10-01-2010, 02:23 PM | #1 |
Rep 212
Can't quite figure out Auto High Beams
The Manual says to put your lights in position 3 (auto), then briefly pull the turn signal stock to the high beams. At this point the high beams should be engaged, and will disengage when the sensor picks up lights in the opposite direction. Am I missing something?
2011 AW 135i Coupe|6MT|Savanna Beige|M Sport|Navi
Order Placed: July 26 | Production Started: Aug 09 | Production Complete: Aug 17 |At Port: Aug 19 | In Transit: Sept 02 | At Prep Center: Sept 15 | At Dealer: Sept 25 |
10-01-2010, 03:32 PM | #2 |
Rep 1,349
What's not working, is it not turning off the high beams when you have an oncoming car?
21 BMW X5 xDrive40i
20 BMW M2 CS 19 Mini Cooper S Countryman ALL4 6MT |
10-01-2010, 06:22 PM | #3 |
Rep 212
It says a symbol is supposed to light on the dash showing its activated. I'm not getting that indicator at all
10-01-2010, 11:42 PM | #4 |
The Only Sane One Here
61
Rep 1,135
Me either. The high beams activate, but no light on the dash. But I've only tried it in the garage (cause I just got the car), not on the road, so I don't know if it's working. Still, seems to me there should be some indicator that it's active.
2011 135i VERT SGM/SB/MOONLIGHT - ED - with every single friggin' option they offered.
10-02-2010, 07:54 AM | #5 |
Rep 212
Well in the garage the lights are just going to bounce off the wall and reflect back into the light sensor and thus shut them off. Let me know how it works on the road.
10-03-2010, 12:21 AM | #6 |
Lord Captain Commander
112
Rep 3,093
The symbol that should come up on the dash is an A within a normal high beam signal. You either flicked the stalk twice to manually engage high beam, or you have the feature switched off.
E82 135i M-sport: SGM/6MT/Black |
10-22-2010, 03:26 PM | #7 |
Rep 1,177
something with cruise control.. after you set the speed there is no indication on the dashboard about it
Alpine White, Coral RED , Glacier Silver Aluminum trim, M sport, 6MT, NAV, HiFi, USB-iPod, Bluetooth
Performance: JB4|BMW PE|DP Cosmetics: BMW Sport Pedals|Black Kidney Grill |
12-26-2010, 10:44 AM | #9 |
61
Rep 1,135
It's an option. Not sure if it was available in 2008.
BTW: the OP says you "pull" the stalk, but IIRC, you actually push it away from you.
