06-28-2011, 10:34 PM | #1 |
Rep 106
Brembo 365 with OEM 18 pic request
Does anyone have pictures of the Brembo 365/345 kit with the OEM 18" wheels? What are you running for spacers? Thanks.
07-01-2011, 12:17 PM | #2 |
Rep 3,523
No need for spacers, it fits the OEM 18's no prob.
Front wheels need low clearance wheel weights thats all. I'll post some pics in a bit. It fills the 18's in nice, looks great. I use my 18's in winter too with diff tires. |
07-06-2011, 12:58 AM | #4 |
Rep 338
Thanks, I just came here to check if someone uses 365 mm Brembos with 18" OEMs I would like to keep option to use 18" wheels and therefore prefer 365 mm version over 380 mm. How do you comment braking performance compared to OEM brakes? I'm really fed up with brake fade after just couple of laps.
i8 2014 (PI, Protonic Blue), X1 25i 2016. Gone F30 320i xDrive 2013, E84 X1 23d 2010, E60 530 xdA 2006, E92M3 2008, R53 Mini Cooper S 2006, F430 F1 2008
07-09-2011, 08:46 AM | #5 |
Rep 363
It looks like you may be running R compound tires? Those will allow you to generate even more heat in the brakes due to the higher level of grip provided before lockup. At the very least, and before you get your BBK, consider swapping out the stock pads for track pads at your next event. The OEM pads are in no way designed for track use. They're designed for low-dust, low-noise, high initial bite street use. They always fail on the track. That's why the "track" package Nismo 350Z crashed during Car & Driver testing at the track: it came with the same stock street pads that every other 350Z comes with. They got hot, faded and sent the car right off. Between track pads and race fluid (Motul 600 or the like) you'll be ok. But even after you get the BBK, I'd still run race fluid and track pads. The slightly larger diameter disc may not guarantee a fade-free track day. You gotta use a dedicated race pad, especially when you start getting faster.
07-10-2011, 02:47 PM | #6 | |
Rep 338
07-11-2011, 02:31 AM | #7 |
Rep 48
You don't need spacers but you do need to get the front wheels rebalanced with low profile wheel weight and have them install the weight as close to the outside edge as possible.
