      06-21-2011, 11:19 AM   #1
cc3
Drives: 1M, GT4, M2 M140i G40
Anyone had it flat out yet??
Is it faster in fifth than sixth? Does the limiter only work on 6th?? Anyone tried yet??
      06-21-2011, 11:28 AM   #2
fastauto
fastauto's Avatar
Drives: AW 1M Coupe
i am not 100% but i think the limiter is only in 6th. to me it seems like 5th is this cars sweet spot
      06-21-2011, 12:01 PM   #3
MNavigator
MNavigator's Avatar
10
Drives: EJ207
Flat out in 5th no limiter.
      06-21-2011, 12:07 PM   #4
b33g33
Give '///M' Hell!
b33g33's Avatar
Drives: Einser Rex
Thumbs up
.... and .... what did you hit????
      06-21-2011, 12:13 PM   #5
MNavigator
MNavigator's Avatar
10
Drives: EJ207
Depends on what you believe to be true Car 270+ km/h; GPS just under 260 km/h. Car pulled the whole way there.
      06-21-2011, 12:17 PM   #6
nachob
Drives: 2004 330i ZHP, 2022 Cayman T
My E46 speedo is on the high side. I would probably believe GPS more. My car registers 60 on the speedo, but the radar things always show 57 mph. Glad you made that point. The speedos can be off by 3 mph at 60, probably 5mph at full speed IMHO.
      06-21-2011, 12:35 PM   #7
Dackelone
European Editor
Dackelone's Avatar
Germany
10539
Drives: N54 e82
The speed limiter works in all gears. I think this is a falicy. People said the same thing for the 135i and even the M3. Its just that most people do not get the chance to drive THAT fast in the states or even while on ED over here. Even most Germans do not drive that fast! lol
I seriously doubt that the 1M will go faster than a real 260 kph without having its V-max speed limiter removed. That would be in sith gear too. BMW has said it is set to 250 kph. And unlike previous M models no higher speed limiter will be available.
Even on a 135i with sport package ((which included "#840 speed syncronation" option which is BMW speak for a higher speed limiter from the standard 135is 210 kph limiter) a 135i will only do a real 240 kph top speed. With the V-max chip from any tuner over here... 285 or 290 kph is possible. I personally have only seen 280 kph on my tuned 135i.
Some the M3 guys said their car could do 280kph or 173 mph.... but then I pointed out to them that the speedo WILL read 4% (or more) higher than true velhicle speed. ALL M cars will ony do 250 kph. IF you go thru a M driving school over here... you get a special certificate and race licsence - with this you can go to your BMW Zentrum and PAY for the 280 kph (real kph) speed limiter to be coded into the ECU. Or pay some chip tuner over here a few thousand euros for the V-max to be open. On an M3 that gets you right around 300 kph (real) v-max.
      06-21-2011, 12:42 PM   #8
Dan Parker
Drives: 2012 Golf R
Speed limiter removed. 182 mph on Android GPS speed app. It had more but I ran out of road.
Dan Parker
      06-21-2011, 12:58 PM   #9
M3Power79
Belgium
31
Drives: 1M sold - M4 MW DKG ordered
I did a dynorun last weekend and they found out that the car is not limited at 250 km/h but at 259 km/h, that's why it was probably not hiting the limiter at 270 km/h on tacho.
click here to see the result : http://www.1addicts.com/forums/showt...=538135&page=2
@DanParker : 182 wtf! Is your car already tuned?
"... on the smiles-per-mile charts, the 1-series M coupe can't be beat. It is a challenging piece, a triple-X-rated driver's machine for semi-professionals. Its handling balance provides an open invitation to indulge in latent oversteer, and provides an opportunity to separate the men from the boys. It is an absolute hoot on the track and an addictive plaything on your favorite twisty back road. "
      06-21-2011, 01:00 PM   #10
Dan Parker
Drives: 2012 Golf R
Yes but that's all I can say for now.
Dan Parker
      06-21-2011, 01:29 PM   #11
M3Power79
Belgium
31
You are making us curious He is folowing the BMW 1M marketing strategy
When do you reveal step 2?
      06-21-2011, 02:00 PM   #12
Dackelone
European Editor
Dackelone's Avatar
Germany
10539
Drives: N54 e82
FYI guys... in German tacho means speedometer.
So... if the 1M is limited to 259 kph (true vehicle speed) that that would mean about 272 kph on the speedo/tacho gauge. (IF you figure the speedo reads high by 4 or 5% plus).
Dackel
      06-21-2011, 02:50 PM   #13
EmmDrei
Germany
26
Drives: 2011 Saphire Black 1M Coupé
Hit my rev limiter in 6th once so far. Speedo read 270+, I didn't have time to really look at it, I was concentrating on the traffic. But the little beast didn't really have any "punch" above 250. At least comparing it to the M3, that is. That just kept going with unimpressed ease until the speedo went past the 300 mark. But to me it's not important. Autobahn isn't the fun part in the 1M and it's certainly not its strong-point. Btw, we already had a test "white against black"... I hate to say: the white one had more grunt!
The best piece of road - worldwide.
      06-21-2011, 03:09 PM   #14
MNavigator
MNavigator's Avatar
10
Drives: EJ207
Going from memory I think it was 272 speedo to 256 GPS or 6% error and that changed with speed. At around 100 km/h it was only 3-4% and that being said when I finally get my car redelivered I am going to check if the odometer is off as well.
      06-21-2011, 04:08 PM   #15
DriveHard
DriveHard's Avatar
Colombia
115
Drives: X1 and R58 JCW
lol I think the words "Traffic" and "270 kph" should not be used in the same sentance ..
tunnel vision just starts to set in at that speed, espically if you can maintain it and not run out of room.
I like high speed
X1, R58 JCW, M2 in my future if planets align
      06-21-2011, 04:23 PM   #16
MNavigator
MNavigator's Avatar
10
Drives: EJ207
I was in the same type of situation. It was around 1:30 in the afternoon.
      06-21-2011, 04:47 PM   #17
NihonX
Drives: 2011 VO 1M
I like high speed
Autobahn.
2011 VO 1M
      06-21-2011, 06:27 PM   #18
clived
clived's Avatar
Drives: Evolved 1M
Given the running in instructions refer to 160mph, the limit being a real 259 km/h sounds exactly right to me.
2019+ BSM M2C 2011-2012: VO 1M Coupe, many toys, Evolve Stage 3. 2008-2011: 135i M Sport Le Mans Blue / Lemon / HGSL. Evolve OBD remap - 390bhp. Also in the family: X3 M40d / Audi S4 (V8)
      06-21-2011, 08:08 PM   #19
M12Power
M12Power's Avatar
Drives: 2015 Scion FR-S 6MT
Was that in 5th or 6th gear?
      06-21-2011, 08:34 PM   #20
Dan Parker
Drives: 2012 Golf R
Dan Parker
1addicts
