03-04-2011, 05:53 PM | #1 |
Rep 531
18" VMR 18x9.5 ET22s fit with 380mm Brembo BBK?
I have the above wheels (VMR 710) for the track and was wondering if anyone has had these on their car with a Big Brake Kit? Specifically 380mm up front?
I'm in the market for a BBK, as it were.
Gone but not forgotten...2009 E90 Le Mans Blue M3 6MT De-Chromed, Rogue SSK, Brembo BBK, Eibach Pro Kit, Eisenmann Race Black, MS Filter. 1998.5 Titanium Silver E36 M3 Coupe NASA GTS2 Race Car.
03-05-2011, 09:18 AM | #2 |
M-Flight Member
38
Rep 1,085
Brembo site:
Rotors up to 320mm require a minimum 16 inch wheels Rotors 323mm, 328mm and 332mm require a minimum 17 inch wheels 345mm to 355mm Rotors require a minimum 18 inch wheels 380mm Rotors require a minimum 19 inch wheels
2011 Le Mans Blue M3// Black extended Novillo w/ Blue Grey Aluminum trim/DCT/ZTP/ZCW/ZPP/ZCP Premium Sound ///Akrapovic Evolution Exhaust
2015 Audi S4 Prestige, Brilliant Black S-tronic 2012 Le Mans Blue 135i M Pkg DCT |
03-05-2011, 09:36 AM | #3 |
Rep 7,887
380 MM Stoptechs will work with a lot of the 18" wheels readily available like the Apex & TR Motorsport wheels.The Brembo 380's are 7mm larger so it is tougher to find an 18" wheel that will work with them.
03-06-2011, 11:00 AM | #5 |
Rep 531
thanks but I'm not in the market for new Wheels as I already have the ones listed above. I need to know about Brembo Rotors. As I understand it, the Stop Tech Rotors are different in size as well.
03-06-2011, 06:48 PM | #6 |
Rep 531
Will the 380mm Brembos fit with ANY 18s?
03-06-2011, 08:05 PM | #8 |
Rep 531
Care to elaborate? What would you recommend?
03-06-2011, 09:43 PM | #9 |
Rep 9,032
18" wheels that fit Brembo's: VOLK TE-37, VR2, CCW. That's all I know.
You're better off getting Stoptech's so you have more clearance.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
03-07-2011, 08:39 AM | #11 |
Rep 8,496
Not sure if they're 380mm but you should contact this guy.
http://www.m3post.com/forums/showpos...3&postcount=43 |
03-07-2011, 09:19 AM | #12 |
Rep 3,450
03-07-2011, 09:34 AM | #13 |
Rep 531
Thanks for the input guys. Much appreciated. Sounds like I might have to look into other than Brembo unless I want smaller rotors or different wheels.
03-07-2011, 10:25 AM | #14 | |
Rep 9,032
Those yellow Brembo's are definitely not 380mm. OP should ask VMR of the vender he bought them from. I don't think they were designded to fit a BBK of any type.
03-07-2011, 07:20 PM | #17 |
Rep 9,032
Well, that's not good. Time for new wheels then.
03-08-2011, 11:08 AM | #18 |
Rep 531
Not a chance. I'm not paying for new wheels and then track rubber for 19" wheels just so I can fit bigger rotors on my car. I'll just have to go with 365s. Has anyone ever driven some hard track sessions with both a 380 and a 365? If so, is there much difference in the amount of work they are up to? I assume the 365s are still far better than stock in terms of fade resistence? I typically run my car at BIR which is a pretty fast track and is notoriously hard on brakes. My OEMs start to fade pretty good after a few hard laps.
03-08-2011, 11:39 AM | #19 | |
Rep 3,450
03-10-2011, 11:26 AM | #20 |
Rep 531
Who makes the VR2 wheel? Is that Volk Racing?
03-10-2011, 01:50 PM | #21 |
Rep 9,032
My bad, it's just the TE-37 VR by VOLK.
05-13-2011, 09:13 AM | #22 |
Rep 531
So I bought the 365mm Brembos some time ago and went to put on my track wheels last night to get ready for a weekend at the track and those DON'T FIT either.
I have a set of 12mm spacers but did not have them with me at the time, so I'm going to give those a try this evening. I'm hoping they work otherwise this could turn out to be an expensive set of brakes (plus new track wheels) I'll be the first to admit that I'm stupid for assuming that the 365s fit all 18s. I should have measured those as well.
