well. Also, if you are in that area you might as well replace the charge pipe before it pops off. The OEM plastic piece is pretty poor.
http://hpashop.com/category.sc?categoryId=268
-Tyler
      08-31-2011, 03:43 PM   #9
fastauto
fastauto's Avatar
Drives: AW 1M Coupe
whats everyones view on which is better? single larger filter or dual cone setup?
      08-31-2011, 03:56 PM   #10
Fundahl
Dual cone has the most surface area and therefore the least pressure drop across the filter.
      08-31-2011, 04:13 PM   #11
robertm
Drives: 2020 M2 Comp
-Tyler
Curious what do you think about potential for heat soak with this setup? It looks like the AFE setup you're selling covers the top of the filter which seems to be a better design than the open top version some others are selling. The open top version has two filters vs one though. Care to discuss the adv/dis adv of the two setups?
Also, which of the two intake scoops do you find to work better with the complete AFE setup?
      08-31-2011, 04:17 PM   #12
mPlasticDesign
mPlasticDesign's Avatar
684
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Question
I was considering this, anyone else?
But without the long dual intake tubing like this:
      08-31-2011, 04:59 PM   #13
SV Concepts II
SV Concepts II's Avatar
Drives: E90 M3
Location: 1460 White Oaks Rd. Suite F Campbell, CA 95008
aFe makes great intake systems. I would be curious to see how much power this dual cone system added. Thanks for sharing.
      08-31-2011, 05:17 PM   #14
zayzay
Drives: bmw 1M
just purchasing the AFE system, i am also curious to see if their is a difference in the feel of the car compared to stock without any other modifications.
      08-31-2011, 05:40 PM   #15
Dan Parker
Drives: 2012 Golf R
The car is very fast stock so it's hard to feel the gains a CAI may make. The afe CAI I used has seals at the top edges and appear to press against the hood nicely. With this design I don't see the need for the cap.
Dan Parker
      08-31-2011, 07:13 PM   #16
Fundahl
Do you know how filters work? I can pull up Mr. 5's logs of reduced waste-gate duty cycle with DCI and his custom one when I'm on a real computer. (On phone now)
I will say, pressure drop increases as you increase your turbo rpm. This is why the stock airbox was designed for a set volume and becomes restrictive at higher boost levels, where a higher volume setup (such as DCI) really shines.
      08-31-2011, 07:53 PM   #17
mikewills
2008 Duc 848  [0.00]
Originally Posted by Motion View Post
Wow! Why such a price spread? $499 from Bimmerworld and only $376.95 from HP Autowerks!
http://www.hpashop.com/product.sc?pr...categoryId=263
That really confirms my believe not to rely on information posted here by others. Do you own research first!
Actually, bimmerworld is $347.99 and HPA is $376.95.
      09-01-2011, 10:05 AM   #18
Red135
La Flama Blanca
Red135's Avatar
27
Drives: 1-series
I see it now, why would there be a difference in price between the 135i and 335i? It's the same kit. If it were a price mistake, people better jump one it now!
The kit for the 335 includes the intake tubes.
AMS, Berk Technology, aFe, ER
      09-01-2011, 10:16 AM   #19
TunedM2C
TunedM2C's Avatar
Drives: 2016 LBB M2
I think this is the best option available but the price could be better.
      09-01-2011, 12:34 PM   #20
Spammer99
Drives: BSM 1M
I have just gone through the 2k break-in period with my 1M this morning and have been running a AFE p/n 54 82002 sealed CAI w/ the scoops since about the 1,000km mark... While I have yet to take it to redline (5,500 is as far as I have gone), I have jumped on it a bit, and it appears to have equal power, with better throttle response. I picked up a little bit more intake sound (turbo spool) but nothing that would be deemed annoying. Since CAI's deliver most of their increased power at the top end, I probably haven't revved it high enough to experience any gains.... It is going into BMW tomorrow to get it's break-in service completed (engine oil and rear end oil change), so after leaving there I will be sure to experience the top end of what this motor can produce.
      09-01-2011, 02:27 PM   #21
Papethova
Drives: '08 135/ '11 1M
I think , THINK, I had read back in the early 135 days that there was no difference between these closed intakes versus plain dual cone intakes
      09-04-2011, 08:49 AM   #22
Wichard20
Drives: BMW M3CS
did the scoops install no problem? I remember reading on the 135i forums users had problems with clearance/install of the scoops but that was a long time ago
1addicts
