BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
      05-27-2011, 12:44 AM   #1
rzm3
rzm3's Avatar
673
Drives: E92 M3
Arrow KW Competition Installed and Tested... 2.8 Seconds Faster than Stock
Constructed from the same internals as the M3 GTS and 1M MotoGP Safety Car, the KW Competition system is built for M3s whose owners demand more than the one-size-fits-all, off-the-shelf coil over kits.
Designed using the 7-post rig and extensively validated on the track, each kit is customized and hand-built at KW Racing in Germany, and then FedEx'd over to the States.
Compared to the KW Clubsport, Competition uses upgraded competition quality parts for even higher performance and durability. For example, the already superb clubsport camber plate is reinforced, rubber bushings are replaced with full spherical bearings, the lower spring perches are now aluminum, and the rear shaft diameter is increased to 22 mm and available as a coil over.
This set up is designed specifically with the track day enthusiasts in mind. The adjustment range of the dampers allow the system to be comfortable on the street, and competitive on the race track.
      05-27-2011, 12:46 AM   #2
rzm3
rzm3's Avatar
673
Drives: E92 M3
Arrow Stock vs. KW Competition
Since 2008, I've tried H&R, Dinan, Moton Street Sport, Moton Club Sport. This will be my 5th system in preparation for NASA Time Trail, so I wanted to do things the 'proper' way.
As I have a full data system on my car as well as access to MSR Houston, I decided to do a true apple-to-apple comparison -- same car, same modifications, same track, and same driver... the only thing that's changed is the suspension.
Car Specification:
2008 E92 M3 DCT
Yokohama AD08 265/35 & 295/30
CCW C14 Forged Wheels 18x9.5 & 18x10.5
Rear Seats Delete
StopTech BBK ST-60 & ST-40
GT4 Aero
      05-27-2011, 12:47 AM   #3
rzm3
rzm3's Avatar
673
Drives: E92 M3
Arrow Full Review
Driving Impressions
First, a little bit of the stock suspension.
It has been a while since I last drove with stock suspension. Overall, for a street set up it worked quite well on the track. Obviously the springs are soft which means you have to be patient, brake early, and let the car roll into corners. Or, in the words of a racing driver: "you turn the wheel and then a second later you realize 'oh shit' all the 3700 lbs are on the outside wheels."
The other noticeable attribute of the stock suspension is the mid-corner push as expected on most street cars. This is especially noticeable at turn 17/16/15 of MSR Houston. Some drivers will try to stab on the gas to get the rears loose and rotate the car, but during the process you transfer weight away from the front and understeer even more. In sum you lose a lot of time when the car understeers.
Anyhow, onto the main event – KW Competition.
I worked with KW and spec'd the kit specifically for a street legal weekend track car. KW has several set up combinations available based on their shaker rig testing and field experience. I chose rates which are about 15% stiffer than their Clubsport. This combination will give the car much quicker transition time vs. stock, and, at the same time, maintain a decent ride on the streets.
First impression is that the turn in is much, much sharper compared to stock. The stiffer springs combined with proper shock valving significantly shortens the transition time which allowed me to brake and turn in later.
Second impression is that there is much more grip in all four corners on the same tires. This is in part due to the front adjustable top mount will give you a max of around -3.5 degrees of camber. I've set mine to -2.8 degrees based on data from prior runs, but I can easily add/subtract if needed -- camber can be adjusted directly through the strut tower openings -- without taking the strut assembly off.
The balance: car is very neutral now at the limit. At turn 2 the carousel you can now be on the throttle for almost the entire duration. And at turn 17/16/15 I can easily get the car pointed at the right direction and power out of the exit.
The Results
1:48.3 is my fastest lap time on the stock suspension. 1:45.5 is my time on KW Competition. This is a delta of -2.8 seconds.
As you can see from the track data, through every corner the M3 is able to enter and exit at a higher speed. The most notable corner is 17/16/15, where the KW is 4 mph faster than stock. This is due to a much balanced chassis which allowed me to get on the gas pedal much sooner than when the car understeered on stock suspension.
The beauty of KW Competition is that it comes as an integrated suspension solution. KW has collected a tremendous amount of data on the M3 from KW’s shaker rig testing as well as racing experience, so the kits are truly tested and proven. On the other hand, most high-end dampers from other brands come as dampers only, and typically vendors who may not always have a lot of experience on the M3 are in charge of getting camber plates, spec’ing springs, setting shock valving, etc. Therefore it takes a lot of time and effort to tune a set up like that correctly (for me, I had two racing drivers help me tune my Moton set up).
Hope this has been helpful.
      05-27-2011, 02:56 AM   #4
kitw
kitw's Avatar
471
Drives: F91 M8, 991.2 GT3
Wow, those struts/shocks are a lot shorter than stock! cool.
