BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
      06-19-2011, 08:09 PM   #1
SlamMan
SlamMan's Avatar
Drives: ED 5/19/2010, Interlagos E90
Need Help with Ground Control Conversion Kit Install
I know this isn't a technical section but I'm hoping it gets seen by someone who's installed this kit since I've got the front of my car completely torn apart now.
I'm questioning where the sway bar link bracket should sit on the body of the shock absorber. I marked the stock bracket per the instructions but, because the diameter of the shock body gets bigger (pic 2) a little ways from the top, when lining up the GC bracket to the stock mark it doesn't make much contact with the body of the shock except at the very bottom (pic 3).
I'm also unsure how long to set the sway bar links.
Any help is greatly appreciated. I'm taking lots of pictures so once I'm done I'd like to put together a DIY write up.
I play real sports. Not tryin' to be the best at exercising. - Kenny Powers
      06-19-2011, 08:16 PM   #2
mact3333
mact3333's Avatar
Drives: 16' YMB/Blk F82
does this pic help??
      06-19-2011, 08:40 PM   #3
SlamMan
SlamMan's Avatar
Thanks. Unfortunately it's not much help. I can't tell where the bracket sits on the body from the picture. Did someone do the install for you?
      06-19-2011, 10:36 PM   #4
kitw
kitw's Avatar
471
Drives: F91 M8, 991.2 GT3
I think want the sway bar bracket underneath the blue line, not on top of it. Otherwise, the spring collar isn't going to be well supported either.
(this is a guess, i've never installed them but judging by the other pictures and the other install threads, I am guessing)
DSC_3369 by Kit W, on Flickr
      06-19-2011, 11:11 PM   #5
SlamMan
SlamMan's Avatar
That's what I think too and that's where I was planning on putting it. It makes the most sense but the diagram isn't clear one way or another. If that's where the bracket goes, I'm not sure if the threaded sleeve is supposed to rest on the top of the bracket, or the body of the shock, or both kinda. It's close.
The diagram almost seems to point to the line under the bracket. That's why I started second guessing.
      06-19-2011, 11:25 PM   #6
mact3333
mact3333's Avatar
I didnt install mine...but threaded sleeve looks like it should be on top of the bracket...also, the end link is a certain length so it when you attach one end of it to sway, shouldnt it be obvious at which height the end towards bracket should go??
      06-19-2011, 11:31 PM   #7
SlamMan
SlamMan's Avatar
The sway bar link is adjustable but it's closest to the stock one in length if the bracket is below the line. Another reason it makes most sense with the bracket below the line.
      06-20-2011, 10:56 AM   #8
signes
signes's Avatar
Drives: 991 GT3 RS
Did you get this worked out and finished up last night? Curious to see pics of the result and the DIY. Hope you got it sorted.
GT3 RS | Desperately seeking the next great M car...
      06-20-2011, 11:04 AM   #9
SlamMan
SlamMan's Avatar
Unfortunately no. I need to call GC here soon.
      06-20-2011, 12:21 PM   #10
SlamMan
SlamMan's Avatar
A big thanks to Donovan at Ground Control for answering my newbie questions. I just got off the phone and, according to him, the threaded sleeve is just going to rest on the tapered part of the shock body, just above my blue line in the 2nd pic. The link bracket is just going to attach below that. If I put the link bracket just at or below the blue line then the bracket won't come in contact with the threaded sleeve. He said the sleeve doesn't necessarily rest on or come in contact with the link bracket. He told me the marking of the original bracket was less about the height and more about the circumferential orientation. Good thing I marked both just to be safe.
Hopefully I won't run into any other questions and I can wrap up this evening.
      06-20-2011, 01:46 PM   #11
mact3333
mact3333's Avatar
you're a brave man for doing this on your own...I know its not an easy install...
GL...post pics when youre done.
      06-20-2011, 11:46 PM   #12
SlamMan
SlamMan's Avatar
Damn. I'm so close. The kit included a couple new bump stops and I'm not sure which is for the front and which is for the back. My guess is the one on the left goes on the front but neither stop has a large enough inside diameter to slide down on the shock rod like the stock one does.
I'm also hoping I can get a torque spec from GC on the link bracket nut. It seems to be a pretty soft metal, aluminum maybe, and I don't want to over torque it.
      06-21-2011, 06:15 AM   #13
mastek
e36s54, e70x5d
mastek's Avatar
Drives: slow
Originally Posted by mact3333 View Post
Also, you want to have the bracket-bolt assembly face the transmission -- and not the engine, like in this pic. Jay @ GC specifically instructed me to point the bracket at an angle towards the transmission in order to allow the sway links to work with the OE sway bar and now make noise.
      06-21-2011, 11:32 AM   #14
mact3333
mact3333's Avatar
WTF!.......Mastek, can you post some pics of your GC setup as I am taking my car in this friday for slight adjustment of height and would like to get this setup the right way.
      06-21-2011, 12:27 PM   #15
SlamMan
SlamMan's Avatar
I do remember Jay mentioning to mark the location of the bracket. I thought he meant mark it for height on the shock body but he must have been referring more to the angle the bracket points. Luckily I marked both. Your bracket doesn't look too far off if any. Has it made any noise?
      06-21-2011, 09:50 PM   #16
mastek
e36s54, e70x5d
mastek's Avatar
Drives: slow
I will try to find the pics - but its simple really ...
- have the front of the car raised equally
- loosen the bolt on the strut clamp holding the sway bar link
- and spin the strut clamp towards the back of the car a little (Jay said to have the clamp pointing back at the transmission)
      06-21-2011, 11:52 PM   #17
SlamMan
SlamMan's Avatar
I don't mean to pile on but I was just looking at this pic again and it looks like the bump stop may be on upside down. Stock, the boot is attached below the bump stop. I don't know how critical it is though.
      06-22-2011, 05:57 PM   #18
mact3333
mact3333's Avatar
You are right, my bumpstop and sleeve is upside down.
      06-22-2011, 10:00 PM   #19
AMPowerJ
One mod leads to another ...
AMPowerJ's Avatar
Drives: 2014 F10 M5
Why don't these kits come with better instructions?
When I installed my Dinan springs it was the same way. Here are a bunch of parts; good luck figuring out their orientation.
Current: 2014 F10 M5
Previous: 2015 F80 M3, 2013 E92 M3, 2013 F10 M5, 2009 E90 M3, 1998 E36 M3
      06-23-2011, 01:59 PM   #20
SlamMan
SlamMan's Avatar
Better instructions would be nice for sure. I'm going to put together all the photos and notes I have for this for a DIY post.
I'm pretty much finished with the fronts. I just have to torque everything down to spec. It's taking so long since I only have a little time at night to work on it. I also don't have a 21mm-3/8in socket for my 3/8in torque wrench so I need to go buy an adapter or 21mm socket tonight. Balls! The back has to go faster.
      06-24-2011, 06:25 PM   #21
SlamMan
SlamMan's Avatar
Done with the front! Just need to knock out the backs tonight and set the ride height and sway bar links.
      06-27-2011, 11:13 AM   #22
dnvrdrvr
Captain Obvious
dnvrdrvr's Avatar
Drives: 2018 VW GTI SE
Well... how'd it go?
Just a girl and her 863 ponies...
2013 Santorini M3, 2016 328i Alpine White Wagon (Lab hauler), 199x wrapped E36 M3 (because racecar)
///M-Flight
m3post
