03-24-2011, 12:28 AM | #1 |
www.facebook.com/weshowellcreative
59
Rep 623
Drives: 2015 AW M4 Coupe Project Car
BBK question
How does a BBK - like the Stoptech trophy kit, for example, affect the e-brake? Does the e-brake still work? need extra parts? does it keep OEM parts, etc?
Thanks (guess it's kind of a lousy time to ask since I bought my BBK, but I just didn't think of it) Thanks! |
03-24-2011, 01:35 AM | #2 |
Rep 1,315
Short answer, no. You don't need to do anything with e-brake.
However, some race design brakes do require removing the ebrake, but they would be written in discription. |
03-24-2011, 10:54 AM | #3 |
Supreme Allied Commander
3887
Rep 54,530
Drives: F80 M3
Yes, your e-brake will still work. There is no extra parts to install during the BBk installation process and oem e-brake components are retained with the exception of the oem e-brake drum, which is part of the rear rotor, but it's replaced by the trophy's.
03-24-2011, 01:41 PM | #4 |
Rep 9,034
Like what Harold said. The rear rotors have a steel rear drum for the e-brake, and weight a ton compared to the fronts.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
03-24-2011, 03:54 PM | #5 |
3887
Rep 54,530
Drives: F80 M3
03-24-2011, 04:10 PM | #6 |
Rep 961
It depends on who makes the kit, and whether they intend it to be usable for handbrake turns or not. The aluminum e-brake drum won't stand up to that kind of punishment, where a cast iron drum will.
03-24-2011, 05:07 PM | #8 |
Rep 9,034
That's what I thought. Maybe it's just the Trophy system?
03-24-2011, 09:38 PM | #9 |
Rep 4,737
Here's a picture of my rear axle w/o the OEM disc/drum. You can see the e brake shoes behind the hub.
And I believe that the OEM drum is aluminium... correct me if I am wrong. |
04-06-2011, 04:07 PM | #12 | |
Dr. Octagon
260
Rep 1,919
Both hats are Al.
OC ///M
2013 E92 M3 Individual Sold: 2011 E92 M3 SSII | Sold: 2008 E92 M3 SSII | Into a Wall: 2008 E92 M3 SSII | Sold: 2007 E92 335i JB |
04-06-2011, 04:16 PM | #13 |
Rep 638
The Oem rotors rear hats are aluminium, but have a steel liner pressed in.
Brembo and Stoptech use aluminium hats that are hard anodised. Alcon uses a steel rear hat which weighs a ton Last edited by alpina527; 04-10-2011 at 03:12 PM.. |
