07-03-2011, 07:24 PM | #1 |
Rep 161
About the brake fluid..
hi,i need help about the brake fluid,how much Brake fluid do i need for e92 m3 ? its time to change the fluid now,do you guys recommand OEM fluid or motul 600 or even castrol SRF ?
thank you! Last edited by JOM3JO; 07-03-2011 at 08:55 PM.. |
07-03-2011, 10:37 PM | #2 |
Rep 9,032
Not sure how much you need but SRF is the best.
The boiling points of Motul and Ate blue are pretty close, but Ate is CHEAP. .
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
07-04-2011, 12:59 AM | #4 |
Rep 4,737
I typically order 500 ml Motul when I bleed my brakes. But there is typically quite a bit of left over.
Note: when you bleed your brakes, that does not replace all the fluid in your brake system. To bleed the entire system you will need a car computer to cycle the ABS/DSC. |
07-04-2011, 02:57 AM | #5 |
Rep 161
i think i will do full brake fulid change,im going to BMW dealer to do it and i will bring my own brake fluid,but im not sure how much fluid do i need?
thank you! |
07-04-2011, 04:19 PM | #6 |
Rep 1,286
Why would you worry about that? The fluid doesn't circulate and who cares what's up in the abs pump unless the fluids are not compatible.
07-04-2011, 04:24 PM | #7 | |
Rep 1,286
Also, why don't you do this yourself? It's not difficult, just suction out as much as you can from the reservoir, fill with your new brake fluid and then you and a buddy (mate ) flush/bleed the system one corner at a time. The other advantage of the Motul is that it's a different color than stock and you'll see when the new fluid has reached the caliper. |
07-04-2011, 06:18 PM | #8 |
Rep 161
thanx for reply...i havent done the brake fluid myself before,i heard might get air or bubble inside,i have no idea how to do,and also i need BMW to reset the brake fluid warming light for me as well...is there any good DIY for brake fluid change? is 1 liter ehough?
thank you! |
07-04-2011, 10:06 PM | #9 | |
Rep 5,012
Oh, you'll need ONE LITER to do the job, but it'll BARELY be enough if you include the clutch. And no, the clutch valve is NOT a check valve folks . I thought it was, and let air in the system. Needed an extra liter to purge the sucker. Finally, it's quite easy to reset the computer for the brake fluid, oil change, and whatever else you want. Just do a search. I've done it twice already, but don't experiment yourself if it's your first time. Find somebody who knows how to do it, and learn from him. Start a thread in your regional forum for a 'tech day', offer to buy pizza, and you'll probably get at least one volunteer. And if you want to change the tranny and/or differential fluid, remember car has to be leveled. I did all of that not long ago in one shot. Good luck. EDIT: Since I don't track my car, I used Castrol GT LMA (Dot 3/4), made in Germany. Quite cheap ($9), and a great fluid. That's why I do it once a year < he he>. |
07-05-2011, 02:14 AM | #10 |
Rep 204
If you do a propper bleed you'll need at least one liter. I'd buy two liters.
After every day you track your car you have to bleed the brakes, to just refresh the oil that gets hot in the calipers. That's what i do. Go for the SRF it's the best, i use it in all the racing cars.
F13 M6 CP GT3 | Mineral White | 20'' BC Forged Center Locks | Fully Loaded | JB4/Meth | Custom GT3 Widebody Kit + Aero | Catless DP/X-Pipe | Turner StrackSport Discs/Pagid Brake Pads |
07-05-2011, 03:09 PM | #12 |
Rep 15,818
I asked my BMW tech and he said to get 3 bottles of 500ml (so 1.5L) to get a good flush
07-05-2011, 03:12 PM | #13 |
Rep 15,818
this is what I'm going to order:
http://cgi.ebay.com/ebaymotors/Motul...Q5fAccessories
