BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
European Auto Source (EAS)
      05-26-2011, 09:31 AM   #1
SlamMan
SlamMan's Avatar
Drives: ED 5/19/2010, Interlagos E90
Sintered Pad Recommendation
I just read through the links in the sticky on choosing pads and it sounds like sintered pads might be a good track option for me. I'll probably be doing a few HPDE events and open lapping days and would like a pad that I can swap out for those events. I figured the sintered par would be the way to go as it doesn't require bedding.
I've searched the forums for feedback on pads but haven't seen much mentioned about whether the pads people are reviewing are sintered or metallic and most websites selling pads don't seem to mention much one way or another either.
Can someone recommend some sintered pad options? Am I overlooking metallic pads too quickly?
Thanks!
I play real sports. Not tryin' to be the best at exercising. - Kenny Powers
      05-26-2011, 09:47 AM   #2
DTM-POWER
Debonair
DTM-POWER's Avatar
Drives: e39 M5, 650hp Evo X
I don't care what anyone says. Every full race pad needs bedded. Just its only 1-3 laps.
I've had the best success with DCT-70s for initial hot bite and temp and also last the longest in my evo. I plan on running a set when I get my m3 but the stock calipers/rotors just aren't going to be able to take any track use even with full race pads I'm expecting.
Wait and euro delivery a 2012 E92 Alpine white on Fox DCT or get a 2011 now?? UGH
      05-26-2011, 09:51 AM   #3
Jaypod
Jaypod's Avatar
Drives: Frozen M3, AM V8V, 991 GT3
+1
      05-26-2011, 12:47 PM   #4
SlamMan
SlamMan's Avatar
So would the bedding process just be less intensive?
The only sintered pads I've come across so far are the CL pads on Essexparts.com
Edit: After reading more about the bedding and swapping process I could be talked into some metallic pads too.
      05-27-2011, 08:35 AM   #5
madmaxhk
Drives: BMW 135i 08
+1 on the CL brakes. I have them on my cars, Lotus Exige, BMW 135i and Evo X. The pads have excellent initial cold bite. The only problem is the heat might transfer to the brake fluid.
The CL brake doesn't come with any back plate. I will recommend install the Titanimun heat shield shim from hardbrakes.com
      02-23-2014, 01:00 PM   #6
dcaron9999
dcaron9999's Avatar
Drives: 2011 135i M package
Sorry for thread revival. The Rc5+ seem like an excellent track/street compromise sintered pad for my BMW 135i.
Im looking into these, and I think Essex Race Parts is the only reseller in the US...
http://www.essexparts.com/shop/brake...-pads-152.html
"The RC5+ is CL’s latest offering, and was developed with the autoX and track day crowd squarely in mind. It is a well-mannered race pad, with lower noise, low dust, and a lower coefficient of friction. The beauty of this compound is that despite its mild manners, it still retains a very high max operating temperature. It is a great choice for lighter cars on race tires, or heavy, high power cars on street tires. The failure mechanism of this pad is one of its greatest strengths. If you do happen to push it over its temperature threshold, bite slowly tapers away rather than falling off a cliff, so you’ll easily recognize when it’s time to back off. It’s extremely wear resistant, and doesn’t destroy rotors with pad deposits when pushed to their temperature envelope. The RC5+ is a great rear pad option for those who like a more front biased setup with the RC6 or RC6E compound up front."
Essex Part # 07 4156 17.0 RC5+
Manufacturer Part # 4156RC5+
FMSI #
Composition Sintered
Category Club Sport/Full Race
Max Operating Temp* 1800F
Dust Moderate
Noise Low to Moderate
Bite / Mu Moderate to High
Judder/Vibration Very Low
Pad wear Low
Rotor wear Low
2011 X3 35i with M pack + 2011 135i w/6SPMT | 255 square tire setup | Quaife 3.46 LSD | Diff lock down bracket | Bilstein B8+Swift SpecR springs+H&R FSB | CDV delete | BMS Oil Tstat bypass | ER FMIC & CP | N54Tuning DP | GC Street Camber Plates | M3 FCA +guide rods+RSFB's+Tranny mounts | Manzo toe arms | Cobb Stg2 agressive tune | Hawk DTC70 brake pads | RB SS brake pistons | Goodridge SS brake lines | Custom brake cooling ducts
      02-23-2014, 01:33 PM   #7
JAJ
Drives: 2014 Shelby GT500
I looked into the CL sintered pads a while ago. They work well for the track but they're basically metal-on-metal, so when they're cold they can erode your rotors very quickly. The good news is they don't need bedding and they work well hot.
m3post
