      07-11-2011, 11:38 AM   #1
biglare
Bulldog
biglare's Avatar
Drives: BMW & Porsche
Post 1M ESS Tuning 410hp with Dyno Graphs
BIMMERPOST
     Featured on BIMMERPOST.com
ESS 1M Tune: http://www.esstuning.com/products/ES...-Software.html
Official specs:
DirectFlash Stage 1 :
Top Speed Governor: Removed
RPM Limit: 7200RPM
Fuel requirement: 91US
Horsepower: 400 DIN (Stock 335) - 390DIN if used with stock intercooler
Torque: 550NM
Normal whp range on DynoJet: 345-365whp
After over a week of running the ESS Tuning Stage 1 tune on the 1M I was finally able to schedule a dyno session on a DynoJet in SD. I was able to measure both the stock hp/tq as well as the Stage 1 tune hp/tq.
I was very impressed with the stock numbers and could definitely feel the tune and the dyno graphs confirm my thoughts. The car feels very linear as it pulls to redline and flattens out right at the end.
Based on using the standard 15-18% drivetrain loss the car stock is making about 370 HP and the stage 1 tune is making about 410 HP.
I am told that the 1M Stage 2 tune from ESS Tuning is in the works right now. I cannot wait to get my hands on the Stage 2 tune!
I've been busy today fellas, but here is the graph to show STD, smoothing 5 and AFR's.
The weather station at the dyno was showing 91 deg F on the stock run and 100 deg F for the tuned run. The dyno is located in Santee which is approx. 20 miles inland of SD coast.
Enjoy!
Edit by admin with current photos of car:
Prev: Individual F80 M3 - Fjord Blue/Silverstone(interior) | Fashion Grey(exterior)
GTS
      07-11-2011, 11:47 AM   #2
DiavelM3
4 Star General -Twilight Zone
DiavelM3's Avatar
Drives: '11 E92 M3 ZCP
Very Impressive numbers!
'12 Ducati Diavel
'06 E46 M3 (sold) | '97 325is - Dinan (sold)
'02 Z3 3.0 coupe (sold)
Past - '84 Ferrari 308 GTSI | '88 Ferrari 328 GTS | '05 Dodge Viper Copperhead Edition #180/300 | Audi S4
      07-11-2011, 11:54 AM   #3
flipm3
E46 + E90 + F80
192
Drives: E46 + E90 + F80
2009 BMW M3  [0.00]
2002 BMW M3  [0.00]
Great results!!! Thanks for sharing! It looks like ESS did a pretty job tuning your car. Very impressive.
It still amazing me how much power these little car make not just with a tune, but even stock!!
I don't mean to be nit picky or too critical, but I'm curious to hear your impression on the top end power. It looks like the ESS tune has some fall off on power around 5500-6000. Granted I'm sure in a real-life situation, it's probably not that noticeable.
Awesome job ESS Tuning. Enjoy the car biglare...it must be great to have ESSVT2-600 and tuned 1M
F80 M3 DCT|Alpine White . Black Leather | My Build Thread
E90 M3 DCT|Melbourne Red . Speed Cloth | My Build Thread
E46 M3 6MT|Jet Black . Black Nappa Leather | My Build Thread
      07-11-2011, 12:18 PM   #4
carchrism5
carchrism5's Avatar
Drives: M2, X3 M40i, 911
Looks good, I spoke to Roman about this tune and as soon as my break in is done I'll be going with the ESS tune
EDIT: what were the conditions of this run? I'd also be curious to see this on a Mustang Dyno
      07-11-2011, 12:25 PM   #5
M3 Adjuster
Albania
7906
Drives: 1M, X1 M Sport, E46 325ic
Definitely nice to see another dyno run. gotta love it when the HP at the wheels is darn near the rated hp at the flywheel..
      07-11-2011, 12:30 PM   #6
JHOOPS2
AKA HISSMAN
JHOOPS2's Avatar
Drives: 2009 SG 135i Coupe'
Welcome to the world of the N54.
      07-11-2011, 12:34 PM   #7
JHOOPS2
AKA HISSMAN
JHOOPS2's Avatar
Multiply the numbers by 1.15 for 15% gain value. ~ 363 hp stock and 400 hp with stage 1 @ the crank "estimated". My 135i did 347hp to the wheels with the JB3 Map 2 only, for reference ~12-13psi iirc.
Also, do they have a version of the map with smoothing set to 5? That will take out a lot of inaccurate variable fluctuation and give you a more precise, or as precise as you can get number. Also set it to STD instead of SAE due to it being a turbo car. Yeah, I own a dynojet.
