03-03-2011, 12:04 AM | #1 |
Rep 1,315
AP BBK issue and questions
I just got my car back with AP BBK installed. It's my first time to use AP BBK, not sure if the BBK performs the way it is. Now I'm running AP BBK with F3R pads on front's and Xtreme pads on rear's, tires are Hankook R-S3, suspension is KW V3.
1 Lack of response, braking comes late. The first 70% of braking is lack of response for some reason. No matter what speed I'm in when I'm stepping on the brakes, there's no much response, unless I keep pushing all the way down. 2 Braking power. For example, I have Brembo BBK with Endless ME20 pads, Moton and R888 combo on my Pcars. it's kind of braking that how much I apply, how much I get. If I slam on it, my lung would stick to my belly. But the braking power on AP doesn't even come close to that. I know that tires and suspension have some difference, but aren't AP BBK suppose to have better braking that Brembo? I'm not sure if the F3R pads require pre-heat or what. I'm going to the track this weekend, but kind of scary about the braking power I have right now. It's no better or worse than stock set up. Is there any chance the shop didn't bed in properly? However, they installed some other BBK on my other cars before, no issue. Any input would be appreciate. |
03-03-2011, 12:21 AM | #2 |
Rep 4,737
1. Make sure your fluid is bled correctly.
2. Make sure there is nothing leaking. (check brake fluid reservoir and caliper bleed screws/hoses) 3. Make sure you properly bed-in your pads. (http://www.m3post.com/forums/showthread.php?t=396763) I know a few people on the board who has the AP kit, and none I know had 'brake power' issues you described. |
03-03-2011, 12:28 AM | #3 | |
Rep 1,315
hmmm, I need to check it out tomorrow. |
03-03-2011, 12:54 AM | #4 | |
Rep 4,737
Actually, some new info I found... Easiest way to verify is to put in Xtreme front pads if you have them... Or just get your brakes hot.
03-03-2011, 11:08 AM | #6 | |
Rep 961
I'm with rldzhao - you've got air in the brake lines. The AP pedal is firm and right up there - you shouldn't be able to push it very far before it gets too firm to push any further. Once you get that fixed, you'll have lots of stopping power.
03-03-2011, 10:32 PM | #10 | |
Rep 1,315
I guess I'm in bad luck lately, from coilovers install to brake, none of them was one time deal. damn |
03-04-2011, 07:48 AM | #11 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
I'm thinking you are just experiencing cold race pads on the street. Also, they may not be completely bedded, yet. Go bed them in per this recommendation:
Zeckhausen Bedding Instructions Have fun. Doh! Never mind. Just read the rest of the thread.
Dinan compliment of stuff plus PF rotors and RG63s. Enough for now. Why, yes. I am an abrasive bastard. |
03-04-2011, 09:24 AM | #12 |
Rep 9,032
Dude, it's pretty common. I almost expect to have to go back after an install.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
03-04-2011, 10:48 AM | #13 | |
Rep 961
My experience with replacing calipers and lines is that they usually need a second bleed after a day or two of use to really get them solid. |
03-06-2011, 04:53 PM | #14 |
Rep 1,315
Thank you guys for the help. The brakes performed well on track. It responded better under hard braking than my Brembo GT's. But those pads squeal at any temp and speed, damn.
Anyways, I'm happy with the outcome at the moment. |
