05-25-2011, 02:39 PM | #1 |
Rep 28
2008 E92 M3 Brake Rotors Warping
Here's my situation:
I purchased a 2008 E92 M3 in early 2009. After about 8K miles the steering wheel would shake while lightly applying the brakes at 70+mph. So I took the car into the dealership and they said the rotors are warped. They replaced them with new pads and rotors. Everything was back to normal. However after another 6k miles I got the same problem happening again. So I took it back in and they replaced them a 2nd time. Keep in mind I had only gone through 10% of my pads from the first time they replaced the rotors to the 2nd time so it's not like I as doing any excessive braking. Then what happens? After another 6k miles the same warping again. So they replace it one more time and tell me this is the last time. Of course they warp again after another 6k miles after the 3rd time and BMW refuses to replace them anymore telling me that the reason this is happening is because I am abusing the vehicle. Now I've owned an E36, E46 and E92 M3 the past 12 years. I have NEVER had any problems with any of them until this one. I have only tracked the current M3 one time at a BMW sponsored event before any rotors were replaced. Is there anyone else out there with the same problem with their E90/E92 M3 in that the brake rotors are warping under normal driving? |
05-25-2011, 02:48 PM | #2 |
Captain of the Enterprise
101
Rep 1,424
That is very strange. Are you sure you're being honest?
If yes, then perhaps there's an engineering reason why this is happening. Can any tech heads out there offer some insight?
2011 1 Series M Coupe VO M3 vs 1M Comparo Review 2011 M3 E90 DCT ZCP (sold) * 2010 335i Sedan (sold) 2005 M3 Convertible (sold) * 2003 325i Sedan (sold) |
05-25-2011, 02:59 PM | #3 |
Rep 751
I assume the tech checked other suspension components for excessive wear, such as wheel bearings and control arm bushings. If you are using the OE pads, without switching between different street/track pads, and your use is as described, then it’s hard to imagine a reason for it. And even with such switching around, I would not expect warped rotors, but perhaps pad deposits that could demonstrate a similar symptom. Contrary to general opinion, it is rare for a rotor to warp.
05-25-2011, 03:31 PM | #5 |
Rep 7,887
Nope!My stock rotors lasted at least 53000kms and over 40 trackdays with no warpage.I had pad deposits which caused vibration but they cleaned off after a bit of use.They were still within service limits when I sold the car.
05-25-2011, 03:44 PM | #6 |
Crazy Russian Bastard
30
Rep 819
Even if you drove your car for the last 6k miles only from work and back home with no street racing. Then the issue you are having is because you are riding your brakes way too much.
Also get some fresh fluid in to brake lines. And check calipers for any damage. But im quiet sure you just riding your brakes too much. So you need to change your habit as to how you use the brakes when you slow down. Does any one else drives the car besides you?????
B
M W |
05-25-2011, 03:53 PM | #8 | |
30
Rep 819
And where or how exactly would a pad deposit stick on to a moving rotor???
B
M W |
05-25-2011, 04:08 PM | #9 |
Rep 751
Pad material reaction to heat. The pad transfer happens constantly with all pads, that’s how they work. But it should be uniform, assuming the operating temperature is within the design range of the pads. That’s why race pads don’t work when cold, and why track temps melt street pads in a weekend.
05-25-2011, 04:15 PM | #10 |
Rep 213
You are not hosing down the brakes w water when they are hot are you?
That's the only other reason I could think of that was not mentioned. Do you feel vibration in the pedal? Ever experience brake fade? Just thought I'd ask.
RPI GT Race Exhaust ~ RPI Scoops ~ BMC Air Filter ~ 19" BBS LM DBK ~ JL Motoring VRS Front Lip ~ Vorsteiner Diffuser Type I ~ KW Clubsports
My RPI GT Race Dyno vs. Stock: http://www.m3post.com/forums/showthread.php?t=239228 |
05-25-2011, 04:17 PM | #11 |
O! So Sour!!
552
Rep 15,615
Drives: Fast 240z / Slow M3
I had my rotors warped after 9K miles as well. Same exact symptoms as OP, shake in steering wheel when braking above 50MPH And i dont "abuse" my car.
My buddy assumed it was also pad deposit, but when I went to dealer, they checked the rotor and the oscillation was pretty bad. My M is also a 2008 Hopefully that is the only and last time, anyone else have this issue besides OP and I?
05-25-2011, 04:17 PM | #12 |
Rep 638
The 'tech' probably didn't check the rotors properly. I could almost guarantee that they won't be warped.