      07-11-2011, 12:34 PM   #8
TunedM2C
TunedM2C's Avatar
Drives: 2016 LBB M2
I'm guessing pricing will be close to the 335i variant? Around $900?
      07-11-2011, 12:38 PM   #9
MrRoboto
Drives: VO 1M
400-15%=340
      07-11-2011, 12:40 PM   #10
Dan Parker
Drives: 2012 Golf R
Am I reading this wrong?
350 hp / 400 ft lbs @ the wheels with tune?
It's hard to read on my phone.
Dan Parker
      07-11-2011, 12:45 PM   #11
JHOOPS2
AKA HISSMAN
JHOOPS2's Avatar
Originally Posted by MrRoboto View Post
400-15%=340
Common confusion. My experience is that the dynojet is only on average seeing a loss of about 13% loss from the flywheel. However, we don't have flywheel numbers. What we do have is rear wheel numbers where multiplying the number by 1.15 will get you the more accurate number. That is where the 15% that everyone uses comes from. Then somewhere it always gets lost in translation and everyone starts using reverse math to try and figure out how much power they would have to make at the crank in order to get the rw# with 15% loss.
      07-11-2011, 12:46 PM   #12
carchrism5
carchrism5's Avatar
That math isn't correct, when there is a drivetrain loss, the number at the wheels is the portion of that (say 85% in this case). By adding back 15% you are getting a skewed number, the proper way is to divide by 0.85 and find out what the number is at the crank.
example: 400bhp car with 15% drivetrain loss would put down 340 on the dyno (400*85%), if you had the 340 on the dyno and added back 15% you would get 391 which is different.
      07-11-2011, 12:46 PM   #13
JHOOPS2
AKA HISSMAN
JHOOPS2's Avatar
It appears so. Numbers are SAE and smoothing is set to 3 though. Hard to compare with other cars on the board. That being said, the numbers could be higher, or lower.
      07-11-2011, 12:51 PM   #14
JHOOPS2
AKA HISSMAN
JHOOPS2's Avatar
A lot of assumption there. What if the 400hp car makes 348 on the dyno...as many do on my dynojet. These are the numbers that I have found best work.
      07-11-2011, 12:56 PM   #15
JHOOPS2
AKA HISSMAN
JHOOPS2's Avatar
Quick example.
Completely stock my 135i makes 275hp and 301tq @ STD smoothing set to 5.
Now, if I divide that number by .85 then I am making 323hp at the crank bone stock on a 88* day.
If I multiply 275 by 1.15 I get 316.25. What is more believable with a stock 135i?
It's fuzzy math either way, but I have found my way to be much more accurate over the years.
      07-11-2011, 01:39 PM   #16
carchrism5
carchrism5's Avatar
^ I know it varies from car to car in terms of what you are talking about, but I was referring to raw math. If you give a number and then assume a 15% loss that is the correct calculation, dividing by .85 that is the only way to do it. I agree it is fuzzy math because you can never get ideal numbers, I was simply stating that you cannot add back 15% and say that is the corrected number for 15% loss.
There are too many variables involved and I am personally most interested in the difference between numbers from stock to mods because as we all know dyno graphs are like finance, you can skew them anyway you want to make it seem the way you want.
      07-11-2011, 01:44 PM   #17
JHOOPS2
AKA HISSMAN
JHOOPS2's Avatar
All true.
      07-11-2011, 02:10 PM   #18
carchrism5
carchrism5's Avatar
IIRC the tune is $995 btw. ESS said they would be adding it to their web shop in a little.
      07-11-2011, 02:19 PM   #19
cracka
cracka's Avatar
Drives: VO 1M
Time to update my Christmas list!
      07-11-2011, 02:41 PM   #20
Dan Parker
Drives: 2012 Golf R
Is this a flash type tune?
Dan Parker
      07-11-2011, 02:44 PM   #21
Gtrain
Taiwan
144
Drives: something slowwwww
yes it is.
      07-11-2011, 03:19 PM   #22
Mountie
Drives: 135i
The only way to accurately do this is to have both crank and whp numbers. My 135i, for example, dynoed 267. Take 300 crank divided by 267 whp and myestimated drive-train loss is around 12%. Use that number as your baseline for any modifications in calculating crank hp. So, if I add a tune and turn out 340whp, then my crank would be 382. At this point all 3 variables have been accounted for. Then there is the overrated crowd that takes this down a different path... because I also put down 295wtq
Tags
1m ess, biglare, dyno graph
1addicts