I get really leery of using spherical bearings in the top hats on the street, especially since they aren't sealed against getting crud inside them.
DSC_3369 by Kit W, on Flickr
      05-27-2011, 03:09 AM   #5
biglare
Bulldog
biglare's Avatar
Drives: BMW & Porsche
Great news Richard and really looking forward to seeing the times with this new setup.
Did you need to get an alignment after the installation as well?
Prev: Individual F80 M3 - Fjord Blue/Silverstone(interior) | Fashion Grey(exterior)
GTS
      05-27-2011, 07:32 AM   #6
klammer
Drives: 11 spc gry m3 e90, 19 X5
Looks nice, looking forward to
the comparison and vids.
mods: track ready stuff
      05-27-2011, 08:31 AM   #7
STALKER
Drives: 997.2 GT3, Golf R
Very interested to read your review.
Keep up the good work and thanks for sharing the info with the community here.
      05-27-2011, 09:32 AM   #8
rzm3
rzm3's Avatar
673
Drives: E92 M3
Should be no problem. You get lots of junk on the race track as well.
KW offers two top mount versions for Competition kits. The Competition version in the picture above, and the Clubsport version below. The Clubsport mount has boots for those who live in the snow belt.
Yes sir!
      05-27-2011, 10:27 AM   #9
flipm3
E46 + E90 + F80
192
Drives: E46 + E90 + F80
2009 BMW M3  [0.00]
2002 BMW M3  [0.00]
Wow...these look incredible! Definitely looking forward to hearing your reviews and thoughts!
Thanks for always providing this forum with thorough and educational information!
F80 M3 DCT|Alpine White . Black Leather | My Build Thread
E90 M3 DCT|Melbourne Red . Speed Cloth | My Build Thread
E46 M3 6MT|Jet Black . Black Nappa Leather | My Build Thread
      05-27-2011, 12:08 PM   #10
kitw
kitw's Avatar
471
Oh, I like the clubsport mounts! are they the same thing with boots or do they have some more rubber in them?
      05-27-2011, 10:30 PM   #11
wwjd15
Drives: 11 E92 M3 MR
Great stuff from Richard as usual! I'm in for result.
      05-28-2011, 01:30 AM   #12
montreal red
chris
montreal red's Avatar
Drives: White Boat
wow thats a great looking suspension kit.
Current: 2013 F10 M5 & 2016 Mini JCW
2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone)
      05-28-2011, 01:36 AM   #13
GewoW
#thatsanicemovebro
GewoW's Avatar
Greece
202
Drives: E92 M3 LSB/Black 6MT
2011 BMW M3  [9.34]
why no love for JRZ?
      05-28-2011, 05:49 PM   #14
rzm3
rzm3's Avatar
673
Drives: E92 M3
Neither has rubber in this area. The designs are similar in construction, but the Competition version uses more material around the spherical bearing for higher durability.
      05-29-2011, 12:09 AM   #15
RickyBobby
RickyBobby's Avatar
108
Drives: M3
Nice looking mounts. Do they have radial bearings in them?
      05-29-2011, 03:48 AM   #16
Eugene-TAIWAN
Eugene-TAIWAN's Avatar
Taiwan
249
Drives: E92 M3 Coupe
wow i wonder how much these things go for
Past: Gintani stage3 M3, Cayman GTS
present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW
      05-29-2011, 04:16 AM   #17
Maseroche
Maseroche's Avatar
Bahrain
55
Drives: '12 BMW M3
2012 BMW M3  [0.00]
A friend of mine swears by these! he has them on several of his cars, even street-driven ones.
Khalid
'12 BMW E92 M3
'03 BMW E46 M3
'14 Mercedes-Benz S400
'18 Alfa Romeo Giulia Quadrifoglio
      05-29-2011, 05:48 PM   #18
mastek
e36s54, e70x5d
mastek's Avatar
Drives: slow
If your doing a true "apples-to-apples" comparison please make sure to post the compression & rebound settings of both coilover kits.
And please post an MSRP for this kit. Thanks
      05-30-2011, 07:25 AM   #19
dawgdog
Drives: 2015 M3, 2016 GT3
Just have to comment that I am so impressed with how you have set up your car.
2015 f80 M3, 2016 GT3
      05-31-2011, 04:04 PM   #20
STALKER
What ride height are you going to set these at?
      05-31-2011, 06:19 PM   #21
aw335can
Drives: 2007-335i, 2009 AW M3 CPE
Im going to put those on my must have list...
      05-31-2011, 06:36 PM   #22
rzm3
rzm3's Avatar
673
Drives: E92 M3
-0.75" from stock.
m3post