It will probably be either pad deposits, dirt behind the rotor mounting face, buckled wheel/tyre, or worn suspension bushes. Next time, get them checked at a precision engineering shop who know what they are doing. |
05-25-2011, 04:21 PM | #13 |
Rep 398
There is no such a thing as warped rotors. There is no way that pressing cast iron with a softer compound could warp the rotors. Like someone mentioned before the vibration is due to brake pad deposits that are caused by uneven cool down of the brake rotors. When you create heat by pressing the brake pedal and come to a stop leaving the foot on the brake causes the surface that has contact with the pad to stay hot while the rest of the rotor is cooling down;therefore a chemical reaction causes that a deposit of pad material to be deposited on the rotor forming an uneven surface which is not visible to the naked eye.
Your driving habits caused those deposits and you should make changes to the way you use your brakes. Excessive heat is your enemy and leaving your foot on the brake after generating excessive heat will contribute to vibrations on your braking system. Dragging the brakes generates heat and that's why people who drive that way usually experience brake problems. Keeping your brakes cool when possible should be your state of mind. Try braking and taking your foot of the brake to slow down when you know that you will be approaching a red light or intersection and take your foot of the brake as soon as your car stop. The M3 DCT will allow you to do that. Just my .02
05-25-2011, 05:30 PM | #14 | ||
30
Rep 819
And yes, there is such a thing as warped rotors! http://newcarbuyingguide.com/index.p...318/event=view You can google a lot of information on warped rotors. Quote:
The way to prevent warped rotors, is to follow a strict break in procedure for pads and rotors. PREVENTION There is only one way to prevent this sort of thing - following proper break in procedures for both pad and disc and use the correct pad for your driving style and conditions. All high performance after market discs and pads should come with both installation and break in instructions. The procedures are very similar between manufacturers. With respect to the pads, the bonding resins must be burned off relatively slowly to avoid both fade and uneven deposits. The procedure is several stops of increasing severity with a brief cooling period between them. After the last stop, the system should be allowed to cool to ambient temperature. Typically, a series of ten increasingly hard stops from 60mph to 5 mph with normal acceleration in between should get the job done for a high performance street pad. During pad or disc break-in, do not come to a complete stop, so plan where and when you do this procedure with care and concern for yourself and the safety of others. If you come to a complete stop before the break-in process is completed there is the chance for non-uniform pad material transfer or pad imprinting to take place and the results will be what the whole process is trying to avoid. Game over. Very good question.
B
M W Last edited by KGB7; 05-25-2011 at 06:07 PM.. |
05-25-2011, 06:06 PM | #15 |
Rep 751
Sorry, I thought I did. If pad material is subjected to heat significantly beyond its design parameters, then it no longer transfers in a uniform manner. If you rub a stick of butter on toast, it comes off very evenly. If you try to rub in on the surface of a hot pan on the stove top, it pours off, and will then solidify in chunks as it cools. Of course, the "chunks" on a brake rotor are thousandths of an inch in thickness, but still there. At least, that is my understanding of it, and seems to be supported by experience.
05-25-2011, 06:10 PM | #16 | |
30
Rep 819
http://en.wikipedia.org/wiki/Brake_fade http://en.wikipedia.org/wiki/Disc_brake Scroll down to; Disc damage modes
B
M W Last edited by KGB7; 05-25-2011 at 06:16 PM.. |
05-25-2011, 06:27 PM | #17 |
Rep 4,167
I will be honest in saying....
after putting hawk hps pads on and killing them rotors, they better WARP or I aint driving hard enough lol.. Seriously though, it might be the calipers are uneven.
Audi R8 v10 Ford Raptor m3e46freak@yahoo.comfor all euro parts!! ebay/craigslist verified/ m3post/e46fanantics/m3forum/zpost/bimmerforum |
05-25-2011, 07:09 PM | #18 |
Rep 213
A couple more questions and points to consider...
I would recommend not using your parking brake after hard braking and or driving. This can potentially cause a problem. Also after a session of hard driving I would recommend cooling down the brakes by cruisin around a bit.
05-25-2011, 07:11 PM | #19 |
Rep 213
Hey op are you Ricky Fowler the golfer?
05-25-2011, 07:18 PM | #20 |
Rep 95
Question; Manual or DCT? AND... No I don't want to make this another one of "those" threads. Also, front, rear, or both sets warped?
Delivered 02/20/09
LeMans Blue/6MT/EDC |
05-25-2011, 07:21 PM | #21 |
Rep 239
What I would do is to make a series of stops from 60 mph or so, hard but not so hard as to have ABS activation. 10 stops or so will do and check afterwards. Be sure also to have the lug bolts torqued evenly (using a torque wrench). If the pulsing continues then the problem was warped rotors. If it disappears, deposits or something like that are the problem. You should also check the front wheels for balance. With these big wheels bad balance sometimes feel like warped rotors.
05-25-2011, 07:33 PM | #22 |
Rep 5,012
Guess you didn't take physics in High School then . Get your cast iron rotors hot enough from riding the brake pedal (or doing a few panic stops from high speeds), then hose them down with cold water and tell me what happens . And yes, riding the brakes can warp them too.
