03-13-2011, 09:09 AM | #1 |
Rep 6,007
ZCP Question?
Just ordered a new M with ZCP this time, but think it's going to need just a slight more drop. I'm considering a Dinan Stage 1. My question is how the ZCP achieves it's lower ride height, and if I add Dinan springs will it take the ZCP 10mm drop and drop another .5" ? If so I think this would put me at just the perfect height for looks and driveability would remain perfect. Or if I put Dinan on my ZCP would it end up the same and a non-zcp car with Dinan?
03-13-2011, 09:30 AM | #2 |
Rep 638
It's done on the spring perches, so the Dinan springs will give a nice drop.
10mm lower than a stock M3 plus 12mm from the Dinan springs to give a 22mm drop which is just about perfect. |
03-13-2011, 09:39 AM | #3 |
Rep 6,007
That's what I thought... so 10mm + .5" with full suspension travel should be a sweet setup.
03-13-2011, 06:56 PM | #4 |
Rep 1,253
Drives: F10535, E90M3, E30M3, E28M5
Garage List 2017 Alpina B6 GC [0.00]
2014 535xi M Sport [0.00] 2014 X3 3.5 M Sport [0.00] 2011 M3 E90 [9.74] 2007 Z4 M Coupe [7.00] 1990 M3 [9.50] 1988 M5 [10.00] |
Congrats JO8M3 on your new ride!
I'd be interested in reading your review if you go ahead with the Dinan Stage 1. Kind regards....
ESS VT-1 550 | M24 Oil Cooler | Fall Line Half Cage | RaceTech 4009W | 6 pt Harness | Lifeline Zero 360 Fire Suppression | Rear Seat Delete | Motion Control DA Dampers w/remote reservoirs | 900/650 Hyperco Springs | RD Sport Sway Bars | Brembo 380 BBK | GC Camber Plates | Hoosier R7 | Eisenmann Sport | Stack Gauges | Painted Challenge Front Lip | Painted ZCP Rear Spoiler | Xpel Ultimate Film | LuxAngelEyes |
03-14-2011, 12:26 PM | #5 |
Rep 1,504
I'm not sure about this one. If so, how is the rear drop accomplished? I think the drop is done with springs alone.
'09 E92 M3 6MT | Alpine White | Black Leather | EDC | CL Trim | 19s
'03 E46 330i 6MT | Electric Red | Black Leather | ZSP | Bi-Xenons |
03-14-2011, 12:48 PM | #6 |
Rep 6,007
hmmm.... good question. If this is true then I don't know if I'd still want to use a dinan drop.
03-14-2011, 01:03 PM | #7 |
Rep 4,971
I think I remember seeing that someone upgraded a non zcp to the zcp suspension. Not sure if it was an actual thread or not. Maybe he mentions what components are required and how the drop was achieved. Ie. Non ZCP vs ZCP spring lengths etc.
03-14-2011, 02:27 PM | #9 |
Rep 1,504
Hopefully Dinan will have the answers. I think at first it was thought that the perches were different heights on the front but I don't think it was ever confirmed. It just never made sense to me that they would do it that way. I will eventually put ZCP wheels and springs/struts/shocks on my car but I'm waiting until I need tires, which might be a while.
03-14-2011, 04:12 PM | #11 | |
Rep 3,178
///M3 | E90 LCI | Space Grey | Fox Red with CF Structure | 6MT | 260M | My build
03-14-2011, 05:49 PM | #12 |
Rep 6,007
so that thread seems to think it is just shorter springs? hmmm... lot's of conflicting info on here. well hope I like my ZCP as is.
03-14-2011, 06:43 PM | #13 |
Rep 596
I recently installed dinan stage one on non zcp car. Stage one is simple set of shorter springs plus bump stops for the front and spring guides for the rear.
03-14-2011, 07:32 PM | #14 |
Rep 6,007
Dinan just emailed me back saying I would only gain 1/8" more drop. I guess that means zcp isn't done from perches and is just shorter springs.
03-14-2011, 08:07 PM | #15 |
Rep 4,971
Thats too bad, I say wait and see until you get your new car. If you still want lower, the ground control kit may be your only option that allows you to keep EDC and have some height adjust-ability. You can also corner balance your car as well.
03-15-2011, 11:16 AM | #16 |
Rep 6,007
If that was true than Dinan springs would lower me .5" more than the 10mm drop. According to Dinan this is not true and I will only be 1/8" lower if I install their springs.
03-15-2011, 02:41 PM | #17 | |
Rep 638
Put them side to side on the bench and you will see the difference. Has anyone on the board got a set of front ZCP dampers hanging around that you can get the measurements from to prove it? |
03-15-2011, 03:52 PM | #18 | |
Rep 4,567
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem |
03-15-2011, 04:34 PM | #19 |
Rep 6,007
this would be great to get to the bottom of
03-15-2011, 08:53 PM | #20 |
Rep 246
I read some where on this board that Dinan was making a ZCP specific suspension. Perhaps different spring rates and a tad bit lower ride height. I would wait on this mod if i were you. Or if i was looking to lower, then look elsewhere. Eibach Pro's or maybe RD Sport.
03-16-2011, 06:54 PM | #21 | |
Rep 1,424
03-16-2011, 07:41 PM | #22 |
Rep 6,007
If that's true I'd like to find out. None of that had been mentioned to me in my discussions with them.
Sounds a little odd though since BMW just used shorter springs to lower the zcp. In that case there would be nothing zcp specific to Dinan's maybe new mod. Would like to find out though. Def be interested if it's true
