03-05-2011, 07:45 AM | #1 |
Rep 6,007
ZCP vs. Dinan Stage 1... need some info
About to place an order for a new car this week and trying to decide if ZCP is really worth it. Has anybody had experience with both ZCP and Dinan Stage 1? It's going to be one of the two choices. I don't have any experience with either, just what I read on the forum. I know Dinan is about $1,100 and I think you need a dealer to install it if you want the Dinan warranty? So I guess all said and done after an alignment the two are close to the same price? How does looks and handling compare between the two? Thanks
03-05-2011, 10:35 AM | #2 |
Rep 6,125
I don't know about the handling differences between ZCP and Dinan but...
Lowering heights are very similar. And you don't have to install Dinan springs from the dealer. I installed from local reputable shop and dealer is fine with it. As long as it is installed properly, it's fine.
PAST: F80 M3 ZCP | 911.1 C2S | F10 M5 ZCP | E70 X5M | E90 M3 | E46 M3 | E36 M3 |
03-05-2011, 10:39 AM | #3 |
Rep 229
03-05-2011, 10:55 AM | #4 |
Rep 3,246
here are some pics of the look
http://www.m3post.com/forums/showthread.php?t=462561 i felt the dinan was a better track setup as i drove the zcp at my home track less than a week after having a lapping weekend there and also from hopping from one to the other liked the dinan better... good luck, either way you'll be smilin the hole time
mods: track ready stuff
03-05-2011, 11:20 AM | #6 |
Rep 4,971
Personally if I was going to order a car right now, I would just order it as ZCP, but not because of the suspension. I would consider the Dinan set up (especially since Dinan mirrors the OEM warranty), but I would lean toward the Ground Control set up as it gives you the ability to adjust the height and also allow you to corner balance the car. There has been some good feedback on that kit, on and off the track.
03-05-2011, 11:22 AM | #7 | |
Rep 6,007
03-05-2011, 11:30 AM | #8 | |
Rep 4,971
Good luck with the order! Edit: Oh, and keeping it OEM is a nice touch. (even thought I have way too many mods on my car with more to come...its a disease ) |
03-05-2011, 11:40 AM | #9 |
Rep 4,737
If you know for sure that you will put an aftermarket suspension in it, Dinan or coil over, don't bother with ZCP.
You do NOT need dealer installation to get the warranty. |
03-05-2011, 04:26 PM | #10 | |
Rep 6,007
Someone else posted a thread that said if you put Eibach on ZCP it would sit slightly lower than Eibach on non-zcp? If that's true, it's got me wondering if Dinan on ZCP would sit slightly lower than either Dinan or ZCP alone?? Could be a nice mix if drives really nicely and sits just a touch lower. I really like the slightly lowered look, but hate the slammed look.
03-06-2011, 08:35 AM | #12 | |
Rep 6,007
Only decision I have to make is if I try to lower it just a touch more with Dinan, if it's possible. Car is due to me end of april.
03-06-2011, 08:46 AM | #13 | |
Rep 4,971
Post up some pics when you get it. |
03-06-2011, 08:54 AM | #14 |
Rep 6,007
haha... I guess I will need a new one. I'll def post some pics.
03-06-2011, 09:36 AM | #15 |
Rep 1,198
Having owned a zcp car - I'll give my $0.02... I did not like the eibach pro-kit springs on my car - didn't like the ride height differences between front and rear and handling wasn't as good. I really felt it was a step back from the zcp setup.
So I switched to the GC conversion kit. On the street it is more firm than the stock setup and on the comfort setting body motion was not as controlled as stock. On track, normal setting still allowed for too much motion imo and sport setting was just right. Car was well planted and motion control was much better. I was not running r-compounds so that could affect your opinion of this combo as I'm don't know how the suspension would handle the higher grip/cornering speeds. But I did like this setup alot on track. In summary, the stock zcp is actually very good in terms of handling and ride quality trade-off on the street. GC conversion is definitely firmer but not harsh. I did not track the zcp suspension so I can't comment on it's performance on track. I can say for sure that the GC conversion and firm setting is very nice on track and I assume it's due to the revised programming of the zcp EDC. Good luck with the new car - you will like it for sure! BC
'15 M3, '16 911 Turbo S Cab
