07-07-2011, 08:18 AM | #1 |
Rep 1,497
Shocks w/EDC-Expensive to replace than shocks w/no EDC?
Are shocks w/EDC more expensive to replace than the standard shocks with no EDC?
Also-I know that a lot of guys take out the electronic suspension controls for hard core track duty. Last edited by checkmate; 07-07-2011 at 08:49 AM.. |
07-07-2011, 08:35 AM | #2 |
Mr. Nice Says Hello
636
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
On getBMWparts.com
it shows that part number: This is the price for without EDC I assume I assume that the EDC strut would be alittle bit more expensive but cannot seem to find the part number for a struct for edc I know a lot of track guys prefer not to have edc because once you go coilover setup you lose what EDC is for. But if you have a car with one you will have ot buy a module or have it coded to turn it off |
07-07-2011, 08:39 AM | #3 |
Mr. Nice Says Hello
636
Rep 16,662
Found the part number for the EDC strut, it looks like it is double the price for non edc strut
07-07-2011, 08:50 AM | #7 |
Mr. Nice Says Hello
636
Rep 16,662
07-07-2011, 08:51 AM | #8 |
Mr. Nice Says Hello
636
Rep 16,662
07-07-2011, 09:33 AM | #10 |
Mr. Nice Says Hello
636
Rep 16,662
EDC is nice to have, I did my first event with the EDC and it was nice to be able to adjust to the way I drove on the track. I plan on buying a set of coilovers shortly and edc was something nice to have until then
07-07-2011, 09:38 AM | #11 |
Astronaut
64
Rep 670
I heard a rumor that Dinan was coming out with some EDC compatible coilovers.
No details yet that i'm aware of. I have EDC and will be doing 6-8 DE's a year. So far it's been great for a compromise but i'm sure i'll do coilovers eventually like all the other cars i've owned. |
07-07-2011, 09:39 AM | #12 |
Rep 1,497
I'm more concerned about the day my warranty runs out-EDC Struts are expensive to replace and it seems my brain's telling me to not opt for the EDC at this time. My car only goes into production in August-so I still have some time to make changes.
I think the more important question-is the EDC worth it for $1,000? or should I save that money for a set of track wheels/tires/brake pads? Last edited by checkmate; 07-07-2011 at 09:52 AM.. |
07-07-2011, 10:14 AM | #13 |
Rep 15,818
if you only plan to track once a year and daily more often I'd say get EDC
I've tracked 4 times this year and will do another 5 or so more at least by the end of the year...and I'm still happy I have EDC :P
07-07-2011, 12:29 PM | #14 |
Rep 1,497
I talked to David Aviles (My SA) on my purchase and he recommended to not have the EDC option considering my plans to track and possibly change the springs/shocks down the road.
The non-EDC cars come with a default Normal Setting and according to David-even with the EDC-he always puts it on Normal mode for the best lap times. In addition to that he also agreed that with EDC-customizing shocks/springs would be a pain. There is a lot of coding that goes into it. Phew!-That's a good $1k in my pocket :-) |
07-07-2011, 01:08 PM | #15 | |
Rep 15,818
Normal is a great mode, but I love comfort mode on these crappy LA freeways If you plan on changing the suspension, then yeah EDC is a waste. I, however, do not :P
07-07-2011, 01:14 PM | #16 |
Rep 1,497
Considering these are electronic dampers/shocks-any new set up will be quite expensive to install considering the coding necessary to shut off the electronic nanny controlling the dampers. Your local indy shop will need access to BMW spec coding to do the EDC delete.
07-07-2011, 05:20 PM | #17 | |
Rep 15,818
If you go a spring set up, say Dinan or Eibach, then you don't need to modify anything related to the EDC Nonetheless though, if you do plan on changing your suspension, getting EDC is a waste of money
07-08-2011, 01:07 AM | #18 |
Rep 291
Only Once a year then go with Comp package car all the way nice set-up. Unless its a dedicated track car why spend 2k+ on coils. If you are financing the car 1000 spread out at a low interest rate less painfull than coils all paid at once. I would go EDC comp package. I love mine and BMW says its the best handling M3
EDC makes a differance. Last edited by FASTTOYS; 07-08-2011 at 01:12 AM.. |
07-08-2011, 10:42 AM | #19 | |
Rep 957
Regarding getting fastest lap times in Normal - I've heard that from many sources and I do prefer normal on track myself. But again, it's not equivalent to EDC. My recommendation would be get non-EDC if you plan to replace shocks and get EDC otherwise. It does make difference, even with aftermarket springs. |
07-19-2011, 10:15 AM | #20 | |
Rep 1
07-30-2011, 05:14 PM | #21 |
Rep 973
I am planning on buying an M3 but I dont know if I should put edc or not. I plan on buying 20s as soon as I get the car and I think it would need a little lowering as I opted for 18s from the factory. can I just put eibach springs on my edc suspension and would it work ok? I mean, I want to be able to have a soft ride when im cruising and a harsher ride when I go to the track(Id use my stock 18s for this). any input would be aprreciated
if you want perfection buy a mercedes, or marry an accountant
07-30-2011, 07:42 PM | #22 | |
Rep 8,952
Hope this helps! |
