08-21-2010, 09:50 AM | #1 |
Rep 1,653
radar detector
anyone hardwired one in their car? i know it is illegal in VA, but i make a lot of trips from va to nj. any installer recommendation?
2011 E92 Space Grey/black + Tech + Premi + Heated Seats
08-21-2010, 09:54 AM | #2 |
Rep 1,603
Drives: my feet
depends!! John (Shieldze) can hardwire it, hes got one in his car. Or Abe at Designo can have it show on your rear view mirror for a stack maybe.
2008 Alpine White e93 335i- Sold
2009 Black Sap. Met. e93 335i- Sold 2010 Melbourne Red e92 M3- Sold |
08-21-2010, 10:42 AM | #3 |
Keepin' America Free
72
Rep 1,260
Yea It's pretty easy, check out the DIY section in E90Post. I can help you with it.
F10 535i | Retired: E60 ///M5 | E92 335i
"If everything seems under control, you're not going fast enough" -Mario Andretti |
08-21-2010, 12:23 PM | #5 |
72
Rep 1,260
Probably not, I have mine on my visor so I can take it off if needed, but it's still hardwired into the sunroof/sos power
08-21-2010, 12:50 PM | #6 |
Rep 1,653
got a pic of urs?
08-21-2010, 01:20 PM | #7 |
72
Rep 1,260
No... I'll take one when I get a chance
08-21-2010, 02:38 PM | #8 |
Rep 270
Doing mine tomorrow hopefully.
18 Alpine White F85 X5M // 03 Titanium Silver E39 M5 // 13 White Porsche 991 911 Carrera
(Gone but not forgotten) 15 Mineral White Metallic F15 X5 XDrive50i M Sport // 09 Melbourne Red E92 M3 // 08 Space Gray E70 X5 4.8i // 07 Black Sapphire Metallic E86 Z4 M Coupe |
08-21-2010, 03:11 PM | #9 |
l33t
22
Rep 237
08-21-2010, 03:43 PM | #10 |
Rep 1,653
thank you
post it up when you get it done
08-23-2010, 08:19 PM | #11 |
72
Rep 1,260
I'm gonna help carl when I get back from Seattle next week. It's pretty easy once you know how to do it, so it shouldn't take more than 30 mins. I'd be glad to help all of you do it.
It is easiest if you have SOS or a sunroof. To be honest, that's the only way I know how to.
08-24-2010, 09:00 AM | #12 | |
Rep 270
08-24-2010, 09:07 PM | #13 |
Rep 134
I pulled the cover off my rear view mirror and that looks like the simplest way to do it. I ordered the invisicord and it should be here tomorrow or the next day. After it gets here word is that it takes about 30 seconds to wire up and then you're good to hook. There is a write up on it here:
http://www.m3post.com/forums/showthr...ght=invisicord |
08-25-2010, 11:34 AM | #14 | |
Rep 270
08-28-2010, 10:20 AM | #16 | |
Rep 134
Just installed mine, it went a bitdifferently for me. The lead for the ground wire was too long to go where OP had it and still have the cover fit back over the whole set up. I ended putting the ground right next to where OP had the power lead. I had to file both of the ends down a bit to fit in because they were a bit too thick. I also wrapped the part of the leads that would be exposed since they were so close to each other to prevent a short. Other than that little snag the install was relatively painless. I would suggest getting at least the 12", I went with 16" and it is enough for me to run the unit on either side of the mirror. It looks much cleaner than having that cord running from the lighter, plus a bit more stealth. I didn't take any pics of the process because the OP has that pretty well covered. I will say that the easiest way to get the mirror down is to twist the whoe unit counter clockwise about 90 degrees and the whole thing will come down. Then you can take the plastic cover off without scratching the hell out of it. Then to put it back on it's the same thing, start it at 90 degrees from the normal position and twist it back on to the cam nut that is embedded in the windshield. I'm functionally retarded and the whole process from start to finish, including grinding the leads down on the sidewalk (cuz I was too lazy to go back in the shed and find my file), took about 15 minutes. I would recommend this setup if you're looking for an easy way to hide your unit. Chest |
