04-07-2011, 01:13 AM | #1 |
Rep 3,479
Drives: 19 M2C 6MT
Another spring question.
I don't feel like spending the money for KW's, but if i feel like I need to, I will.
I want to lower my car, not sacrifice the ride quality, and not worry about having to replace shocks or having to worry about blown shocks. Anyone have issues with just having springs? I also don't want to change out bump stops or shave mine. Thanks in advance! Kian |
04-07-2011, 05:04 AM | #2 | |
Rep 638
You are only 18mm off the bump stops as standard. Lower it 18mm and you will be riding on them. Shaving the guide supports retrieves 9mm of travel and shorter bump stops allow another 9mm. Some people just fit springs, but there is not enough data yet to see what the long term damage is to the shocks. |
04-07-2011, 02:39 PM | #3 | |
Rep 3,479
Drives: 19 M2C 6MT
The thing is, I put Eibach springs on my 08 135i, after 2 years, my shocks were gone. I felt every single bump, dip, ding, lump... I don't want that to happen with the M, so i was hoping to find a good solution for lowering the car without any headache. I am hoping someone with a 2008 M3, that has had springs for 2+ years, can tell me how there springs and shocks are. Kian |
04-07-2011, 03:03 PM | #4 | |
Rep 638
04-07-2011, 03:43 PM | #5 |
Rep 3,479
Drives: 19 M2C 6MT
04-07-2011, 03:49 PM | #6 | |
www.facebook.com/weshowellcreative
59
Rep 623
Drives: 2015 AW M4 Coupe Project Car
Personally, I went with the Ground Control kit. It gives you street camber plates (quieter than steel on steel) and Jay will work with you to get the spring rate that makes the most sense. You can end up with something catered to your needs / track / street. Also, it's adjustable F/R and it's under a grand. Kind of a no brainer if you can swing 1k IMO. |
04-07-2011, 03:52 PM | #7 | |
Rep 3,479
Drives: 19 M2C 6MT
How are your shocks holding up with this setup? That is my main concern. Kian |
04-07-2011, 03:56 PM | #8 |
59
Rep 623
I don't think anyone is having shock problems (yet) I haven't seen any threads on this list in that regard (springs or otherwise)
The GC kit will give you more potential travel than springs and my hunch tells me that this equates to less abuse than springs. I'm no tech guru but this seems to make sense. However, If you want a bulletproof guarantee that you'll have no problems and long term reliability of your OEM shocks - it's just not there. I have EDC... but if my shocks go out in 2 years, I don't think it would kill me to track down a good coilover kit like the Moton SS (possibly with stiffer springs) or the AST 4200 with EDC delete. Would be a great excuse and a fun upgrade. |
04-07-2011, 03:56 PM | #9 |
Rep 638
Yes, i have done my EDC e92 M3 with Eibachs, shaved mounts and e36 m3 bump stops. If you want it to look better and ride close to stock with very little extra load on the shocks, this is the route to go. I am more than happy with it.
If you are planning on regular track days, then you will probably do better by looking at the other options. |
04-07-2011, 04:09 PM | #10 |
Rep 3,274
Someone on this forum needs to buy top mounts and shave them down, and then sell them. I would buy a set right now. ANYONE!?
04-07-2011, 08:12 PM | #11 |
Rep 6,007
Eibach worked perfectly fine for me for two years. As far as I know it's ok to hit the bump stops on this car and in fact they are designed for it.
04-08-2011, 01:27 PM | #12 |
Rep 15,818
I want to find a kit that will look good, be great as a DD, and be great on the track
it seems the GC kit or Dinan are my only options...
04-08-2011, 01:30 PM | #14 |
59
Rep 623
Call Jay at GC - that's what I did. I did the initial research and then he answered any final questions and went out of his way to make sure the kit I got was perfect for my needs. The Dinan kit doesn't lower the car enough for my tastes and the GC kit is customizable. no brainer.
04-08-2011, 01:41 PM | #15 |
Rep 229
I didn't want to mess with untried/untested options so I sprang for the Dinan stage 1 kit with camber plates. It is one of the most satisfying upgrades I have ever done to a car and worth every penny to me.
04-09-2011, 02:17 AM | #16 | ||||
Rep 3,479
Drives: 19 M2C 6MT
I know KW just came out with one, i do like the idea behind it. I wish there was a perfect solution but there isn't Quote:
Yes, this was my original idea to do. But the drop is not satisfying enough.. I haven't seen it in person so maybe I will do that. But I wish the drop was more like an Eibach drop then I would probably pull the trigger. |
04-09-2011, 06:57 AM | #17 | |
Rep 638
I have a spare set right here, but I am in the UK. |
04-09-2011, 07:25 AM | #18 | |
Rep 6,007
I agree it would be nice if zcp was lower, 20mm would be max, but more than 10mm would be nice
04-09-2011, 05:57 PM | #19 |
E60_to_E90
36
Rep 1,201
These are tough criteria to meet, especially with the first two being somewhat contradictory. I had the same criteria, but add on "not introduce warranty issues". So I ended up with Dinan stage 1, which best met the above criteria. The ride is very compliant, still works great with my EDC, and rides very similar to OEM. It may not be low enough for some, but it's just right for me on my DD. I think the only other options would be GC or KW (of which I have no experience, so I'll leave others to comment).
2011.5 E90 Dinan M3, SS II, M-DCT, EDC, M Drive. 20" MORR VS8.2 wheels
Performance Mods: Dinan St.1 suspension, exhaust, intake; TTPs; BPM St.II, DCT, servo tunes Cosmetic Mods: OEM CF splitters, mirrors, center console, spoiler; Arkym CF diffuser; LUX; tint |
04-10-2011, 03:58 AM | #20 |
Rep 15,818
could you use the ZCP springs.....?
04-13-2011, 09:00 AM | #22 |
Rep 876
To the guys with the Ground control setup, are the bumpstops and spring perch OEM length or shorter???...ie-when you lower the car with their springs and camber plates, is the distance below the bumpstops maintained like the Dinan kit or are you losing some clearance??
I too would ike to drop the car 20mm front and 10mm rear but dont want to lose the clearance distance before hitting bumpstops. Also, same question for the KW sleeve kit, is this clearance distance maintained with the KW kit??? |
