06-23-2011, 02:04 PM | #1 |
Rep 800
Dumb Question: Torquing Down Top Shock Nut
I haven't actually tried it yet but it's been confusing me so I figured I'd ask. How do you torque down the nut on the top of the shock rod without the rod just spinning?
My car also has EDC. Do I need to get the rod back into a certain position to reconnect the EDC plug on the top?
I play real sports. Not tryin' to be the best at exercising. - Kenny Powers
06-23-2011, 05:41 PM | #2 | |
Rep 961
I have this one: http://www.europaparts.com/specialty..._store=default although there's no guarantee it will work with an EDC strut. It's thin wall and hollow all the way through, so a 3/8 hex head socket or regular socket just goes down the center onto the top of the strut shaft while the outer socket holds the nut. You put a torque wrench in the square hole and you can tighten it to the correct torque every time. Makes taking the strut apart a breeze too. There are other designs that work as well, and if there's enough room, an offset 22mm box wrench will work too, provided you can find one. I can't help you with clocking the EDC plug though. |
06-23-2011, 09:22 PM | #3 |
Rep 800
I think the nut on the M3 is 21mm. I'm not sure if that particular tool would work because you need to get a 10mm socket on the end of the shock rod. It sounds like you need a hex wrench for the top of the Audi/VW shocks.
No one really seems to address this in any of the DIYs on here or e90post. I think I can get it tightened down with the impact wrench but I won't know how tight it is.
06-23-2011, 09:38 PM | #4 |
Rep 4,737
1. Hand tighten the nut until snug.
2. Use a 10mm socket to hold the shaft. 3. While holding the shaft, use an open ended wrench to turn the nut. (note: do NOT use the socket to turn the shaft) 4. Once the nut becomes snug, remove the 10mm socket. Use a 21mm socket to torque down the nut to 64 N-m. The EDC plug is designed to rotate freely around the shaft. |
06-23-2011, 09:46 PM | #5 | |
Rep 961
The tool is double ended with a 21mm end and a 22mm end. A 10mm deep socket fits down the middle.
I'm sure rldzhao's method will work fine too. Quote:
06-23-2011, 10:19 PM | #6 | |
Rep 800
On another note, is there any problem using an impact wrench to remove the the shock rod top nut? Hopefully not since I already did.
06-23-2011, 10:45 PM | #8 |
Rep 876
I just looked at thew GC instructions...very bad...pics dont even show some of the parts...Jay needs to improve the instructions with color photos with step by step.
