03-24-2011, 06:52 PM | #1 |
Rep 374
Need Advice On First Major Mod..
solved.
iCARBON.KW.VMR.COBB.BERK.BMS.CPe.ActiveAutowerke
03-24-2011, 07:03 PM | #2 |
Rep 210
Option 4: Coilover suspension!
03-24-2011, 07:19 PM | #5 |
Rep 3,939
Quite frankly, I would start with suspension as someone else suggested. BMW performance suspension all the way!
03-24-2011, 07:20 PM | #6 |
Rep 5,730
Drives: BMW i3 rex
Garage List 2018 I01 i3s | CURRENT [0.00]
2018 G01 X3 | CURRENT [0.00] 2017 I01 i3 | SOLD [0.00] 2017 F48 X1 | SOLD ... [0.00] 2016 I01 i3 | SOLD [0.00] 2017 F22 M240 | SOLD [8.00] 2016 F25 X3 diesel ... [0.00] 2006 E60 550 | SOLD [6.00] 2011 E90 335 | SOLD [8.66] 2012 E82 135 | SOLD [5.50] 2011 E82 1M | SOLD [7.94] 2007 E85 Z4M| SOLD [4.50] 2003 E53 X5 4.6is S ... [9.00] 2008 E92 328 | SOLD [0.00] 2008 E82 135 | SOLD [0.00] 2008 E90 335 | SOLD [0.00] 2003 E46 M3 | SOLD [7.50] 2006 E90 330 | SOLD [10.00] 2003 E46 330ZHP | SOLD [0.00] |
wheels first
03-24-2011, 07:21 PM | #7 |
Rep 110
Drives: 2007 328i
I would choose wheels, just because I feel it can make the car look so much better.
03-24-2011, 10:34 PM | #9 |
Rep 488
If you are on a tight budget, just get sway bar instead of the whole suspension. Or better yet, before you make make your car any faster, put yourself through a driving school, like BMW one in SC. That will go a long way...
03-25-2011, 03:35 AM | #13 |
701
Rep 3,268
Drives: 2010 128i
Suspension!
03-25-2011, 07:07 AM | #15 |
satch
39
Rep 1,040
I did my GIAC upgrade first. I wanted to get an idea for the power complection of the car first to let that influence need for other performance mods. It determined exhaust, FMIC, and even helped with suspension, ssk and wheel/tire choices because the car and feel dynamics changed with a whole new power curve.
So no real science in my approach but it felt logical
"The Dingo ate your Mustang" |
03-25-2011, 03:38 PM | #17 |
Rep 921
biggest feel will be tune or non run flat tires.
if you've got good rubber you can get most of the money out of them towards a new set. If you don't want to hassle then i'd say.. Tune and front sway bar (e93 m3). The tune will give you the most feel as far as change to car, and sway will help to balance car in turns. Sure it will still float around, but you can take care of that in your next round of mods. To me exhaust and wheels are last on my list of things to do....I'm not concerned about the look of wheels (the car already looks pretty good on the 18s), and i'm not into loud in this type of car, sports car - yes, but the practical 1 does better for me surprising people, plus the n55 already sounds decent, performance gains aren't that big. Figure 1000 for 10-15 hp and 15-20 ft lbs. procede will get you 35-45 hp and 80-100 ft lbs.
18 X6M, 22 Tesla MYP, 21 Plaid, 19 Ram
03-25-2011, 04:12 PM | #18 |
Rep 602
I went BMW Performance Exhaust first, with the BMW Performance Suspension and Dunlop Direzza Star Specs (non-rfts) plus BMW mobility kit finally on the way. Next stop is a Quaife ATB LSD. Now to the whys using my sequence:
(i) all about the sound at every point in the rev range; (ii) suspension comes with a bit of slack to compensate for the stock rfts and my driving style and environment show up the slack a wee bit too much - will add suitable M3 suspension bits once I get my head around the benefit of each lil bit; (iii) roads here are a bit on the knotty side, and I tried a friend's 335i with the Dunlops recently, and the ride comfort etc is night and day compared with the stockers - mobility kit is for cushioning if, God forbid, I should get a flat - those softies show up the slack in the suspension tho, hence (ii) above; (iv) Quaife again because of the spinning inside wheel which either shuts down the power or burns a rubbery hole in my tire budget. Environment dictates that I am on multiple (wet, if it rains) hairpins on a short drive to work/town so I suffer; (v) next would be brakes (just the rotors - cross-drilled and vented) and downpipes ; and (vi) BMW performance power kit. You will see I'm a bit conservative on the power mods coz I don't really see an immediate need for them but nevertheless want superb handling poise, great traction and stopability. Hope this helps.
BMW Performance Exhaust, Michelin Pilot Supersports F-225/40, R-255/35, BMW Performance Suspension, BMW Performance black kidneys, Quaife LSD, M3 rear sub-f bushings, M3 front control arm, rear guide rod and rear upper link kits, BMW Performance cross-drilled/slotted rotors, AFE Cold Air Intake. Last edited by Yogijet; 03-25-2011 at 10:21 PM.. |
03-25-2011, 04:42 PM | #19 |
Rep 5,729
Drives: 2019 M2 Competition
03-25-2011, 04:44 PM | #20 |
Rep 5,729
Don't add 70 hp + with Procede or JB4 until you get that thing handling better
03-25-2011, 05:12 PM | #21 |
Rep 2,201
dont you give up ride comfort with coilovers?
i did them on a previous car and swore I will never mess with suspension again, my back cant take it
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten.. 1974 2002, many various 3s. |
03-25-2011, 06:59 PM | #22 | |
Rep 1,552
Drives: '19 M2C | '20 100AE ND2
The stock wheels look good, no reason to spend over $1,000 to change them as your first mod. So he can gain turbo lag at ~2-2.5k RPM like my friends with N54s? Yea, no thanks.
2019 M2C - Alpine White - 6MT
2023 Supra 6MT - Deposit and Wait Last edited by MarkR171; 03-25-2011 at 07:06 PM.. |
