05-30-2011, 01:21 PM | #1 |
Rep 1,086
Need front Camber Plates
I have to reduce my outside tire wear, improve turn-in and limit understeer. I want to use camber plates only, no springs, coilovers, etc. at this point. I'd prefer adjustable plates, but some of those come in cool colors and are probably a dead giveaway at the dealership during regular maintenance? I don't need to be flagged.
Adjustable plates that I've read about include: 1. Vorshlag 2. Ground Control 3. Does Turner make some that are not listed? 4. Others? Fixed Plates: 1. Dinan 2. Others? Also, is there a camber plate only solution out there that doesn't raise the front ride height? If no, how much does each set raise the height and is this just an aesthetic issue? Thanks! |
05-30-2011, 03:43 PM | #3 |
Rep 2,991
There are no camber plates except the Dinan plates that work with stock diameter springs.
First thing to try is to remove the front camber pins. that should get you -0.7 more camber. On stock springs, you'll probably get to -1.3 or there abouts. Beyond that is going to be replacing shocks and springs with something height adjustable or using the Dinan plates (which really only raise the car 1/4") |
05-30-2011, 05:17 PM | #5 | |
Rep 1,086
05-30-2011, 06:09 PM | #6 |
Rep 222
Not sure I'll need them yet, but I suspect I will; first track outing for the new E90 will be June 11.
Anybody make camber plates for a 2011 E90, ZCP, EDC; and do they change ride height? joel |
06-01-2011, 04:53 PM | #10 | |
Rep 1,286
How much did it raise the front end? I thought that all of the adjustable camber plates were at least 1/2" or more tall and would add that height to the front suspension. Is that true or did you use shorter springs in front? |
06-01-2011, 05:25 PM | #11 | |
BimmerPost Supporting Vendor
445
Rep 1,658
Ground controls unit is the only true camber plate I know of that works with the stock springs and EDC. The Dinan plate is a waste. They seem to have two versions. I'm not 100% sure what the difference is a their site has no product description. it might just be a revision of the upper spring perch |
RedSectorA37.50 |
06-01-2011, 06:15 PM | #12 | |
Rep 2,991
06-02-2011, 02:11 PM | #13 | |
Rep 48
Hands down GC has the best camber plates on the market. |
06-02-2011, 06:35 PM | #14 |
Rep 2,991
Ok, wow, looks like they have done a different plate for the E9x. I'll have to check them out. Looks like it is a stock style plate with a large thrust bearing. I like.
06-02-2011, 07:22 PM | #15 |
Rep 1,286
What happens to the stock "rubber" strut travel limiter with the GC camber plates? Is that eliminated and replaced, if so by what? I thought that it (stock bushing) had some sort of progressive resistance that was unique and helpful given the limited travel of the stock M3 suspension.
06-03-2011, 12:03 AM | #16 | |
Rep 2,464
is ground control camber plate fixed or adjustable?
2011 MINI Cooper S
previous cars: E92 M3, Z4MC, Z4 Roadster, E36 328 Sedan |
06-03-2011, 04:14 PM | #17 | |
Rep 876
Unless you track your car, couldnt imagine a need for camber plates, esp if you pull the pins out, giving close to -2 just from that move.
Also, dont think dealer will notice camber plate install unless they look closely as they arent visible from strut tower brace points inside the engine bay...the plastic cover from EDC covers it up. Quote:
06-03-2011, 06:41 PM | #18 | |
Rep 9,032
http://www.m3post.com/forums/showthread.php?t=534485 If he gets some plates and runs -2, he maybe able to use those PS2's on the street for a few thousand miles!! .
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
06-04-2011, 10:15 PM | #19 |
Rep 676
Strongly disagree re camber plates on the street- BEST mod I have done MAJOR impact on control and fun to drive at moderate speeds around town-NOT for track only, not at all.
06-04-2011, 11:50 PM | #20 |
Rep 876
Hmm...you can get -2 camber by pulling pins without a camber plate...so this implies you will be running -2.5 to -3.5?...good way to wear out inner tread too quickly unless you are driving very aggressively on the street which prob isnt a great idea anyway...also, car is way too twitchy on the street at -3 or more imho.
06-05-2011, 12:47 AM | #21 |
Rep 9,032
Have you seen anyone get -2 by pulling the pins?
I've seen -1.7, which is pretty good, but not the same as -2.
06-06-2011, 01:04 AM | #22 |
Rep 4,318
-2 won't happen on stock springs even without the pins. Won't even get close to that.
GT3 RS | Desperately seeking the next great M car...
