03-10-2011, 04:04 PM | #1 |
Rep 1,519
ATE super blue ok with StopTech BBK?
I'm having a StopTech 6-piston/4-piston BBK installed on my E90 M3 tomorrow. It's my daily driver and I plan on several track days this season. The shop doing my work is a reputable BMW-specific shop. I asked if they could source Motul RBF 600 brake fluid for me to use at the time of the BBK install; they said their brake flush systems are pre-loaded with ATE super blue and they feel the ATE fluid will be more than adequate for a few track days given the high thermal capacity of the StopTech BBK. They think it would be highly unlikely I would boil the ATE fluid given that I'll be running the StopTechs. Any thoughts? ATE super blue's boiling points are 536/388 F, while the Motul's are 594/421 F. Thanks...
03-10-2011, 04:58 PM | #2 |
Rep 5,329
ATE superblue is fine for your system....... awesome fluid...... wish i could get it easy here in the UK as its what id use.... even better you can bleed perfectly as you see the blue flue bleed through.
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com |
03-10-2011, 05:17 PM | #3 |
Rep 9,032
It should be fine.
Could they run Castrol SRF?
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
03-10-2011, 07:36 PM | #4 |
One mod leads to another ...
416
Rep 2,900
I just had my ST BBK installed and the shop used the same fluid.
Current: 2014 F10 M5 Previous: 2015 F80 M3, 2013 E92 M3, 2013 F10 M5, 2009 E90 M3, 1998 E36 M3 |
03-10-2011, 10:01 PM | #6 |
chris
278
Rep 12,144
i use ATE and have no issues. but if youre a hardcore track nut then you might want castrol SRF. my skills just arent there yet.
Current: 2013 F10 M5 & 2016 Mini JCW 2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone) |
03-10-2011, 10:10 PM | #7 |
Rep 3,831
Lots of track junkies use Motul RBF 600, good stuff.
03-10-2011, 11:15 PM | #8 |
Rep 1,519
Thanks for the quick replies, everyone. I'll do the ATE super blue per my shop's recommendation, and then I can always switch over to Motul or Castrol SRF later if need be...
03-10-2011, 11:37 PM | #9 |
Rep 961
03-11-2011, 06:55 AM | #10 |
Rep 3,831
Same here. Change it once in the spring.
03-11-2011, 07:37 AM | #11 |
416
Rep 2,900
So do you only bleed once a year too? I wasn't sure when you said "change" if that was a complete flush once a year or flush and bleed once a year.
03-11-2011, 10:08 AM | #12 |
Rep 525
Drives: '21 F95 X5 M C, '11.5 E92 M3 C
I use Motul, however, I know a few racing buddies absolutely hate Super Blue...not because of the performance but because of the mess that blue fluid causes.
Drives: '11.5 Interlagos Blue E92 M3 Comp, '21 F95 X5 M Comp DIYs: Enable Rear Fog | Easy Side Gill Replacement | Front Grill Replacement |
03-11-2011, 12:45 PM | #13 |
chris
278
Rep 12,144
well ATE makes the same fluid in gold too if you dont like the blue color.
03-11-2011, 06:39 PM | #14 | |
Rep 961
As for bleeding the brakes, my driving instructors have hammered conservative brake management so deeply into me that the calipers stay under 200 degrees Celsius. That way, I don't have to bleed them more than once a year either. |
03-12-2011, 01:06 AM | #16 |
Rep 3,831
I pretty much change out the fluid once each spring, before track season. I started doing this 2 years ago and have had zero issues. Castrol SRF is expensive up front, but since it will pretty much last you a full year with out needing to bleed your brake system or anything, it works out the same or less.
